Originally Posted by
cmotors
I hear ya. Better to be safe than sorry, that's for sure. The ignition wire really isn't drawing much of any power. It is only for determining if there is power active on the line. If it sees power, then it tells the radio to turn itself on using the actual hot wire, which is typically the yellow wire. This hot wire is what pulls the power to run the radio. As long as you are tapping with the correct fuse and gauge of wire rated for the amount of amps, it shouldn't be a problem. I avoided using the sunroof fuse because the fusetap that I bought was not rated high enough for the amps found on that particular fuse.
But again, the radio ignition wire is not drawing power from that line, only sensing whether there is power on that line and using it as a cue to tell itself when to power on, and when to shut off (when it no longer sees power on that line).
