Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 1997 Fiat Brava SX 1.4 12v
  1. #11
    May 2009
    hey all,
    A few days ago i finally applied the first layer of bondo, this afternoon I hope to find some time to start sanding again... Here are some new pictures of my build:
    So still to do:
    - More bondo and more sanding
    - Paint
    - finding a new position for the rearwindow heating button, the emergency lights button and the foglight button
    System status:
    Carputer [#####]
    Dashboard with display v1 [#####]
    Dashboard with display v2 [##---]
    Centerconsole with Cardreader and DVD-drive [#----]
    Relocation of some dash buttons [#----]
  2. #12
    May 2009
    Hey all,
    again a short update... Last monday I applied the first coat of spray-on bondo (or however it's called in english)... On the pic below (taken with my mobile) it really starts to look good, but on close inspection its obvious it still needs some more sanding and bondo.... but i am getting closer :-)
    I also started the centerconsole bit to accomadate the Cardreader and DVD-drive... pictures on that will come in soon!
    So still to do:
    - Paint
    System status:
    Carputer [#####]
  3. #13
    May 2009
    Progress is slow due to the cold weather overhere, most of the materials i'm using can only be used above 10C and it's -5C on average now...
    I did however finish my centerconsole insert with Cardreader and DVD-drive :-)
    A few pics, raw build:
    The raw build in primer:
    Test fitting the raw build:
    Painted:
    I do not have a picture of the finished product build into the car but I'll post one soon, sorry :-)
    Yesterday i also started on relocating the radio front so i can have "normal radio" untill I've found a suitable replacement (usb-radio) to go inside the carputer.
    It's still in the planfase, so i'm planning as i go along :-) Here's what I've got so far, I'm not sure btw if i'm gonna leave it flat or if I'm going to add a "sunscreen" above the radiofront, does anyone have a bright idea?
    So still to do on the dash part:
    - Paint --> I decided on getting a professional paintjob btw to make it look as good a possible.
    System status:
    Carputer [#####]
    Centerconsole with Cardreader and DVD-drive [####-] --> only needs connecting USB to the computer
    Relocation of a radio front [##---]
  4. #14
    May 2009
    Hi guys!
    I bought a radio module from Car-TFT so i no longer need to relocate the radio front (as planned earlier, see pic below). Now I only need to decide if i'm going to relocate a radio which will then only be used as an amp or just use a real amp?
    Last week I started with the relocation of the dash buttons, in the meanwhile I finished it aswell including the extension cable for the buttons.
    Below the pics of the build
    To make the build process easier I took a piece out of the center tunnel of a crashed car as a template and made the panel to fit in it.
    This is the panel I made in the final shape, already coated with glass fiber resin and sanded down slightly.
    The panel sprayed with spray on filler to bring out imperfections.... and there were lots of them
    After a few times sanding and bondo-ing
    Painted and with the buttons fitted. For the picture I placed into the template to get a better idea how it's going to look fitted into my car.
    System status:
    Carputer [#####]
    Dashboard with display v1 [######]
    Dashboard with display v2 [####--] --> Only needs to be build into my car
    Centerconsole with Cardreader and DVD-drive [#####-] --> only needs connecting USB to the computer
    Relocation of some dash buttons [#####-] --> Only needs to be build into my car
    Relocation of a radio front [##---] --> stopped production
  5. #15
    May 2009
    The dash piece nearly finished!
    Because I was not confident with my painting skills I took the dash piece to a body-shop of an ex-colleague of my brother in law to get it sprayed. He offered to finish the sanding and bondo-ing for me, apparantly I could have done a better job... And all the while I thought I did a pretty good job....
    Below some of the pics he made of the process:
    This is how it looked when he finished taking off most of my bondo work, most of my bondo work gone... WTF?
    Apparantly one of the bondo/filler types I used was incompatible with his paint and quite brittle so it had to come off.
    The new 2-component Bondo applied, it looks like he's a little less cautious applying bondo as I was...
    After bondo and sanding he primed it, see how good it already looks! On to the spraying booth!
    And this is right after he painted it, so a bit more shiny then it is now. He used a textured kind of paint to match the texture of the rest of my cars interior, looks great imho
    When I got it home I started placing back the ventilation grills. That was a disaster! Every single bar of those grills kept falling out of its slot, put one in a slot and another pops out, arghhh.... In the end it took me 1,5 hrs to get them in...
    Luckily the heater panel went in with only a little persuasion and the display went in without a hitch, below the pics of everything assembled !
    The complete piece:
    some detail pics:
    So what's left?
    - I need to come up with some pipes to connect the heater vents from their new location to the old location.
    - The radio or amp question
    After this I can finally put everything into my car
    System status:
    Carputer [#####]
    Dashboard with display v1 [######] --> will be scrapped shortly :-)
    Dashboard with display v2 [#####-] --> Only needs to be build into my car
  6. #16
    May 2009
    Radio or amp question...
    Well, the radio or Amp question answered itself.... While doing a test fit and some listening het radio I planned to use started bellowing smoke and of course it died on me...
    So now I'm installing the cables for the Amplifier, I already tested it with the cables lying loose through my car and everything worked fine! Hopefully i can get everything hooked up during next weekend an also shoot some pics!
  7. #17
    May 2009
    New dash first time fitted into the car!
    Yesterday afternoon I finally found some time to start making some new pipes for the airvents i moved to up in my dash. Running these pipes got a lot easier since the radio I planned to use died on me so there's lots more space in the dash now I also got my amplifier hooked up and it seems to work fine!
    Below some pics of the new dash inside my car for the first time. On the pics I've still got the dummy display installed because i was afraid to damage the real one while trying to make the pipes for the airvents.
    In the pics you can also see the panel I made for the buttons that used to be in the dash. They're already hooked-up and completely functional I may respray that panel though because there's some color difference between the panel and the installed buttons
    overview from outside the car
    frontal view from inside the car
    System status:
    Carputer [#####]
    Centerconsole with Cardreader and DVD-drive [#####-] --> only needs connecting USB to the computer.
    Build in Amplifier [######]
  1. 1991 Fiat Uno 1.5 SX
    By bbrotherr in forum Show off your project
    Last Post: 09-07-2009, 12:49 PM
  2. Fiat Brava 'FiatTEST socket' to OBDII socket
    By jellymonster in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-10-2009, 04:40 AM
  3. Fiat Brava OBD-II Compatible?
    By Pharazon in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-22-2006, 10:12 AM
  4. -12V and -5V rails explained:
    By andrewb in forum Power Supplies
    Last Post: 03-19-2006, 10:52 AM
  5. Microsoft, Fiat Announce In-Car Computers Partnership
    By uxu in forum General Hardware Discussion
    Last Post: 07-19-2004, 06:45 PM
