Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: Buidling a new PC for my Car looking for opinions on the hardware
  1. #11
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    I think that's a great case. I would be concerned about getting the M4-ATX in there, though. You could do as well with an M2-ATX, I'd bet, and it might fit more easily.
    Since Mini-box manufactures the M-350 case and the M2-ATX (and the M4-ATX), you might call or email them and ask which of their PSUs will fit in that enclosure with the boards you're considering. And you might consider buying directly from them, since you're paying list price, anyway. I bought my M4-ATX direct, and they shipped the same day.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  2. #12
    Jun 2009
    http://www.mini-box.com/picoPSU-150-XT that is the other power supply i am looking i know it is a direct fit on the board with a 24 atx instead of the 20pin. also it seems that i can get a kit with a power supply for thehouse so i can test easy.
  3. #13
    Constant Bitrate simplex's Avatar
    Oct 2009
    Budapest, Hungary
    Quote Originally Posted by rdholtz View Post
    I looked at those minor differences and decided not to spend over twice as much for the Asus board.
    Not minor differences, the whole design is better:
    -heatsink
    -ram slot placement
    -sound card
    -solid state capacitors
    You should also check Gigabyte GA-GC330UD: not overkill as the ASUS board, but still,
    you get better BIOS, heatsink, capacitors, for almost for the same price as the Intel board.
    Conclusion:
    Do NOT go the Intel board, go with the Gigabyte one,
    or if you want onboard HDMI, 7.1 and bluetooth, go with the ASUS.
    Check my worklog:
    Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
    Lord of the boards: DFI CP100-NRM
    "Or you can try Ubuntu, but than don't tell everyone you are using linux,
    because it's just a secret unreleased prebeta of Windows 3829" :P
  4. #14
    Jun 2009
    i am thinking Asus is still the best even after looking at everything. it always gives me the option to bring it inside and use it on a tv for any onboard movies
  5. #15
    Jun 2009
    I am doing some more looking into SSD drives and they seem really best for a car like stated above. shock proof and better temperature. I am thinking about doing a single 64 gig drive to house music OS, and the rest of the software i want to install. i saw someone said it can on be written a certain amount of times. anyone know how many times?
  6. #16
    Oct 2009
    Budapest, Hungary
    Quote Originally Posted by brianteel View Post
    Well, get a decent SSD (for example OCZ Vertex), it still lasts longer than a normal
    HDD in this enviroment. Also, a bit faster. But for best results, you should only use
    the SSD for the static part of the system, and do all the dynamic stuff
    (music, hibernation file, pagefile) on a laptop HDD.
    To answer your question, approx. 3 years MINIMUM for a low-end SSD, fair enough,
    as you will change it to a bigger/better/faster one in two years.
    Check my worklog:
  7. #17
    Jun 2009
    I have been lookin at those drives. The better ones for 32 and 64 gig or crazy expensive
  8. #18
    Sep 2009
    Reading, PA
    They are all crazy expensive. But I believe they will be worthwhile in the end. I would start with a smaller one to save the cash. You know in a few years when you're ready to upgrade, the bigger ones will be the same or less than you paid for yours. I'm not going the route of SSD quite yet simply because I already had a fresh 160gb notebook drive laying around, but I do see it as a necessary upgrade if and when the cash is around.
    The OCZ Vertex does look to be the drive to beat for price/performance, especially with free shipping and a $30 mail-in. Using this for Win7 and your FE and such should be excellent, with the other HD for storage. If I remember correctly, the case does have two trays to use for drives, but do check. This is still a cheaper route than going all out for a 60+gb drive, and gives you more storage. Still puts a less reliable drive into the mix, but people do get away with it. The 60gb drive is 220 after rebate, you could afford to replace the notebook drive once till you reached that price.
  9. #19
    Jun 2009
    weighing in the options i think i am going to start with the 32gig OCZ drive get everything installed then get another drive for it. I think that is the best way to go. I will not put music on it yet. use a usb card or something for that right now
  10. #20
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    I've been testing with the OCZ Agility 30gig and OCZ Vertex 30gig. Both are excellent drives and fast.
    I highly recommend either of them.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  1. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 08:44 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 11:28 AM
