Results 21 to 30 of 35
Thread: Buidling a new PC for my Car looking for opinions on the hardware
  1. #21
    Jun 2009
    one too the next item :-), Power sources. I was thinking of the M4 one but now thing the Pico 150. The pico 150 is a 24 atx connector and the M4 is a 20 pin. there is a significant power difference between them but both i think are more power then i need so that would be good. According to Asus i need a 400 watt power source but seems people are using alot less power to run the board.
  2. #22
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    I just checked my M4-ATX; it has a 24-pin connector. I believe the M2-ATX has a 20-pin connector. Both have 4-pin P4 CPU connectors, too.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  3. #23
    Jun 2009
    ok cool, does the M4-ATX have the ability to plug in to an adapter so that i can test it inside
  4. #24
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by brianteel View Post
    No, it has three screwposts you wire into. There's no provision for an adapter, so I made one; here's what I wrote about it in post 75 of my worklog:
    12V Adapter
    Some time back, I bought one of the Coleman thermoelectric heating/refrigeration units that keeps food hot or cold, depending on which way you run the power. I hardly used it, and then switched to the Scion xB. In this smaller vehicle, the big cooler took up half the back seat, and I went for a smaller one that fit the smaller car. I'd about decided to give the original one away, and right about then it came time to test the CarPC on 12V. That's when I remembered that the hot/cold unit came with a 120V to 12V adapter with a socket for a standard lighter plug. Very useful, and it'll run a load up to 5A. Here's the way it looks:
    Click image to enlarge.
    . . . Coleman sells the adapter alone for about $40 on their site, but they're available elsewhere for $25. Lower-amperage units are lower cost.
    Then I wired a cable that ran from my M4-ATX to a cigarette plug; that let me test it in the house, and I could also test it in the car even before I did any car wiring.
    By the way, a friend found one of those car cooler units in a thrift store -- with the 120V/12V adapter -- for $10.
  5. #25
    Jun 2009
    http://www.mini-box.com/picoPSU-150-XT-102-power-kit
    i am thinking about getting that and keep using the P2140 from carnetix.
  6. #26
    Jun 2009
    well all parts are coming in today. should have everything installed and running by the end of the night
    2009 Volkswagon Tiguan
    Custom Built Carpc, Only way to go
  7. #27
    Jun 2009
    well at this point every thing is built and running just need some time to change all the wiring in my car and i will be all set. Everything seems to work except the board is only reading 2 gb of ram and i have 4 in there.
  8. #28
    Apr 2007
    Atlanta, GA, USA
    What parts did you wind up with for your system?
  9. #29
    Jun 2009
    SSD 30G|OCZ OCZSSD2-1VTX30G RTL
    MB/CPU ASUS|AT3N7A-I ATOM330 ION RT
    MEM 1Gx2|KST 240P KHX6400D2K2/2G R
    Mini-Box M350 Mini ITX Enclosure
    picoPSU-150 DC-DC Power Supply
    i just noticed that i order the wrong ram. went to get 4gig but got 2 gig. Oh well 2 should be more than enough for what i am doing. I went with the PICO because i have the carnetix to regulate the power and then i can bring it inside if i want to and it will work with my TV. it is really fast, between 10-15 sec into get fully booted into windows from cold and Centrafuse load time is down to about 30 sec from 4 minutes with my old PC. just have to get everything running as a shell and see what happens there.
  10. #30
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    This I would really like to see. Can you make a video? What version of windows?
    You've got a great hardware list.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  1. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 09:44 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
