Results 1 to 10 of 12
Thread: Ford Falcon BF XR8 Ute - Mac Mini Install
    Apr 2007
    Hello all
    Planning a mac mini install into my Ford Falcon BF XR8 Ute:-
    Current audio system consists of:
    Alpine CDA-9887 Headunit with iPod
    Digital Designs C4a 100 wrms x 4 channel amp
    Digital Designs C2a 200 wrms x 2 channel amp (bridged to sub ~500wrms)
    Morel Supremo tweeters mounted in a pillars
    DynAudio MW160GT mid woofers mounted in doors.
    OzAudio Matrix Elite 12" subwoofer in 1.8cf sealed box.
    Stinger 0awg wiring
    Exide Orbital deep cycle battery
    Planned upgrades include:
    Mac Mini 2GHz C2D, 2GB Ram, 320GB HDD, Airport+Bluetooth
    Carnetix P2140 PSU with revised MacPac cable
    VGA-CGA converter for factory screen
    Apple mini-dvi to vga adaptor
    AI Net AUX input cable for headunit
    Dynamat bulk pack sound deadening for doors etc
    KnuKonceptz battery terminals + distribution blocks
    think thats about it
    Some photos of the audio install:
    Tweeter install, will be removing to finish paint prep and repainting over christmas
    Sub install
    Headunit (paint since touched up)
    DynAudio mids
    Performance includes:
    ZF 6sp Auto
    Pacemaker 4-1 headers
    Xforce cats
    Xforce dual 2.5" catback
    Bluepower CAI
    Custom tune
    Previous dyno it made 215rwkw, since added the CAI
    Will post more once i receive all the parts
    Apr 2007
    Mac Mini showed up today
    Carnetix P2140 w/new mac pac shipped today - should arrive monday/tuesday
    VGA - CGA adaptor some how ended up in a different state and has been on its way for 2 weeks now
    Feb 2006
    Melbourne, Australia
    Heya Mate, looking forward to this one.
    A few words of advice though: You may want to get rid of the mac-mini, they are notoriously slow to boot into the OS, whether using Mac OS X or Bootcamp with Win XP. Fast POST and boot to desktop is a must.
    Secondly, which VGA/CGA converter did you opt for - the local Ozzie one I think you're onto doesn't work well, especially on the ICC TFT display - rather get a computer that can support an ArcadeVGA graphics-card.
    Will save you lots of headaches/stress/disappointment later.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Apr 2007
    thanks for the tips
    The mac mini will be running all the time in sleep mode when not in use, if i have battery drain issues ill add another battery.
    If i decide boot times are too slow if i need to cold boot then ill install a SSD drive (iv got one in my mac pro, ~5 second boot time compared with 30+ seconds
    VGA-CGA ill see how i go, i want a mac so that rules out using the ArcadeVGA
    Ill only really be using it with front row so it does not need to be great - screen is too low res for much else and with no touch screen not many programs suit it.
    Iv had a good read over your progress, looks good.
    Feb 2006
    Problem is not the boot-time wrt drive access - it's initializing the EFI on the Mini - something that seemingly takes ages
    Apr 2007
    P2140, powermate and CGA converter arrived today.
    Just waiting on the toyota loom for the ICC video connection (unless there is another way?)
    Anyone had any luck getting the powermate to work with front row?
    If i use powermate software its all possible except being able to press the esc key for back
    If i use proxi its not very reliable in choosing between click and hold click - also the esc key on hold tends to close front row rather than go back
    and USBoverdrive only seems to have left right and click no hold click etc
    Feb 2006
    @ Luke:
    Mmm...maybe have a looky at my Project Log. You may want to check the next 2 pages too......
    If you in for it, we could make a decent deal here.
    I'm after a stock center-console.
    I have mine, with the MacMini still mounted in it, Carnetix PSU, shutdown switch for those periods where your UTE will be stopped for a week or longer, this will prevent battery drain, a 120mm quiet fan in the bottom to supply fresh air to the MacMini, and 3 sockets to provide GND/+12V/Ign to the carnetix.
    I will remove the MacMini and the Carnetix, but leave the cables, fan, switch et al...and will then want your stock concole, and the cables for your carnetix.
    Have a look at the pictures in the thread I linked,and if you're interested in this, let me know. Otherwise, no worries.
    The mac doesn't fit in the tissue-holder area, to long.
    Feb 2006
    In hindsight, probably not a good idea anyway.
    Will look for a 2nd-hand center console from one of the breaker-yards.
    Apr 2007
    thanks for the offer but i think im going to mount the mini under the drivers seat
    Dont need access to the optical drive really ever so no problem not having access.
    On friday night i ended up test fitting my mini with cga converter, im pretty happy with picture quality, its as i pretty much expected - no way you can navigate the OS but that was never going to be attempted anyway but with front row open easy to read and no junk on screen like iv seen mentioned.
    Next week seats etc will come out for rewiring etc
    Also had it run up on the dyno last week, now making 225kw post CAI
    Apr 2007
    Saturday i got a few hours on the car to Dynamat the front doors
    Door Dynamatted, service holes were left unsealed due to practicalities of retaining OEM foams but its pretty well sealed
    Door trim Dynamatted, some plastic trimmed near speaker mounts as they were touching the speaker surrounds slightly
    Overall so far 2 sheets per door of Dynamat used.
    Monday i started stripping the rest of the car down for rewiring etc
    Drivers seat is out, lots of plastic trim out, 4 channel amp out etc
    Rear cab wall is going to receive a lot of Dynamat, it sounds like a bongo drum when you just touch it
    around 1/2 sheet per rear quarter which will leave around 2 sheets for misc bits
  1. Replies: 3
    Last Post: 11-16-2012, 07:26 PM
  2. 1999 Corolla Mac Mini install
    By hutacars in forum Worklogs
    Last Post: 09-17-2010, 08:36 PM
  3. 2008 Hummer H2 Mac Mini Install
    By HARDxCOR3 in forum General MP3Car Discussion
    Last Post: 03-29-2009, 11:35 PM
  4. 2008 VW Jetta - Mac Mini Install
    By Clownzer in forum MacCar
    Last Post: 04-25-2008, 02:41 PM
  5. Mac mini VW GTi Install
    By itrends in forum Show off your project
    Last Post: 03-23-2005, 06:04 AM
