Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: 2003 Dodge RAM Truck PC - Centrafuse
    Dec 2009
    Okay, so this is my very first Auto PC. I am going to be posting progress notes, etc. I have done a lot of research before starting this project--reading hundreds of posts on mp3Car.com and other places, and believe I have a great working plan. I will be building this over the coming weeks and will post my progress.
    Summary is this:
    - 10" Touch screen computer running Centrafuse
    - Black Acrylic custom panel
    - EEEPC 701 Computer
    - DVD/Media player
    - Backup camera
    - OBDII Module
    Parts I am using:
    $30 Back up camera (E0717) http://www.eonon.com/Camera/E0717.html
    $130 10" Monitor with VGA and Composite Input (E1102) http://www.eonon.com/Stand-Alone/E1102.html
    $50 Touch Overlay 10.2 Inch Touch Screen Overlay for EEEPC 1000
    $35 GPS (BU-353) http://www.amazon.com/GlobalSat-BU-3.../dp/B000PKX2KA
    $16 Hi Gain WiFi Adapter http://www.amazon.com/Wireless-Mini-...1625614&sr=1-3
    $85 DVD Player http://cgi.ebay.com/slim-1-2-din-car...item3a561fdbbe
    $99 AM/FM/HD Radio (MCS-DIR-HDR) http://www.mo-co-so.com/Directed-DMH...cs-dir-hdr.htm
    $29 OBD (MCS-OBD-323-USB) http://www.mo-co-so.com/product-p/mcs-obd-323-usb.htm
    Dec 2009
    Removing the Dash.
    To remove the center dash unit, remove one screw located just above the "purse hook" on the passenger side (or follow this tutorial: http://www.ramforumz.com/showthread.php?t=42516), then the entire unit will pop off. Unscrew the HVAC control deck and unplug the cigarette lighter adapter, and the unit will come completely off.
    Dec 2009
    Removing the Radio Bezel
    So some use drills, which may be a cleaner method, but I simply used a soldering iron to melt the little "nubs" and allow the bezel to pop out.
    <br>
    <br>
    And this is what it looks like out of the frame:
    <br>and<br>
    Dec 2009
    Now for the replacement bezel...
    Okay, so I looked a lot at what others were doing, and I decided to do my own thing. I am making a new bezel out of black acrylic. It will be easy to cut out and shape, and it is cheap ($10 for a 18"x18" 3/16" piece). I am drawing it up in autocad, and will have a precision machine I have access to cut it out for me. Currently, this is the design:
    So once all the parts I ordered arrive, I will double check sizes and tolerances, and then execute the design. I will first run it through on a sheet of (even cheaper) plexiglass to ensure all fits well, then I will run the acrylic through.
    Dec 2009
    Updated panel layout
    Okay, so I received the parts and began to verify size and tolerance...one thing I can say is do NOT trust the printed height & width of products...verify upon arrival.
    Yellow is engraving, red is cutout.
    Dec 2009
    Monitor and Camera arrive...
    Dec 2009
    Modifications to the monitor.
    So this is a pretty slick monitor. It has a built-in VGA input, a composite (commonly referred to as "RCA") input for a DVD, etc., and a composite input for a "Back-up" camera. It has a 12V+ trigger to auto-switch to the composite input #2 while the vehicle is in reverse, then switches back once the trigger goes back to 0V.
    The bad thing about this monitor is that it has a very sleek look of edge-to-edge glass. While this is nice, this leaves no place for a touch screen overlay. Because of this, I have to recess the screen behind the acrylic and create my own bezel. There are buttons on the front of the unit (power, input, adjustments of brightness/contrast/etc.), so I will be relocating these buttons since I can't easily display them through the acrylic. I will be soldering directly onto the circuit board to relocate the buttons.
    4 screws on the back, and you can open it. Be careful to disconnect the speaker wires as you open it.
    Remove the two screws on the touch-button board...
    Then slip a screwdriver under the board to peel it up (its glued)...
    And then the board is free to solder remote wires onto.
    Dec 2009
    Testing the capacitance circuit...
    I needed to put this behind my own bezel, so I am relocating the buttons that are on the front of the monitor. To do this, I have to solder directly onto the daughter board and complete the capacitance circuit.
    After I determined what was needed, I soldered the wires onto the respective places to bring the buttons out remote.
    and
    and the put-back-together product.
    Dec 2009
    Updated Bezel Layout...
    Updated the bezel drawing to have some text and bring the monitor buttons to the front. I also changed the Dodge logo out for my own, so as to not infringe...
    Dec 2009
    Testing out the new screen on Centrafuse
    and
  1. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 09:29 PM
  2. Tahoe PC, 2003 tahoe truck computer, thks for the help.
    By DBrisson in forum Show off your project
    Last Post: 02-25-2004, 07:17 AM
