2007 Dodge Charger & Zotac Ion
This is my first attempt at a carputer. I've been lurking for over five years.
Components:
- Zotac IonITX D-E
- M2-ATX
- 4GB RAM
- 160GB HDD (Will get a SSD soon)
- DVD-RW
- 4th Gen Mo-Co-So case
- Lilliput 629 with DVI input
- Directed HDRadio
- CANUSB
Check back for pictures while assembling the system
The Mo-Co-So case. It's a really nice case. Much better than if I had attempted to build a case out of sheet metal. The bottom plate slides out.
http://www.mp3car.com/vbulletin/imag...98070a45cb.jpg
This plate includes mounting holes for the hard drive and has standoffs for the power supply and motherboard.
http://www.mp3car.com/vbulletin/imag...9808176485.jpg
Here is the M2-ATX installed. I eventually decided to reverse the direction because the cables seemed to lay better.
http://www.mp3car.com/vbulletin/imag...980c532229.jpg
As you can see, the cables didn't lay very flat. The cables weren't going to lay flat enough to fit in the case.
http://www.mp3car.com/vbulletin/imag...980d0e52f1.jpg
Once the motherboard is installed on the plate, all the front panel connectors need to be installed. The case offers a LOT of options. A Power or Reset button, 2 USB ports, stereo RCA jacks (with a wire to ground to the case),
http://www.mp3car.com/vbulletin/imag...980e2e4b0a.jpg
Here is the box fully assembled.
http://www.mp3car.com/vbulletin/imag...ad6a349582.jpg
There is a case fan that mounts on the plate that lines up with the M2-ATX and a vent in the side of the case. I found that the fan was extremely noisy. I will need to find a replacement fan if I'm going to try to use this inside as well.
The Lilliput 629 Touchscreen... Since this has a DVI input, I got a HDMI to DVI converter and use the HDMI out of the Zotac. This works great... HDMI should be a lot smaller than DVI for routing cables in the car.
http://www.mp3car.com/vbulletin/imag...ad84d095e4.jpg
I'm probably going to use RideRunner... I used to be excited about RR, but it is seeming less and less what I want. I'm getting interested in openMobile.
I have developed a plug-in for RR that emulates the OEM head unit using the canbus. In Chrysler vehicles there are 2 canbuses: One for the engine, and the other is for interior devices. That second bus has the head unit, Sirius satellite receiver, and steering wheel controls among others. The plug-in can control the Sirius receiver, listen to the steering wheel controls, and display information in the information cluster in the dash (EVIC). The hardware used is the CANUSB. I tied into the canbus using a hands free adapter that has both ends of the head unit harness (while the HU is still there)
That is it so far. I still need to figure out how it will go into the car...
Ryan
