Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: Project Double Vision - 2003 Honda CR-V Carpc
    Newbie BCS60Z's Avatar
    Sep 2009
    Sydney Australia
    After lusting those CAR PC installs - I told myself I MUST have one in my 2003 Honda CR-V!
    So, here goes my first carputer installation.
    Please be gentle as I may not have the skills on what other's have achieve on their project.
    Removing the lower cubby hole
    MDF frame to house the touchscreen
    Sep 2009
    Sydney Australia
    Dremeling and light sanding
    The Lilliput 7 inch toucsreen
    Test fitting - looking good in my opinion and getting excited
    Sep 2009
    Sydney Australia
    Test fitting MDF frame to the cubby hole
    touchscreen mounted on dash
    another shot
    Sep 2009
    Sydney Australia
    Spray painted the mdf frame
    another shot
    Sorry for the poor quality of this photo --- over-exposure!
    Sep 2009
    Sydney Australia
    I'm now sourcing a suitable fascia to cover the MDF and the gap between the aircon controls
    Or I could try fabricating from an aluminium sheet.....whatever easier to work on.
    Low Bitrate SoloconDeus's Avatar
    Sep 2007
    hehe I like it ,but I may be partial to the SUV you are installing it into.
    My new install
    D945GCLF2, M350 case,Xenarc 700 tsv,m-4 ATX
    Visteon HD radio w/mitches cable, BU-353
    2 Punch 150 amps, 1 Kicker ZX 400.1 watt
    4 Boston Acoustic Speakers,2 Pioneer 10 subs
    Sep 2009
    Sydney Australia
    Quote Originally Posted by SoloconDeus View Post
    Cool!
    Not many around here!
    Sep 2009
    Sydney Australia
    I tried to cover the MDF frame the second time with PVC vinyl
    a bit better looking now than just spray painting it - still not perfect though.
    I've got to move -on and start with the carpc and other stuff.
    First I need to remove the center cup holder/table - you have to remove the seat to gain access on the bolts
    I forgot to take photos of the seat removal - should be straightforward and nothing to it
    Just make sure you disconnect the battery first before disconnecting the airbag sensor under the seat and wait a few minutes.
    Once the cup holder/table removed - lift the carpet and locate the holes on the subframe - see photos
    I've inserted a 10mm bolts to check diameter
    The Center cupholder taken-out from the CR-V
    Sep 2009
    Sydney Australia
    Next up, I cut a piece of MDF in-between the front seats
    This will house the pc and will gain storage and additional cup/drink holder
    Sep 2009
    Sydney Australia
    The Carputer by ZOTAC
    ZOTAC IONITX-D-E Intel Atom Dual Core M350 Car PC System
    This barebone Car PC kit includes the Zotac IONITX-D-E Fanless Mini-ITX motherboard (With NVIDIA ION chipset and Intel Atom N330 1.6GHz dual-core CPU), 2GB of DDR2 memory and a M3-ATX automotive power suppy all enclosed within the M350 Universal Mini-ITX enclosure.
    This kit comes fully assembled and tested.
    The kit includes:
    1 x Zotac IONITX-D-E Fanless Mini-ITX Motherboard (60mm CPU fan included and installed)
    1 x 2GB 800MHz DDR2 Memory
    1 x M350 Universal Mini-ITX Enclosure with wall-mount brackets included
    1 x M3-ATX 125W DC-DC ATX Mini Automotive Power Supply
    1 x All product manuals and documentation and driver CDROM
    Zotac IONITX-D-E Mini-ITX Motherboard
    Experience fluid and vivid high-definition video playback with the ultra-compact ZOTAC ION platform. The Mini-ITX form factor ZOTAC ION combines a high-performance NVIDIA ION graphics processor with a power-efficient Intel Atom processor for the ultimate eco-friendly platform that has no troubles handling regular web browsing, e-mail, productivity and HD video playback tasks.
    NVIDIA PureVideo HD technology harnesses the power of the ION's 16 high-speed stream processors for high-definition Blu-ray playback capabilities. PureVideo HD technology decodes HD video formats and enhances standard-definition videos with the ION GPU for flawless HD and superior SD video playback. HDMI, DVI-D and VGA output for a host of different display options.
    This motherboard includes an internal 802.11n (up to 144Mbps) MiniPCI-E WiFi Adapter (installed) with external antenna.
    Lastly, with longer-than-standard warranty periods, (Lifetime for USA, Mexico, Canada, Latin America), enjoy peace of mind in the longevity of your system.
    The M350 Universal Mini-ITX enclosure features one of the smallest footprints to date taking Mini-ITX kit miniaturization to a whole new level. Please note that with the 60mm fan installed on the Zotac motherboard, only 1 x 2.5" storage drive can be installed inside this enclosure. Wall-mount brackets are included with this kit for easy car cabin or trunk installation.
    The M350 enclosure also features a unique hideaway compartment which houses a special power switch and 2 x USB inputs in a unique layout. The power switch has two functions not found on other enclosures: (1) Switch disable with jumper (to prevent accidental or unwanted power-offs) and (2) Auto power-on after power failure (for ALWAYS ON status) with jumper. The layout of the USB inputs allows you to "hide" 2 USB devices (such as Wi-Fi adapters or Flash drives for booting) behind the front panel.
    You can find more in-depth information on the revolutionary M350 Universal Mini-ITX enclosure here: http://mitxpc.com/proddetail.asp?prod=M350CASE
    Car PC Connections
    Video Output
    Use the VGA output for an analog connection (use a VGA to composite adpater for your composite video display device [RCA]) or you can alternatively use the HDMI or DVI outputs for digital image output.
    Audio Output
    If you have an audio receiver with AUX-IN you may use the rear 3.5mm audio jack and a standard stereo audio cable and make the connection for audio in that matter (just like plugging in an iPOD or other MP3 Player). Also, if you are using a subwoofer and external amps and would like to protect your speakers from the "thump" which comes when the Car PC is turned on from an off position, you can utilize the anti-thump function on the M3-ATX power supply to protect your audio equipment.
    Network Connectivity
    With the built-in Wi-Fi adapter, you can easily connect to a wireless network without any need for additional adapters. The built-in Wi-Fi adapter supports 802.11b/g/n technologies (up to 144Mbps).
    Motherboard Specifications: Manufacturer P/N: IONITX-D-E
    Processor: Integrated Intel Atom N330 Dual-core @ 1.60GHz
    533MHz FSB
    Chipset: NVIDIA ION
    (MCP7A-ION)
    L2 Cache: 512KB
    Memory: 2 x DDR2 667/800MHz Memory DIMM Slots
    4GB Max Capacity
    Graphics Interface: NVIDIA GeForce 9400M processor
    Graphics engine clock: 450MHz
    Shader clock: 1100MHz
    16 Stream Processors
    Microsoft DirectX 10
    OpenGL 2.1
    NVIDIA PureVideo HD Support
    NVIDIA CUDA ready
    NVIDIA PhysX ready
    Serial ATA: 3 x SATA 3.0Gbps Ports
    1 x eSATA 3.0Gbps Port
    SATA RAID 0, 1, 0+1
    Expansion Slot: 1 x Mini PCI-E (occupied by WiFi adapter)
    Back Panel I/O: 1 x PS/2
    1 x HDMI (w/ 7.1 Audio)
    2 x Digital S/PDIF outputs (1 optical, 1 coaxial)
    1 x VGA Connector
    1 x DVI Connector
    1 x RJ45 10/100/1000 Mbits/sec (Gigabit LAN)
    4 x USB 2.0 Ports
    Audio: Line-in, Line-out, Microphone
    Onboard I/O Pin-headers: 4 x USB 2.0
    1 x Audio I/O
    1 x COM
    1 x Fan Header
    Form Factor: Mini ITX 170mm x 170mm
    Motherboard Warranty: 5-Year Warranty (Europe, Middle East, APAC)
    Extended Warranty (India)
    Lifetime Warranty (USA, Mexico, Canada, Latin America)
    *Requires immediate registration @ www.zotac.com
    M350 Universal Mini-ITX Enclosure:
    Model No: M350
    Case Dimensions: Size: 192 x 210 x 62mm
    Volume: 2.5L
    HDD Bay: 1 x 2.5" HDD
    1 x HDD Bracket included
    Front Panel: 2 x USB 2.0 (Hidden)
    2GB DDR2 800MHz SODIMM Memory:
    - 2GB Capacity
    - DDR2-800MHz
    - 200-Pin SODIMM DDR2
    M3-ATX Features:
    - Plug-In Smart Automotive DC-DC PSU
    - 125 Watts (150watt peak)
    - 20pin ATX, 6-24V wide input range
    - Programmable timing settings
    - Intelligent shutdown controller
    - ON/OFF motherboard control
    - Survives vehicle engine cranks
    - Battery deep discharge prevention
    - "Anti-Thump" Amplifier remote control
    - < 0.5mA standby current
    Not high-end but good-enough for my needs!
    Everthing's on-board - meaning less cablings
  1. Lotus Elise CarPc Project
    By mrluke in forum Worklogs
    Last Post: 01-02-2010, 10:03 AM
  2. 2003 Lexus SC430 Convertible CarPC
    By Habious in forum Show off your project
    Last Post: 08-18-2009, 08:30 PM
  3. Project Red Alert: 1994 Customized Camaro CarPC v3
    By meissenation in forum Show off your project
    Last Post: 07-15-2008, 05:23 AM
  4. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 05:46 PM
  5. Hello!! CarPC project pics inside.
    By bobbykokinos in forum Newbie
    Last Post: 03-29-2004, 11:44 AM
