Results 1 to 10 of 11
Thread: 97 impreza. finally got install started
    Mar 2009
    finally got round to starting my impreza install. consisted of running power
    wires and rca cables throught the car.
    I started taking some pictures as i went but during the process i manged to hurt my
    back quite badly and as the car was stripped down at work i had to rebuild the car in
    absolute agony so the picture taking went to the wayside a bit.
    Anyway here is what i did take.
    the start of the strip. front seats out
    rear seats out
    carpets gone
    inteercooler removed to route power wire
    fuse holder mounted on battery clamp
    all wire routed carpets back in
    I was hoping to get the amp and sub in but with my back going i was lucky to get the
    interior back in.
    Jan 2010
    Good start man. Just curious, what kind of setup are you planning?
    Mar 2009
    Thanks.
    for now it's going to be very basic.
    alpine head unit
    ripspeed 13cm co ax's in the front
    standard rear speakers
    mutant 12" sub powered by a alpine mrv t420
    When its finished
    carputer up front running thinks
    alpine type r 17cm cmponents in custom front door builds
    powered by alpine mrv t420
    alpine type s 17cm co ax's in rear
    not sure of there power source yet
    alpine type r 12" sub in custom enclosure
    powered by a bridged alpine mrv t420
    Aug 2008
    London, UK
    hey
    do you have all the speakers?
    wouldnt it be easier to go straight for the alpine speakers now(save the double spending)
    Carpc plan=========90% -Never going to be finished!
    Carpc parts==5% -Computer died
    Carpc install==5% -Need to install computer
    Carpc worklog-0% -Need to start that soon
    Mar 2009
    Quote Originally Posted by da_glu View Post
    hey
    i already have the ripspeed speakers. the alpines and the ripspeed ones the reason i'm not using the alpine compnents yet is they dont fit. so door builds will be made to accomodate them but i want the boot finishing first.
    Mar 2009
    I got a bit more done on the boot yesterday.
    the boot floor pieces together
    hindged flap for access to spare wheel
    Due to the boot floor been so uneven i have decided to put a wooden frame under it which i will shape to the floor
    It's made up of 4 parts the 2 sides a centre peice and the flap, i put a slot in the side of the centre peice and the side peices and inserted some plastic guides in the side peices
    this so the sides can be put in place then the centre slides in between them locking every thing together.
    Mar 2009
    Finally got the frame in and the new floor fitted and secured.
    the bare boot.
    the frame in place
    the frame mounted on the bottom of the floor
    my plan from the start was not screw or permanently fasten any of this build to the car it's self. the idea been the whole thing can be removed without any trace of it being there.
    so i taped the outline of the frame onto the floor then applied a bead of sealer to the bottom of the frame to help it sit nice and flush on the very uneven floor. the sealer sits on the tape and not the boot floor.
    and finally the whole lot fitted
    there is plenty of access to the spare wheel
    next step mocking up the sub box and amp rack
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Thread moved to worklog section. Looking good so far.
    Tidder
    Try RevFE
    Mar 2009
    ok sorry about that i didnt know how to post it to the work log section.
    Mar 2009
    well spent a lot of time over the last week working on the sub box not that it looks like a lot of work has gone into it but it has.
    here is the area taped off and foil being applied
    first few layers of fiber glass and mdf base and end panel
    the mould removed. it was tight to get out
    A few more layers of fiber glass a top and the other end panel. cut out in the top panel for the boot hindge
    the cut out for the boot hindge has now been boxed in. i foun to tiny leaks when i was checking the box volume so it needs a little bit of sealing but it's just about done.
    a few pictures of the sub box. hole will be cut when i get the sub
    the start of a homemade slide actuator to operate the boot floor
  1. 97 LT Blazer - Xbox install
    By NizZ8 in forum Show off your project
    Last Post: 10-26-2011, 12:49 AM
  2. I'm back, finally gettting started on 3.0!
    By Arby in forum General MP3Car Discussion
    Last Post: 06-18-2007, 08:17 PM
  3. Finally my carputer in 97 Subaru Outback Sport
    By ryuandwings in forum Show off your project
    Last Post: 05-17-2004, 09:25 AM
  4. Lilliput install in and Impreza, Lilliput issues
    By SubPuter in forum LCD/Display
    Last Post: 04-19-2004, 09:56 PM
  5. Audi A4 install - LCD finally customed into dash
    By brrman in forum Show off your project
    Last Post: 10-07-2003, 11:47 AM
