Results 1 to 7 of 7
Thread: my P38 rangie
    Nov 2009
    uk
    my P38 rangie
    Here is the new car, and latest project for carputer. I just got the last car installed, then decided to sell, the car. Then bought this, i gotta do some important mechanical bits first though (head gaskets and rear diff).
    Going to make book enclosure with mdf, for the subs, amps, and computer, good size touchscreen up front, uprated speakers in doors etc.
    carputer spec's are
    Intel D945GCLF2 Dual Core 1.6 Atom Motherboard
    M2-ATX
    Transcend 2gb DDR2 667 RAM
    160GB Seagate Sata Hard Drive
    Voom2PC Enclosure
    Royal-Tec RGM-2000 sat nav reciever
    CarPC JoyCon - Steering wheel remote controller USB converter (i have to change the steering wheel, as mine dont have the buttons as standard)
    other hardware:-
    software:-
    tinyXP
    freeice
    Nov 2009
    uk
    screen case
    original rangie consol
    trial fitting
    back seats removed
    screen in consol
    steering spiral modified for Joycon
    multi-function steering wheel
    sub enclosures
    dash at the moment
    [/QUOTE]
    Nov 2009
    uk
    screen case
    trial fitting
    back seats removed
    screen in consol
    sub enclosures
    dash at the moment
    Nov 2009
    uk
    stripped for usb, and vga to consol
    centre consol and seat removed
    also got the power leads in, to the back, waiting on distribution block to come, and been messing with new screen consol.....getting there, slowly, also bought some new speakers for the doors, so gotta get them in now aswell.
    Nov 2009
    uk
    got the screen consol done, also done some carpeting of the sub enclosures, and got the power leads from front to back sorted, also changed the standard speakers in the o/s/f, and o/s/r doors, no point on taking photo's of them, not much to see.
    here's a pic of the screen in the car, and i've even refitted some switches, gonna put some usb extension leads in the blank's, and possibly a reset switch for the carputer
    Nov 2009
    uk
    got the multi function steering wheel fitted, and temporary carpet fitted to rear sub enclosures, and subs in. The MDF you can see in the pictures will be behind the next stage of the build. If you look closely at the door, my vibe tweeter can be seen.
    and here they are with the factory parcel shelf fitted
    Here is the latest with the screen console, i have added 2 usb slots, for memory stick etc. and 2 buttons, dont know what for yet, but i should think 1 will be for a reset.
    Nov 2009
    uk
    i was wanting to get the dash , and screen all mounted securely, and cables running from screen to computer, and decided it would look good with blue led's in all the switches, and dash, such a simple thought, such a pain to do!!!
    here's the dash (i know i got an air bag fault), all the warning lights are also blue
    switches, fog light, air suspension, etc
    electric window pack, camera makes it dazzle, not that bad in car, i had to drill the holes behind the arrows, etc. for 12 seperate 3mm led's, as with just 1 inplace of the original bulb looked dull
    map reading lights
    courtesy light on
    rear courtesy lights
    view from outside the car from the rear
    light in door shining down onto pavement
    heater controls, had to unsolder the orange led's, and solder in blue ones, they measure 3.2mm x 2mm
    blue lights in heater controls again, and switches ablove (air suspension, fog light etc) anyone see why my airbag light is on????
  1. my P38 rangie
    By firestorm in forum Show off your project
    Last Post: 02-11-2010, 11:45 AM
  2. Range Rover P38 - my first attempt
    By cyberlancer in forum Show off your project
    Last Post: 07-03-2006, 03:34 PM
