Page 7 of 25 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 243
Thread: Project λ (Lambda) AKA Tech Van: 1994 Chevrolet G20 Conversion Van/56K WARNING!
  1. #61
    FLAC freeflashstuff's Avatar
    May 2008
    Socorro, New Mexico, United States
    Quote Originally Posted by ZX1Cruizer View Post
    OK............. Im a gamer and you logo looks familiar. Is that the Half-Life Logo? Anyways looks nice. As soon as I saw the roof, I know those were solor panels. I would love to have a house like that.
    Yes, it is a (slightly modified) Half-Life logo.
    I want to get everything done before I finalize it all with the stickers. I am trying to calculate power consumption right now. That was one of the bigger problems I had in the Turtle. I am about to take the amp to the UPS drop and get it sent back. Fingers crossed!
    I have bad luck with vehicles...
  2. #62
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    Wow, another van install. It does my heart good to see all these van installations, as I myself am doing one. I shall definitely watch this thread.
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
  3. #63
    May 2008
    Ya, but you have it slightly easier than I do. I am going to have to modify my glovebox/ashtray/top half of engine cover to fit my screen into. Power and wiring are much simpler this time around compared to my last project (Turtle), I'm afraid... All I have to do is pull on the section of carpet I wanna mess with, and I can run wires underneath it.
  4. #64
    Feb 2006
    I used to have a 1993 G20 that I intended to put a carputer in. A car audio shop recommended that I put a 15 inch monitor where the center console is, where you plan to put the EBY-701.
  5. #65
    May 2008
    Quote Originally Posted by stonestatue View Post
    Dang! Typed this out at 10PM my time last night, shut down and forgot to click submit...
    (Image credit to Andrew Hussie @ mspaintadventures.com. It's a good webcomic.)
    Too bad I can't really afford a 15 inch. I'm wishing I hadn't sold my Litton MobileVU 10.4 inch right about now, though...
    It seems as though I made a mistake in judgement. I assumed (you know what they say about assuming...) that the fuel gauge was broken because it stayed on full. I never bothered to test that theory until today when I installed a new fuel gauge. It too went to the full mark and stayed there. I commenced with the
    and almost threw the toolbox through the (closed) window.
    Needless to say, I figured out I needed to calm down really fast. Once I calmed down, I came inside to check the price of a new sender, realizing I will have to drop the tank to replace it...
  6. #66
    May 2008
    Screen mounting method
    Should I fiberglass a holder for my EBY701, or should I take the headrest shroud ZX1 sent me
    and cut a hole in this piece (which I've already started taping off, just in case...)
    to fit the shroud and take the easy(ier) was out? It would be easier in that I would only have to fill in a gap
    to make it look decent.
    What do you all think?
  7. #67
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I think you should build a bezel that slides around the screen. Like similar to mine.
    As you can see the EBY701 is intacked. Do something similar.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  8. #68
    May 2008
    I believe you meant "intact"?
    So something like I had for the Turtle, then? The only issue with that is I would need a way to angle it toward me (the driver) so I won't have to lean over toward the center to see the screen. That's what I was going to use the headrest shroud you sent me for. I was just gonna fiberglass around that and make it look good. If I had my Photoshop (or GIMP, if you prefer... I use both depending on what PC I'm using when I need it.), I would do a quick mock-up and upload it, but I'll have to do that later.
    I'm going to Los Alamos at 1PM my time for the Supercomputing Challenge final expo-thingy (whatever they call it...). I won't be back until late Tuesday night. I'll have Internet at the hotel (*knocks on wood*) and I'll try to keep up with everything from there.
  9. #69
    Jul 2007
    Miami
    Quote Originally Posted by freeflashstuff View Post
    I was tired when i answered you, lol...... Well angling it is easy, just make a bracket that has a wedge shape on one end. i may have to photoshop it because its hard to explain. Then i guess do the fiberglass on and around that.
    Have fun in LA!
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  10. #70
    Raw Wave
    Nov 2009
    Pity about the fuel gauge.
    First step is for an FSD (full scale defelection - aka Full) is to disconnect the sender preferably near the sender to negate wiring faults (shorts etc).
    For non-indicating or faulty gauges, the oldskool method was to ground the sender end. That would normally send gauges hi (FSD) though in rare instances GND could mean a low/zero value/deflection.
    HOWEVER, with modern cars with more sophisticated electronics, that method could damage the electronics. Although that started circa 1980, it didn't effect most vehicles until much later. Some pro wrote recently that "ground-short testing" ceased in the 1990s.
    But in your case, I reckon disconnecting the sender would have released the gauge from FSD.
    Pity I've been distracted with aux batteries etc.....
  1. bluetooth woes
    By gentoocar in forum Linux
    Last Post: 12-12-2009, 03:05 PM
  2. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 08:58 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 08:56 PM
  5. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
