Results 1 to 4 of 4
Thread: '06 Mini Cooper S Computer Install
    Jun 2010
    My project is finally to the stage where I can post up a few pictures. I'm running:
    HP Mini 210
    Lilliput 7"
    7 port Hub
    Soundblaster audio
    Windows 7 professional
    Soon to come
    wap54g with dd-wrt
    Just starting to gut the interior
    Screen Mounted in dash
    Switches modified to fit new position in dash
    Crossover for one of the Diamonds
    Boot cleaned, gutted, and ready for PC
    dynamat under rear seat
    Flip up access to the battery and wiring
    Computer Installed in place
    Sub floor in place looks just like stock
    Fan diagram
    First Fan controller mockup
    Finished fan controller
    Console getting first coat of texture
    Custom CAI with stainless steel box, and aluminum adapters
    CAI installed
    Jun 2010
    nice work
    Low Bitrate chrislamb's Avatar
    Nov 2007
    Warwick, UK
    Any updates?
    Jun 2010
    Well I have been using it as is and taking notes about what I want to change. I put some DPDT switches under the drivers seat to control what devices get constant battery power and what ones are switched with the key. Most things stay switched with the key but if I want to have everything on while the car is off I can or if I'd like to leave it all up while I remote into it from my home computer I can do that also.
    The problem with the switches is that once and a while I bump one of the switches changing it's position. It most likely happens when entering or exiting the car so I can avoid it by being more careful but want it to be idiot proof so I'm changing my switch box a bit. I'll grab pictures of it.
    Next I'm changing pcs. I'm going to pull the HP Mini because it's too nice to cut up. I've got an old dell laptop that I'm going to completely tear apart. With out all the plastic I can get better air flow and have room for larger heat sinks. I'll extend the wires to the power switch up to the front of the car. I'll remove the lid switch. While I'm in there I will probably extend the wires to the keyboard and put it in the glove box or somewhere up there.
    I'm trying to come up with a good place to put the original screen off the laptop in case I need it. Right now I'm leaning toward making it flip down from the head liner. I like seeing new ideas and adding things to it so I think it will never be completely finished.
  1. Replies: 3
    Last Post: 11-16-2012, 07:26 PM
  2. Replies: 31
    Last Post: 05-18-2012, 09:19 PM
  3. 2007 Mini Cooper Project
    By lacning74 in forum Worklogs
    Last Post: 11-29-2009, 06:30 PM
  4. 2008 Hummer H2 Mac Mini Install
    By HARDxCOR3 in forum General MP3Car Discussion
    Last Post: 03-29-2009, 11:35 PM
  5. 1999 Nissan Silvia Mac mini Install
    By Dilmahay in forum Worklogs
    Last Post: 05-16-2008, 10:27 AM
