7 Attachment(s)
Finally Past The F\G stage
Only got a few hours this weekend unfortunately to play in the garage but here is the progress:
Glassed in the switch box.... :
Attachment 68479
and finished sanding the glass:
Attachment 68481
Got everything out to start filling:
Attachment 68480
Got a quick coat on the rear tray, took the cheese grater to it, added a little bit more filler and gave it a quick sand. That was it. A little more work on this one then the main console which is in much better shape surface wise so it should go fairly quickly.
Attachment 68482
One evening this past week I made the decision the amps are not going to hang on the side of the sub box as I will not be using the 2 Infinity amps currently in play. Their replacements are quite different. So instead I decided to take the space that was originally allocated for them and cut in some windows to show the sub working. I little bit "tuner-ish", I know, but I will try to finish it off tastefully.
Attachment 68483
I recessed the window into the MDF from the inside.
Attachment 68484
When I was done, I just threw some LED's into it loose to get some ideas.
Attachment 68485
I'm not sure what will get done this week coming up, it's going to be a very busy week & weekend.
