Page 5 of 22 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 220
Thread: 2007 Ford F350 Crew Cab Build
  1. #41
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I had just over 1/2 a gallon of resin left and was not comfortable that the console was 100% solid enough to with stand my day to day abuse. So I added 2 more layers of 1.5oz chop mat. At the same time I used it to do some leveling of the surfaces and improved on my corners. I think I will have an easier time now blocking it out.
    So that's 8 layers and almost 3 gallons of resin. Next I need to test fit it into the truck again and figure out what alterations need to happen from there. It will likely be a couple of weeks before I can get back to it.
    Here's a couple of pics (I was told posts without pics are worthless...)
  2. #42
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Looking forward to see it finished. Very nice..
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #43
    Nov 2009
    Thunder Bay, Ontario, Canada
    philg, a little off topic, but where in ontario are you from? By the way, if i had the balls I'd do the same with my truck. I guess i'd also need to free up alot more time!
  4. #44
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by thunderbay View Post
    I'm in Peterborough (NE of Toronto). Yes this definitely is a time eater but I'm not one to sit in front of the TV much, I always have to be doing something so I guess this is it! I wish I was stronger on the software side of this hobby, I love some of the stuff I see created like CF skins, plugins etc. but have no clue. I guess I should find someone to trade of some of my fabrication and install time for their programming time. lol.
  5. #45
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by treetop777 View Post
    Thanks Treetop!
    It's moving a little slowweer right now with the below freezing temps I got lucky in November though, I scored a few extra "warm" days that are a bonus this time of the year in my area!
  6. #46
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Newpctech, thank you.
    The head unit you see is the controller for the Alpine processor, not a traditional head unit. I don't think I could actually ditch it because it controls all of the sound shaping for the processor.
    There is a PCB being developed by a member here on MP3 that will control the processor from the PC but from what I have read, only basic functions like vol, bal, source select, etc will be available.
    So I could bury it under the seat or something but I think I will leave it exposed and accessible. I have a brand new one with a blue display to use for the final install in the console so it should look pretty good when I am done.
  7. #47
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Test Fitting The Console
    Finally, I had an opportunity to test fit the console. After knocking down the exterior of it a bit first and then a bit of minor sanding inside to make the sub box slide in, it fits.
    I will try to locate a reverse cove molding to connect it to the dash. Not a bad fit though considering no body fill has been used yet.
    That is one long console.
    And, as planned the change tray/ drink holder still opens.
    So now I need to plan out the installation of all of the accessories before cutting into it then start to add tabs, mounts etc to hold each piece. I also have to start planning how to detail the amp mount location.
    I think I smell some more resin coming soon...
  8. #48
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Nice fit, good job!
  9. #49
    Sep 2006
    War-Town, GA.
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  10. #50
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Thanks guys, I should have another update by tonight or tommorrow.
  1. 2005 Ford F350, First timer!
    By jdc753 in forum Worklogs
    Last Post: 12-11-2012, 02:33 PM
  2. XR-Lane's NF Ford Fairlane Build
    By XRLane in forum Worklogs
    Last Post: 09-08-2009, 06:19 PM
  3. Newbie Ford Explorer 12.1" center conole build.
    By PandaBearBG in forum Fabrication
    Last Post: 08-01-2008, 09:00 AM
  4. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  5. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
