Page 9 of 22 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 220
Thread: 2007 Ford F350 Crew Cab Build
  1. #81
    Constant Bitrate kolton5543's Avatar
    Apr 2011
    Safford Arizona
    Very creative. I like the idea.
    Quote Originally Posted by Lincolnman View Post
    Your English is fine, don't apologize. You're doing better than most Americans.
  2. #82
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Thanks Kolton, I can't say I was the first to come up with it, but at least I "did it my way" in how I installed them.
  3. #83
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by treetop777 View Post
    Is that what they are called really! Looks good!
    Would I lie to you? Really? :
    http://wiki.answers.com/Q/What_are_p...s_on_a_car_for
    That looks like a Lincoln in your avitar, you must know what puddle lights if you have a Lincoln. The factory worries about their Lincoln owners not stepping in puddles and installs some under the door mirrors, don't they? I thought it was just us low-life truck owners that they figure are wearing boots all the time that don't matter
  4. #84
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by PhilG View Post
    LOL! Indeed! I have yet to step in any puddle of dog sh**, gum, or mud thanks to Lincoln looking out for it's owmers by installing "puddle" lights under the outside rear-view mirror. Lincoln call them "courtesy" lights though. LOL! I learned something new today. BTW - I wouldn't call an F350 (or it's owner) "ordinary" - and after this install it may be the biggest and baddest! Keep it up.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  5. #85
    Jun 2011
    Dublin, Ireland
    Splendid job!
    Your "puddle lights" just gave me an idea too! ;-)
  6. #86
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Hi, just had a read of your worklog from start to finish, love the truck, envious of the room you have to play with. Love the back seat mods and installation and looking forward to seeing that console finished when you get the time. I "still" haven’t finished my centre dash panel, one day I guess.
    I see you’re trying to keep everything neat and reliable amid the constant additions and mods as the build progresses, I find/found this time consuming and sometimes frustrating but worth it in the end.
    Cheers.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
  7. #87
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Thanks for all the positive comments, it does help to motivate.
    I am going to make the time to take the console out of the truck, cut down, prep'd and painted as soon as things warm up consistently. We are above freezing all this week but it's hit and miss this time of year. I think I can make it happen in March or April at the lastest. In the mean time, I will have to update W8 DE to Beta in Feb when it is released. I want to replace the front audio stage and add the B-Quiet. The engine warranty will be up in April so I may look at some engine mods, we'll see.
    Also I have switched to Ride Runner using the Elite skin from CF. I absolutely love it, I finally have the playlist structure that I have been wanting since day 1, all videos play properly without a major nose bleed having to adding ffdshow, MKV's working ocassionally etc. The web browser is easy to use. The one BIG loss for me was that GMPC will not embed properly on my wide screen with Elite but due to everything else working so well, I am will to use it just the way it is. I have OBD, and the new weather plugin to get working next. I also need to send out some donations this week now that I am comfortable that I will be staying with RR. If CF ever produces a product in the future that fits my needs, I would have no objection to trying it again.
    Cheers!
  8. #88
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Improving WiFi
    Been too long for an update, but life keeps getting in the way. I decided to try to improve my WiFi reception in the hopes of ditching the data stick that costs $30 month. I ordered an Alpha Network long range WiFi range extender ( http://www.alfa.com.tw/in/front/bin/home.phtml )
    Here is how I did it:
    The broken off stub of the factory AM/FM antenna:
    I removed the valance to reveal the radio antenna mounting stub:
    I removed the 3 screws for the stub and unplugged it, then cutting the plug off and taping the wire for the new antenna to the end of it to pull through to the inside of the cab:
    Here is the original orange antenna wire inside:
    Here is the new wire pulled through in it's place:
    I then screwed the antenna mast on to the stub and replaced the valance panel.
    The mast has a 90 degree elbow that allows it to bend without alot of force. I really didn't think it would stand up to the wind so I made a plastic collar that slipped over the joint to reinforce it. I then sealed the top of the collar with black silicone.
    The last thing to do was to connect the range extender on the inside and run the USB cable to the PC:
    Thats it for the install. Next will be testing it to see if it is really as good as the reviews I read about it. I will post when I have those answers!
    Thanks for reading!
  9. #89
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Small Update
    Just a quick overdue update. The Alpha Network range adapter is amazing. I don't know what other word to use. Just driving by a location that has WiFi that I have logged into before will cause the browser to pop up and log in. This is while driving by at 70mph on a 4 lane divided highway. Crazy range on this thing.
    The other addition this summer was I finally added a camera to the rear. It works good, it wasn't expensive (40 or 50 bucks) but does help when backing up to trailers. I can't say that I am comfortable backing the truck up using it though, I still use my mirrors.
  10. #90
    Sep 2006
    War-Town, GA.
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  1. 2005 Ford F350, First timer!
    By jdc753 in forum Worklogs
    Last Post: 12-11-2012, 02:33 PM
  2. XR-Lane's NF Ford Fairlane Build
    By XRLane in forum Worklogs
    Last Post: 09-08-2009, 06:19 PM
  3. Newbie Ford Explorer 12.1" center conole build.
    By PandaBearBG in forum Fabrication
    Last Post: 08-01-2008, 09:00 AM
  4. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  5. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
