Page 1 of 22 1234567891011 ... LastLast
Results 1 to 10 of 220
Thread: 2007 Ford F350 Crew Cab Build
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    This build will include a full featured Car PC, running CF 3.1 w/nav and a moderate audio system with some interior modifications.
    The Vehicle:
    Most of the Hardware:
    The Computer Hardware list
    HP 6710b laptop with bluetooth
    HiPower B090A3 12V power adapter
    Lilliput 889GL 8" Widescreen touch
    Carnetix P1900 Power Supply + two 5v 15w DC-DC reg (one internal, one external)
    Nextech 4 port Power Hubs (2 of these)
    MP3car 4 port Non Powered Hub ( ability to be powered but no adapter included)
    OBDLink OBD reader
    MJ Gadget Sirius Tuner Adapter
    Sirius SC-C1 Sat Tuner Replaced on 9-12-11 with the home tuner version SC_H1
    BU-353 GPS Antenna
    MP3car Backup Camera
    Sound Blaster X-FI USB sound card
    Icarus ECBM-T2 Toslink Optical Cable
    Griffin Powermate Volume Control
    Andrea Array 2S Microphone w/ sound card
    The Audio hardware List:
    Infinity 7541a 4 channel amplifier
    Infinity 611a Mono Block Amplifier
    Alpine PXA-H700 Sound Processor with RUX-C701 Controller
    Infinity 6.5" Component Speakers up front
    Infinity 6.5" 2 way Speakers in the Rear
    RD Sonance 12" Dual 4ohn VC Subwoofer
    Alpine SBS-0715 Centre Channel Speaker w/ it's own amplifier I am still undecided on whether to add the centre channel, the phanton mode works well on the processor
    DEI 528T Pulse Timer Relay (delay start for the amps) Was not required, there is zero startup thump in this sytem
    Stinger 1 Farad Cap (I still have not decided whether to include this in the build) I have decided against using this. There is no conclusive results showing a Cap will improve anything
    The Plan:
    Carnetix 1900 ----> Lilliput Monitor and auto Adapter / HP Laptop
    HP Laptop -----> X-fi sound card -----> optically connected to Alpine PXA-H700/ RUX-701 ------> 7541a 4ch to 4 infinity speakers/ passthrough signal to Alpine Centre channel and 611a Mono amp to RD Sub.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Project segments:
    1) Install Monitor in Dash Bezel
    2) Power complete sytem
    3) Install system temporarily to Test
    4) Complete new Centre console to house most of the carputer including hubs, Carnetix Supply and Subwoofer plus a multitude of other items not related to the carputer.
    5) Build a behind-rear-seat amp rack for 2 Infinity amps & Alpine Processor Large amps will be mounted to the side of the console, small amps will be hidden
    6) Install centre channel amp and speaker in dash. Undecided if this will get installed
    7) Modify 4 main speaker locations.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I selected a monitor that would fit the best in the dbl DIN opening. I made paper cutouts based on published dimensions before ordering and selected the Lilliput 889GL 8" widescreen based on best fit.
    It paid off, the monitor fit with very little modification.
    I also found a complete spare Bezel from Craigslist. Having the spare bezel took alot of the stress out of cutting it up.
    Here is the dash Bezel in stock form:
    The back side:
    The top had to be trimmed by about 1/2". The rest fit perfect.
    The monitor was installed using small plastic clips mounted to a screw for the A/C vents on each side at the bottom and a piece of electrical cord casing was stretched across the top and secured under one of the vent screws on each side as well.
    Here it is installed and bench tested:
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Have you considered hiding the lilliput buttons behind the dash panel (or strip the monitor completely)?
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Yes, the install would be cleaner with the buttons hidden however here was my thought process:
    - The 8" was fit with minor mods to dash by removing a bit of material and looks decent (IMO)
    - I would have to fill in part of the opening and fab a location for the buttons, major rework.
    - I decided to get everything up and running with it looking decent then tweak from there when I become more proficient with Fibreglass.
    - I may decide to go with a 10" monitor after its up and running so that will require major rework anyways. (relocate HVAC, vents etc) It is nice to have a spare bezel though to work with when the time comes!
    Thank you for questioning my choices, thats what I am looking for from this worklog, thats how the build can get better because sometimes we get tunnel vision on our projects!!
    Dec 2007
    Danville, CA
    Cool, makes sense to me. Keep us posted! 10" would be great!
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Project segment 2 (Power complete system) is now complete on the PC side. Still have the vehicle side to do.
    Notes on things that didn't work out:
    I had ordered a 12v auto adapter from LaptopPartsNow.com that was suppose to work with my HP but it did not. That was $70 so I guess I willl have to discuss this with them.
    It says right on their web site "100% Compatible - Meets or Exceeds Manufacturer's Specifications"
    Here is the link to the adapter;
    http://www.laptoppartsnow.com/hpcobu6767no2.html
    As you can see below, the third ID wire required by HP is missing.
    So I ended up using my 110v adapter which worked perfect. I powered it on the output side from the Carnetix 1900.
    Notice the third wire required for HP.
    OK, now onto what went well.
    First I tore the laptop down to wire the modem jack up to connect to the ACPI line from the Carnetix for on-off control.
    While I was at it, I removed the complete screen as it was pooched and removed the speakers as they were easy to remove and taking up a lot of space that could be for more air flow.
    I then cut the wires going to the modem jack and extended them over to the power switch and soldered them on. Note the Yellow and green wires which I added.
    The only loose end there is figuring out what to do with the WIFI antenna that used to be looped around the screen.
    I then put it all back together and moved on to wiring up the power supply.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Powering everything went well. I bought the Carnetix 1900 from Carl on this forum known here as "Upspace". He sold it to me for a more than fair price and was kind enough to mail it to me from Switzerland. He moved on to an Archos 5 and I hope that it is working out well for him!
    I did not expect to find a CNX-P5V 15 Watt +5V Regulator inside it. I had already ordered one with my order of other stuff so I ended up with two. Hey why not, I have 3 hubs and a dozen USB devices so more is better, right?
    I managed to mount both CNX-P5V's inside the 1900. Space was tight but there was one position for it that worked. It's mounted to the top up beside the fan. See below:
    I decided to mount everything to a piece of plexiglass making it easier to put in the truck temporarily until the console is built and maybe it will even mount inside the console if space permits.
    So here is everything wired up and ready for the vehicle:
    Notice the current draw. I have not seen it exceed 2.5A other that boot when the internal DVD spins for a moment and it will spike just over 3A.
    This is without a lot of USB devices attached though.
    Here is a close up of just the power board:
    That's it for now. The next update will be integration with the vehicle.
    Comments, questions are encouraged. I take criticism well and will use it to make my install better. Cheers!!
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Yesterday was a FULL day. While you guys south of the border were waving flags and maybe tipping something to keep you cool, I was in the garage slaving over a hot truck. OK, so I had the A/C vented out to the garage so it was only 75 in there, maybe a warm truck. But I do have to say the addition of the PC has made it hotter...
    Here is my workspace complete with PC, stereo, bench computer with SAT radio thanks to an extra Mitch gadget.
    I started with a slight dash mod followed up with a Little installation of wiring, then peripherals then more wiring then sound processor, then PC then very basic testing.
    The dash mod was required to give a little extra clearance for the 8" wide screen
    I ran a 10ga ground to the dash frame shown on the left side of the radio opening. Also you can see the notches created for the monitor to fit.
    I then ran a new 10ga power wire from the battery into the passenger compartment. This will feed a 6 fuse mini panel for various items being added including the computer.
    The next 3 pics show how I solder on the fuse holder to 10ga wire. It can be tricky to get a good solder joint and its important to seal it with heat shrink from the elements.
    The Sirius tuner was already in place, I replaced the translator box from the Alpine head unit with the Mitch Gadget interface and wired it accordingly.
    I then installed the Mic over the visor and relocated the parrot Mic over the door. I am not prepared to remove the Parrot just yet. My confidence for the BT functioning correctly in CF is not there yet.
    The Mic plug reached down under the dash but not to the centre seat where the PC will be located so I will have to add an extension to it.
    I was very please with the clean install of the GPS antenna, This is the same location as I had the Alpine antenna and it worked perfect there without being outside the vehicle. i have not taken the truck out of the garage yet to test but I'm sure it will be fine.
    The Sirius Antenna was already installed for the Alpine so no additional effort was required"
    I guess I will split this update into 2 posts. Stay tuned for part deux.
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    OK, Part deux.
    I installed the old controller that came with the used PXA-700 "redneck style" to the bottom of the CB. I bought a new one that displays in blue because it was almost as cheap as buying the extension cable and Mic that did not come with the used processor. I will save it for the final install.
    I then "installed" (read: set on floor) the processor under the back seat and replaced the 16' RCA cables with 3' to the amps behind the back seat. I ran an optical cable to the front to connect to the X-fi sound card.
    The processor will be getting installed in the amp rack when I get to that.
    Here are the amps installed (read{: sitting behind the back seat)
    The bench mess is really getting bad by this point
    [IMG]<a target="_blank" href="https://imageshack.com/i/mo14benchmessj"><img src="http://imagizer.imageshack.us/v2/640x480q90/816/14benchmess.jpg" border="0"></a>[/IMG]
    OK Here are the power wires ready to go to the computer PC, these also feed the Sirius translator, the monitor and the sound processor. Note the 6 fuse mini panel that will be installed in the new console to supply everything.
    Here is the rats nest at its worst:
    Here it is "sorted out" as best as possible. It's getting slid under the middle seat so perfection isn't going to happen at this point!
    Here the power supply has been slid under the seat and the PC is in place as best as possible. All I can say is this should keep me motivated to get the console and amp rack built.
    Here is the back seat all put back in place. The sub box sounds amazing and it will fit between the front seats but I expect that it will have to be down sized in order to get everything else to fit. It's about 1.6 ft so I can spare a little if I need to.
    Here it is up and running, I have to say it sounds better than the Alpine system I had before even without being tuned. It could be the addition of the processor but I suspect going optical instead of 16' x 3 audio cables has a lot to do with it.
    Beth Hart Live at the Paradisio in Amsterdam, you gotta love it.
    So I may have some minor updates over the next little while but the next major phase is getting the amp rack and console fabricated, and installing over 100ft2 of B-Quite.
    Once that is completed I will fully log here the final wiring install and testing.
  1. 2005 Ford F350, First timer!
    By jdc753 in forum Worklogs
    Last Post: 12-11-2012, 02:33 PM
  2. XR-Lane's NF Ford Fairlane Build
    By XRLane in forum Worklogs
    Last Post: 09-08-2009, 06:19 PM
  3. Newbie Ford Explorer 12.1" center conole build.
    By PandaBearBG in forum Fabrication
    Last Post: 08-01-2008, 09:00 AM
  4. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  5. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
