Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Dual zone control VX Commodore
    Mar 2010
    Today I AM going to start my car PC project. I ahve a 2001 VX commodore wagon that will get a car PC with 2 7" touchscreens that hopefully will be able to be controlled seperately.
    One screen will be in the dash, replacing the old factory head unit. this will control all functions and run CF3. the extra screen will be able to be turned on as needed for the front passenger to be able to watch media (movies, tv) through a 'second instance' of CF3 through wireless headset.
    i.e. driver can listen to music/radio/nav through main screen and car speakers, whilst passenger watches film/tv through 2nd screen and headset.
    To enable this I have done lots of reading and have found things like nComputing's X-series
    http://www.ncomputing.com/Products/X...S/Default.aspx
    and Fiddlehead
    http://www.myfiddlehead.com/installation-2
    as well as server to thin-client stuff
    http://h10010.www1.hp.com/wwpc/ca/en...5-4063703.html
    and KVM switches and UltraMon software
    http://www.realtimesoft.com/ultramon/tour/
    (this is regarding video and monitor control, not sound, which seems to be well-documented here)
    I have read the ZX1 cruizer thread, which has lots of cool ideas. My main concern is that I don't want to buy hardware and it turn out that the screens can't handle video and sound playback effectively.
    Can anyone give me definate word that the X-series gear from nComputing could handle replicating the CF3 software? I will test the concept out on my HTPC first then design the PC to cater for the requirements of the system.
    Thanks all
    Mar 2010
    i am going to try and build a server for my car with accessing through thin clients..
    Just need to learn about servers.. hhmm
    going to post photos soon to illustrate my ides. sorry that i haven't actually started the physical work yet.. will be soon though.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by springate View Post
    Problem is the server would not be acessible. Doing so will introduce slowdown for the thin clients and the server if you try to run anything on that server. Also thin clients are so limited. Most run on Windows CE, or Windows Embedded. I researched all routes and another thing is that the thin client hardware is just to limited. You cant use all USB devices and graphics power is very slow. That is the reason I went with 7 different systems that are all connected via ethernet.
    and Fiddlehead
    Thanks all
    If you plan to use touchscreens, you have to use KVMP switches. Regular KVMs will not work. N-computing will not work. I spent almost a month talking with their tech support. The hardware is slow and the terminals are taxing on the main pc. Also there is no touchscreen support with ncomputing.
    You will not have to run 2 instances of CF3, plus it isnt doable. CF 3.2 will have full multizone support. So front will have its controls and you can have each seat have its own controls also. This will require a powerful rig.
    How many seats do you plan to do. I can give you hardware advice. Do not go my route, I have wayyyyyyyyyyyyy to much and its so confusing and really hard to power.
    My setup can handle more then enough video and sound, in fact it can run 3D gaming, problem is not power, but money. The install is financially sucking me dry. Also some of the stuff is not proven until I have all the hardware together, which will not be till the end of this year. One big thing right now is powering everything. Originally I wanted to use 3 PSU units to power the rear, but it turns out having the OPUS turn them off without power down, could destroy the hard drives, even with them in EWF mode.
    I can help you along, but I will say that I am learning as I go also.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Jul 2007
    Miami
    If its just front and rear, then all you need is CF3.2 and a system with 2 graphic out ports (which is standard on most mobos now a days). Then you will need two soundcards. One is main audio, and the second card is for headphones. I used a PCI card for main audio, then a USB soundcard that has built in simulated 7.1 surround sound.
    You are over thinking your install.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by HiJackZX1 View Post
    +1
    Thats way more hardware/software then you need for a dual-zone install. You can try it with a single CF instance or give a multi-zone frontend a try and save yourself a ton of money.
    Jul 2007
    Miami
    Quote Originally Posted by justchat_1 View Post
    +1
    CF is multi-zone..... Now if you need use like me with like 15+ buttons for the rear, then you have to wait for CF 3.2, which will be unlocked and unlimited as far as the rear screens.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    dual-zone not multi-zone...we've had this conversation before lol. Either way, I did say CF was an option.
    Jul 2007
    Miami
    CF3.2 will have multizone. Stop trying to sell a FE that doesnt have the same functionality as CF. Yea it has multi-zone, but thats all it basically has. CF 3.2 will be 100% multi-zone, while still having a huge plug-in selection, skin selection, and ease of use.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Mar 2010
    i'm going with CF3 for my front end, sorry openmobile maybe when your other features and plugins are more developed.
    the plan is for 2 7 inch touchscreens in the front (one in dash and one in sun visor) and eventually a flip down with headsets in the back
    does anyone know of any good threads to read that involve automatic synching to home network (i.e. when I pull up at home the PC can wirelessly synch up to home PC to update audio/video?)
    I'm going to try and keep this build as compact as possible, but i can see it possibly taking over the car LOL, I really shouldn't have read HiJack's thread!
    Mar 2010
    I've been looking into iphone handsfree, and will get a carcomm cradle with external antenna (reception is patchy in most of Qld) and looking at getting a Andrea superbeam bundle.
    How will I connect this external soundcard with a second soundcard for the passenger's audio?
  1. AIMEE Climate Control POLL
    By Danceheaven in forum Software & Software Development
    Last Post: 01-14-2010, 09:38 AM
  2. Replies: 3
    Last Post: 09-24-2007, 11:00 PM
  3. G4 can support dual zone?
    By SB67 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 08-04-2007, 12:20 PM
  4. How to control an AMP with dual input
    By kingtut in forum Car Audio
    Last Post: 09-02-2004, 10:16 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
