Page 1 of 6 123456 LastLast
Results 1 to 10 of 56
Thread: 1997 Chevy Blazer
    Dec 2009
    1997 Chevy Blazer
    Well, if anyone watched my install in the 1998 Cadillac Seville STS, this is to update it. I'm removing my install from the cadillac as it has caused some minor problems with the system since it has the Bose Premium system in it. Which I found out almost everything electronically controlled in the car is routed through. And I didn't want to go overboard on cost to fully integrate the pc and risk having the car become useless. I will be documenting my install for the Blazer now. Same parts as what I had in the caddy, minus the FM modulator. I'll be ordering the BoomzBox in a couple weeks. I already have a Jensen 400w 4/3/2 channel switchable amp that I'll be using. Since the dash speakers were replaced and the wires cut and removed (before I bought it), I'll be removing them and possibly replacing them with something more mysterious later. Currently it has Roadmaster 6 1/2" speakers in the front and rear doors. Those will also be replaced later too. The OS will also be redone with a stripped barebone XP install with EWF, HORM, and Minlogon. I'll be using RR for the frontend.
    Planned start: Today 8/21
    First order of business, cut the textured clear acrylic to 8 1/2" w by 6 1/4" h to replace the radio and cubby hole in the dash. I'm using clear textured as it'll allow for a more illuminated look later using blue led lights behind. Pictures will be done as each part is installed. This is technically my 2nd install but it should go quite smoothly since I already "practiced" with the caddy.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Cant wait to see pictures. The Blazer is an SUV right? I see lots of potential for that. I agree about the Caddy.... Seems like they integrate everything into each other. Thats why I would never buy a newer model luxury car. All though some people have done it, but I would think its a b!+ch. I would rather get a normal car and start and build up from there.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Dec 2009
    Yes the Blazer is an SUV. I got the acrylic marked out to be cut. I'm replacing the radio and cubby area with it. This will allow me to fit my screen and a slim slotload CD/DVD combo drive connected by USB. That's being ordered in 2 weeks. Went a little overboard and got it with a steel case since it'll be mounted in the dash below the monitor. I'll try to get pics posted up today after I go get my new cell phone activated (AGAIN) so I can use it.
    Dec 2009
    well, now that my blackberry 8530 is usable and i'm back online with it using my netbook, i'm uploading the shot of the textured acrylic i'll be using. it looks ok with the backer still on, but should look much better without it. let me know what you guys think.
    Dec 2009
    now that the acrylic is cut, it's time to test fit for standoffs and choose the right sized screw to get it in with. once that's done, I can mark the cutout for the monitor and, go willing there's enough room left, the external slot-load combo drive to go either above or below.
    pictures of the dash will also be posted today as soon as i take them.
    Dec 2009
    well, completely screwed up today. made a newbie fabricator mistake. measured the dash opening instead of the mount opening. turns out i'm off by 2 inches height wise and a 1/2 inch width wise. not horrible tho. realized the acrylic alone wouldn't have been good enough for holding the screen and slot-load drive in place. instead, i'll be using a piece of metal to cover the full mount opening where the factory radio and and cubby used to be. this will allow for added support for the monitor and drive for when i'm out off-roadin in the blazer. the acrylic will be kept and used to fill the gaps around the monitor and drive. this will end up adding a few extra days of fabrication and install, but with a 12 hour work schedule and the fire/rescue calls i get.
    this is going to be a long but very awesome install once finished.
    >>>also, if anyone knows an easy way to tap the park switch and neutral safety switch, please let me know. need to get to these for the siren and red emergency lights going in at the same time as the pc.
    Jan 2008
    for the emergency lights, could you go into a little more detail on what you need them to do?
    Dec 2009
    The lights just plug into the 12v power outlet with their own switch. The siren is what I'm having problems with. I have a wire that connects to the neutral safety switch and one to the Park Safety (negative) wire. Just need to know where to connect at. Really don't want to pay $500 to get it installed. Help is GREATLY appreciated. Its a Code3 Compact.
    Jan 2008
    i am still having trouble understanding the siren-- connecting this wire is going to disable the siren while the vehicle is in park/neutral? or does it enable it?
    i found a manual, but double check that it is the correct version that you have:
    http://www.code3pse.com/pdf/install_...0855_rev_4.pdf
    according to that manual, i do not see a parking, or neutral wire. according to this diagram, though, there is a 12v input(recommended to be connected to a switched source), and a second "scroll" switch which will allow you to pick the tone-- they say that this can be connected to the horn, so when the "scroll" switch is held(old person won't move out of your way when your running to a call) it will emit a air horn sound..
    Dec 2009
    Soudman, this is the correct manual
    http://code3pse.com/pdf/install_guid...0833_rev_5.pdf
    go to page 5 for wiring diagram.
    it's the gray park-kill switch on the radio that connects to the vehicle neutral safety switch so when it's in neutral or park it disables the siren. i can do all the wiring, just need to know where the switch is and which wire to connect to on the switch. the manual is quite vague and doesn't mention that. i appreciate your help and the spoonfeeding. i've tried searching online for a manual for the blazer and haven't found much. my fire chief recommended just not connecting that wire but i want to do it by the manual so it's covered under warrenty and vehicle insurance.
  1. 1997 Blazer Double DIN Project
    By monette999 in forum Worklogs
    Last Post: 12-14-2008, 01:22 PM
  2. 2000 Chevy Blazer S.U.VeePC
    By JerzeyLegend in forum Worklogs
    Last Post: 11-01-2008, 02:53 AM
  3. 1997 Chevy Z-71 TruckPuter..ITs Alive
    By HarleyTeKk in forum Worklogs
    Last Post: 05-28-2008, 08:42 PM
  4. 1997 Chevy Siverado TruckPuter
    By HarleyTeKk in forum Show off your project
    Last Post: 08-30-2007, 01:01 PM
  5. 2001 Chevy Blazer and software
    By smaug in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-26-2007, 03:27 PM
