Results 11 to 20 of 24
Thread: PC install with DVR + GPS + Internet... In a motorcycle
  1. #11
    Newbie Hicotton02's Avatar
    Aug 2010
    Murrieta, California, United States
    Got the sides grinded down so it bits into the trunk better. Got the SSD in and loaded win7 Ultimate. Found out there there is a such thing as road runner. Looking around for a manual and how to customize it. Also looking into an adaptation of the ODBII software for the bike. So, still trying to figure that out. Waiting on cables, Touch screen, camera, GPS, and DVR.
  2. #12
    Aug 2010
    Finished modding the trunk. Also had to modify the case it aint pretty but it works and you wont be able to see it. M1-ATX PSU was DOA so i had to return it
  3. #13
    Jan 2008
    Dartmouth, MA
    IS that case gonna be waterproof?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  4. #14
    Aug 2010
    Quote Originally Posted by PaulF View Post
    the case will not be but the trunk is.
  5. #15
    Dec 2006
    India
    Quote Originally Posted by Hicotton02 View Post
    Ram: G Skill 4GB
    Monitor: 8.4" Shark touchscreen
    It's quite an interesting project...We don't find many SBKputer projects after all...
    2GB of RAM should be more than enough and it will save some power too considering you have a smaller battery when compared to a 4-Wheeler.
    I'd suggest that 8.4" Shark Monitor/Touchscreen is best avoided. I have the same screen and view-ability sucks big time even in a brightly lit room. The build quality and touch screen is pathetic too.
  6. #16
    Aug 2010
    I ordered the screen 3 days ago. That sucks... Well if it is as bad as you say, I'll just send it back and get a better one. What would you/y'all recommend? Keep in mind that this is on a bike and a budget build
    Aug 2010
    Got the dvr and gps in yesterday. Installed the GMPC software and got it integrated with RR. The dvr software is next. Gotta learn more about RR first.
  8. #18
    Aug 2010
    Got the Touchscreen in today, not impressed. the 1500mA ac adapter apparently doesnt have the juice to run the screen without dimming out. I also have to change the resolution i guess because when i use the touch screen, my finger is about 2 inches from where the touchscreen shows. anywho here are some screenshots on a normal monitor
    Showing CPU usage with 4 cameras recording, RR, winamp, and GPS
    without recording
  9. #19
    Dec 2006
    India
    The adapter though it is marked 1.5A rated, could be able to provide not even 1 amp. IIRC, the monitor takes less than 1 amp. I guess this should not concern you since the power adapter wouldn't be used in the final configuration.
    The touchscreen which came with my 8.4" Shark monitor was very reflective, almost like an old dimmed mirror...lol. In you application, this may create a major issue I guess.
    If you have an option to return the monitor, I'd suggest you to do it and get a proper transflective display (yes, they are expensive but totally worth it, especially in application like yours.). You can also look for TMR screens but they are not as good as transflective monitors.
    BTW, how are you planning to protect the monitor from the elements (Rain, Snow, Humidity, ...)?
    You need to do the touch screen calibration. You must have received a CD with screen calibration utility along with the monitor. Higher the calibration points, the better.
  10. #20
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    +1 for the transflective display. You could go to mo-co-so.com and you'll see there's different "levels" of transflectiveness, so it can be useful if money is an issue (always is). Or try avionics.com but they can be more expensive.
    I regret not having spent more money on a transflective first and adapt the rest. All the hard work needs to be viewable. Im a motorcycle or a convertible, that is a must.
