Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 56
Thread: Bugbyte's iPad Connected Car Install
  1. #41
    Jan 2008
    the dome light issue is pretty minor-- look into high flux, or super flux led's with a 120-180deg viewing angle-- 3 on each side should do pretty well, bith in lighting, and keeping everyhing less then a 1/2" tall..
    for the pivot, what about looking at other cars for similar designs? you might be able to frankenstein 2 different mounts to 1 use-able mount..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  2. #42
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    As a side note, what would be really cool is if you could replace the mirror glass with a one-way mirror, so you could mount the iPod directly behind the mirror and you won't see the screen unless it's on.
    that's something I have in mind, but not sure how well it works with needing to see out the rear view mirror. Turns out the reflective part of the mirror is a film applied to the back that I might be able to sand, or may be able to replace with a one way film. I'll have to think it through a bit.
    Want to:
  3. #43
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Bugbyte View Post
    You dont even really need to use a mirror. Just use glass and a super reflective covering. Kind of how the 10.2 rear screen works on mine. When its off, its black, but super reflective. When its on, the screen kind of blinds out the reflection so you only see the screen.
    See, when its off you see a reflection, when its on, if looking at it directly, you do not see a reflection.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  4. #44
    Constant Bitrate Lando's Avatar
    Apr 2002
    U channel
    Hey, what's Lowes SKU number on the U channel you used? Thanks!
    Aut cum scuto, aut in scuto
  5. #45
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I have no idea. I took the iPad with me and fit it to what they had in the bin. If I had to guess, it would be 1/2" or thereabouts.
    Want to:
  6. #46
    Apr 2002
    Thank you
    Thank you sir!
  7. #47
    Apr 2002
    Can you tell me what department it was in? I have a Lowes around me, but it's a bit of a trip. Just trying to make it as painless as possible.
  8. #48
    Jan 2008
    that stuff is usually in the hardware dept. just look for a 4' x 4' categorized/labeled box that looks like a a scrapyard of metal-- all sorts of stuff sticking up at angles close to vertical, but not quite there.. and if it isn't in that bin, it is within 20' of it. or i should say that every hardware store i've been in always keeps their raw stock in the same aisle, very near the hardware dept, and usually within a very small area in the aisle.
    HID retro--100%
  9. #49
    Apr 2002
    Thanks Soundman!
  10. #50
    Apr 2008
    Check this project out. It is quite impressive and good for Carpcs
    http://iphonetable.blogspot.com/
    They have not provided much technical details yet. As far as i can tell that they made the touch screen workable with Iphone. They probably have a pc inside of the huge touch screen or some kinda customized controller.
    I think that it is quite interesting.
  1. 2002 Volvo S60 Super Connected Car PC
    By PaulF in forum Show off your project
    Last Post: 04-25-2012, 06:02 AM
  2. Dodge Charger iPad Install
    By MobileEVDO in forum Apple iPad
    Last Post: 09-04-2010, 01:23 AM
  3. Replies: 22
    Last Post: 12-17-2009, 06:21 PM
  4. Installing car PC in 1996 Honda Civic
    By PredatorCoder in forum Newbie
    Last Post: 08-18-2005, 07:58 AM
