Page 49 of 61 FirstFirst ... 394041424344454647484950515253545556575859 ... LastLast
Results 481 to 490 of 602
Thread: 2003 Durango SLT / Project HiJackZX1 (Finally Focused Remix)
  1. #481
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Yes, that sensor is most likely signalling an out of range due to the slightly higher voltage supply but that’s a little strange at only 14.8v. Have you checked for a bad sensor connector or earth connection that may have been disturbed when changing the alternator?
    Does the alternator output stay at 14.8v or does it come down after 10 to 15 minutes of driving?
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
  2. #482
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Mickz View Post
    I get a P0113 error. According to Google, it says this:
    A code P0113 may mean that one or more of the following has happened:
    Internally failed IAT sensor
    Faulty connection at IAT sensor
    Open in IAT ground circuit or signal circuit
    Short to voltage in IAT signal circuit or reference circuit
    IAT harness and/or wiring routed too close to high-voltage wiring (e.g. alternator, spark plug cables, etc.)
    Faulty PCM (less likely but not impossible)
    Something tells me that a wire is routed to close to the IAT harness. When I did the big 3 upgrade the light came on sometimes. Once this new alternator went in, the light stays on!
    I actually added a ground. I have one coming from the alternator, One from the bottom of the engine, and then two to the frame. All these meet up at the battery. Reason I did 2 grounds to the frame is because the original factory one is screwed up. It looks like its going to break, so I added a second one.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  3. #483
    Jul 2007
    Miami
    I'm an idiot. Anyone upgrading their alternator, remember to plug the IAT back in. I just plugged it back in, unplugged the battery. Plugged battery back in and now the light is gone.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  4. #484
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Gee I was pretty close
  5. #485
  6. #486
    Jul 2007
    Miami
    Yup... Also the dimming thing has gone away. Maybe the battery wasnt charged? I think when I get the new battery for the rear, I am going to pre charge it. Doesnt Autozone do that.
    Quote Originally Posted by Enforcer View Post
    :-( you always so mean to me.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  7. #487
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Absolutely, if that old alternator was putting out what you said then it was the cause of 98% of the problems you’ve been having. Looking forward to see how this new system runs.
  8. #488
  9. #489
    Jul 2007
    Miami
    Did you click on the play button then?
    No, was just saying in general.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  10. #490
  1. Replies: 823
    Last Post: 08-31-2010, 01:37 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
