Page 53 of 61 FirstFirst ... 343444546474849505152535455565758596061 LastLast
Results 521 to 530 of 602
Thread: 2003 Durango SLT / Project HiJackZX1 (Finally Focused Remix)
  1. #521
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by HiJackZX1 View Post
    .................................................. .... I plan to get back into it and hopefully get my hubby into to. I want to rethink and redo everything as far as the rear install. .................................................. ........
    !!!!!!!!!!!!!!!!!!!!!!!! Warning - Major homophobe comment to follow, skip this post if easily offended !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Glad I wasn't drinking hot coffee when I read that.
    Ok, maybe it wasn't that harsh comment. ;-)
  2. #522
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Actually, thinking about it, that was not homophobic at all.
    Because even if you were a girl talking about her husband, or a man talking out his wife it would have got the same reaction.
    Only time it wouldn't would have would have been if you were a girl talking about your wife. (and even that with accessories . . . .)
  3. #523
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Enforcer View Post
    UGH, you made me almost choke on my food..... LMFAO.... I missed your comments Enforcer. My man was looking at me like I am a crazy psycho because i couldnt stop laughing.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  4. #524
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    UGH, you made me almost choke on my food..... .
    oh, the temptation.
    Stop feeding me straight lines. ;-)
  5. #525
    Jul 2007
    Miami
    Well, as you can see from my sig, I have committed to MaxSpeed Maxterm 8300B thin clients. They feature a 800mhz processor, 512mb ram, 512mb flash card. I spent a total of 19.00 per unit. That includes shipping. They run with XPe, so I will be able to use Centrafuse, which recently ceased Linux and WCE versions. They use 12v power, just havent found documentation on whether its 12vdc or 12 ac. Once I have them, I will start testing and get each unit running with Centrafuse. Once that is all set, I can take the main system out the car, rebuild the tower with the new units and rearrange things. Currently certain components can not be reached and have issues. I need everything to be accessible. Hopefully then, this journey will be close to over.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  6. #526
    Jul 2007
    Miami
    Ok, need advice!
    OK, I got the thin clients. All units are basically a VIA based motherboard. The PSU seem to be DC-DC. The PSU use 12V @ 3amp. Does the PSU have to have only 12v @ 3amps, or can I simply connect 12V and the PSU steps down the amps that it needs, or will I have to have some type of regulation in place? Pictures are below.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  7. #527
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    That all depends on the DC-DC units.
    If they were designed with automotive use in mind thy will be regulated, however if they were designed to be used in a non-automotive situation they will probably need a regulated supply.
    See if the DC-DC units have any numbers and/or markings that identitfy them and then do a google search.
  8. #528
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    Typically the power supply will regulate the volts. The amp rating should be the most it requires. Usually you will never draw the max unless something goes wrong. So you fuse it at or just a bit above the rating. Say 5 amp fuse.
    And, as Enforcer says, you need to find out about those power supplies. They might not play nice in an automotive environment.
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  9. #529
    Jul 2007
    Miami
    The information on the PSU is so limited. I can not find anyhting on them. i know for a fact they are not for automotive use.
    Quote Originally Posted by jmullan99 View Post
    So what actions can i take to make them automotive friendly?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  10. #530
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Replace them with M2-ATX's (or equiv)
    or get a 12VDC-12VDC regulator with enough amps to supply all your units.
  1. Replies: 823
    Last Post: 08-31-2010, 12:37 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
