Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 61 to 70 of 114
Thread: [insert name of project] worklog
  1. #61
    Dec 2008
    Wow the price for the expansion board is 181.0€ or $252.71. http://shop.igep.es/index.php?main_p...products_id=49
    It might be worth it because of the following
    Composite Video Inputs x 2 (backup camera, Ext.)
    LCD interface built on
    VGA output to run second monitor
    but I am not sure.
    What are your thoughts?
    The Doc
  2. #62
    Dec 2003
    OMAP3530 doesn't support VGA + HDMI or VGA + LCD. You can have Composite/SVideo and VGA/HDMI/LCD though.
    http://processors.wiki.ti.com/index....play_Subsystem
  3. #63
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Yeah, it's likely only single video output + mirrored signal on the svideo/composite outputs. That's how it works on my phone anyway (n900). I assume it's the same for other OMAP-based phones. The price of the screen at ~$180 and the price of the expansion board at ~$255 is getting pretty discouraging. It'd be nice to have the GPRS built in but... meh. The built in CAN controller also was appealing but not $255 appealing...
    Currently I'm in the middle of moving, but I'm about ready to set up a corner in the house where I can start hacking again.
    In other news, there is an upstream kernel patch to get egalax-based touchscreens working. For those of you not aware, egalax worked in LinuxICE but subsequent kernels had broken drivers. I'm going to try to backport this patch to my igep kernel and see if I can get it all working.
    Also meego 1.1 was released.
    stay tuned...
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  4. #64
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    Quote Originally Posted by tripzero View Post
    stay tuned...
    Where do I download the egalax patch for linux(been trying to get my egalax touchscreen to work in Ubuntu 9.04(can't calibrate the screen, plus mouse is moving on reversed axis's...x and y are switched)
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
  5. #65
    Jan 2008
    lol in the new "latest posts" plugin, this thread only shows up as "worklog" your brackets get in the way
  6. #66
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by soundman98 View Post
    lame. i liked the old plugin way better. bring it back!!!1eleven! plz .
    I think you have a different issue... 9.04/LinuxICE didn't have the issue I'm talking about because the kernel is pre 2.6.31. However, I'm not sure the version of X you have in 9.04 supports all the stuff it should. The egalaxTouch driver should work fine if you really have a egalax based touchscreen and it's working properly. I've tested LinuxICE with about 3 different egalax based screens and they all work.
    At any rate, here are the resources for the bug I'm talking about:
    https://bugs.launchpad.net/ubuntu/+s...ux/+bug/549447
    this may also be helpful:
    http://ubuntuforums.org/showthread.php?t=1541396&page=1
    cheers.
  7. #67
    Oct 2008
    wouldnt this help? http://cgi.ebay.com/10inch-HDMI-DVI-...item35ab453a56
    it eliminates the adapter......
  8. #68
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by BERTMAN View Post
    wong end... need male. But that's the right idea!
  9. #69
    Oct 2008
    hmmm the description shows male to male, the pics say otherwise haha.
    well, back to the drawing board.
  10. #70
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    long term testing
    Since moving to my new apt, I had to make room in my trunk during the move. I thought this would be a good time to move my secondary battery into my "lab" to do some long term testing on the igep.
    The idea is to produce some numbers over the next few weeks to give an indication on how long the igep will run on just a car battery. Success criteria is any battery voltage above 11.4. First, I will test in an unoptimized condition. This will give me a base for later testing. So for the next several days, I'm running stock ubuntu 10.10 with hdmi and ethernet hooked up. Here are the some numbers for about 12 hrs of operation:
    date - time - volts
    11/19/2010 - 20:48:00 - 12.5
    11/20/2010 - 08:28:00 - 12.45
    As you can see, in about 12hrs it sapped 0.05 volts out of the battery. Running the igep is definitely safe overnight. More data to follow.
  1. Looking for a boat pc worklog to point others to
    By Heather in forum Boat Computers
    Last Post: 10-17-2009, 06:04 AM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 03:03 PM
  3. SpottedBeaver's 2001 Tacoma Worklog
    By SpottedBeaver in forum Worklogs
    Last Post: 05-11-2007, 10:39 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 03:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 02:43 PM
