Don't have any idea at the moment. I've got a hall sensor ammeter thingy but I need to find the cable to hook it into the fusion brain. I also want to write an app that reads the voltage and amps and logs it so I don't have to hook up the voltmeter.
Right now after ~23hrs I'm at 12.37. Also, the initial voltage may be 12.5X since I didn't exactly read it on the right resolution (didn't know my voltmeter could read hundredths of a volt).
It's also noteworthy that I'm testing on the kenitik hc800 which is a little over half the capacity as a normal car battery. This experiment gives us a safe guess at how long we can run it without killing the battery as actual results should be better especially when we start optimizing the software.
LinkBack URL
About LinkBacks
