Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
Thread: 2002 Honda Civic Ex --Worklog
  1. #31
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by slociviccoupe View Post
    I prefer to use the 2-4 guage welding cable for power. Only comes in black though so colored heatshrink is a must when doing power cables. Its double insulated and as flexible as a wet noodle. Also good marine grade tinned connectors crimped and soldered then heatshrink gives a very clean reliable install.
    4 guage is used in most decent amplifier installs and is available in colours, usually blue, sometimes red.
    Below 4 guage is the welding cable that is in black only (to my knowledge). I used 0 guage in my build to run to the rear of the cab then distro blocks split it up into 4 guage runs from there to amps, etc. You can use red electrical tape instead of heat shrink to mark the hot wires as well.
  2. #32
    Constant Bitrate cla1067's Avatar
    Apr 2009
    Sarasota, FL
    I like how that is nicely installed underneath the seat. I just looked at your worklog and it blends in nicely with the seat. Are you going to run the wire underneath the carpet, so it doesn't show or leave it?
  3. #33
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Most of those wires will not run under the seat after the processor gets moved forward into the console which I am still working on. The console runs all the way back and meets the seat so any left over wires will be hidden.
  4. #34
    Apr 2009
    Sarasota, FL
    I'll have to check out your thread when your finished. Didn't realize that you were gonna extend the console all the way back.
  1. 2003 Honda Civic Hybrid Install Worklog
    By Gecko483 in forum Worklogs
    Last Post: 04-23-2012, 01:59 PM
  2. Brazilian - 2002 Honda Civic - CARPC
    By rafaelsonic in forum Worklogs
    Last Post: 05-08-2010, 05:08 PM
  3. 2002 Honda Civic LX-G CarPC
    By burnsidet in forum Worklogs
    Last Post: 12-31-2007, 04:04 AM
  4. UK 2002 Honda Civic Type-R
    By jimtum in forum Worklogs
    Last Post: 06-25-2005, 10:48 AM
  5. Honda Civic Type-R 2002 TFT Dashboard
    By vtecpinguin in forum LCD/Display
    Last Post: 08-21-2004, 04:50 AM
