Page 18 of 22 FirstFirst ... 8910111213141516171819202122 LastLast
Results 171 to 180 of 220
Thread: All-in-one Atom330/ION project
  1. #171
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Nice job! Did you figure out your thump issue? I may have over looked what you are using for your PSU but I know the "intelligent PSU's" have anti-pop (thump) like the M4-ATX.
    "Live Free!!!...It's all about Open Source"
    Current Proj:'09 Altima In-Dash Android Tablet and System Upgrade
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #172
    Jun 2007
    Boston MA
    Quote Originally Posted by hexxamillion View Post
    Take a look a couple of posts above
  3. #173
    Jan 2008
    it sounds like it is just some artifacts of the amp chipset starting up.
    the couple options i can think of are to either keep the amp on all the time, or to connect relays to the speaker outputs-- to disable the speakers until after the amp turns on.
    oh, wait, isn't there a mute pin on the chipset? if you were to connect the amp to power up with the rest of the carpc, but then make the windows application control that mute pin-- that might get rid of the sounds....
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  4. #174
    May 2010
    Moncton, New Brunswick, Canada
    TDA7850 with noise suppressor St-by and mute pins.
    I think I have this amp, but I'm still in the process of installing power from my battery to a UPS/22AH SLA battery in the trunk.
    The diagrams on the ebay site -
    http://cgi.ebay.ca/TDA7850-Car-Audio...item19c418e183
    Shows in the upper LH corner a connector with 3 pins, top St-BY, middle mute and bottom grnd.
    I have a M2-ATX with Anti-thump feature, I hope to use these connections to prevent thump.
    I looked at the manual for the DCDC USB, but didn't find Anti-Thump. Maybe you could use some other pinout on the motherboard to run to St-by or mute to prevent Thump.
  5. #175
    Jun 2007
    Boston MA
    Today was the install day!
    Good news first - I hooked up the computer to the harness and it worked! Everything started as expected.
    Bad news - the "standard double din" black box does not fit into standard double din I took out the dash bezel and dremeled it down a bit. Tomorrow I'm gonna go out and get some Bondo to smooth out the cuts.
    Also, the black box enclosure does not have pre-drilled mounting holes - it has a lot of holes, but none of them match up with the standard ones.
  6. #176
    Jan 2008
    careful-- standard body filler like bondo won't adhere to plastic parts for very long-- different expansion/contraction ratio's.. check some of the stickies in the fabrication section--there are many recommendations for better=performing materials.
    HID retro--100%
  7. #177
    Jun 2007
    Boston MA
    Quote Originally Posted by soundman98 View Post
    Thanks Soundman! As always, you come to the rescue. Autozone should have some stuff for fabrication, right? What would you recommend?
  8. #178
    Jan 2008
    i don't know if autozone has anything like that..
    it might be better to make a thread about it in the fab section, just be sure to list the type of material the bezel is-- usually there is a stamp on the back that will tell you.
    HID retro--100%
  9. #179
    Jun 2007
    Boston MA
    If you guys can read schematics, could you make sense out of the ST-BY and Mute functions? It looks like I should be able to short Pins 1-3 on J1 to get ST-BY and Pins 2-3 to get Mute, but neither seems to work - shorting them does nothing. Any ideas?
  10. #180
    Jul 2004
    @nivanov, I got my amplifier the other day, but I haven't hooked it up yet. There are a few things that I have to work on before I get to that stage. Oh and I actually emailed the seller and asked him how to use the standby/mute, but I don’t expect he will give me an answer because I already asked him about what fuse to use and he didn’t know. I am also curious about the 4-way input. Does that mean it can have four separate inputs and if so how do you switch between them?
    ø¤º°`°º¤ø
    ,¸¸,ø¤º°`°º¤ø,¸¸,
    °º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°
    °`°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°` °`°
    ,¸¸,ø¤º°`°º¤ø,¸¸,
    ø¤º°`°º¤ø
    º°`°º
  1. Integrate Solar Energy in your CarPC Project
    By hexxamillion in forum How to Power a Laptop
    Last Post: 11-26-2009, 08:58 PM
  2. Crowdsourced Map Data Collection, Mapping and Routing: project explained.
    By Heather in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 10-02-2009, 08:26 AM
  3. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 10:11 AM
  4. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 11:06 AM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 05:43 AM
Tags for this Thread
