Page 6 of 23 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 223
Thread: All-in-one Atom330/ION project
  1. #51
    Jun 2007
    Boston MA
    Quote Originally Posted by soundman98 View Post
    i was thinking outside the box-- literally.. cut out the area just around the chipset, and that would allow better airflow to the heatsink, and would also allow a larger, more solid heatsink..
    I'm worried a bit about the double din mounting screws. I forget what type they are (last time I installed a radio was about 3 years ago) but I'm pretty sure I need to leave some room for the screws to go into the black box enclosure.
  2. #52
    Jun 2007
    Boston MA
    Well, at least one problem is solved!
  3. #53
    Jan 2008
    Quote Originally Posted by nivanov View Post
    the screws should be fine, they shouldn't need to extend into the case any more then a 1/8"-1/4"-- less then the lengths of the standoffs for your power supply.. and if their too long, you can always cut them down.
  4. #54
    Jun 2007
    Boston MA
    Oh Really? I was gonna put some washers in if the screws were too long to control the depth of penetration, so to speak I guess they aren't that long to begin with.
    So I'm kind of limited on space for the heatsink, so I was thinking of getting a thick aluminum sheet, thermal epoxy'ing it to the chip and bending it around the pcb in a square bracket shape. I could also mount a fan on top of the flat part of the bracket. I think it should be sufficient, but, just in case, I bought an infrared thermometer. How hot/cold should I expect the chip to be? Mind you, the spec says it can run at 130C. I think if I can get it down to 70C under load, I should be good.
    By the way, I really appreciate everyone's help with this project! I can sort of see the light at the end of the tunnel!
  5. #55
    Jan 2008
    i would say under 0/low load(0% to 30%), it should be warm to the touch-- something like 40 deg. C(100 deg F is that warm to the touch? i kind of think that is starting to burn...)
    but 70c should be ok as well, just a little warmer then i would prefer in a tiny dash box...
    i would probably first try to heatsink it without fans-- that way, if you can keep it around 70C with a moderate load, you will know that the fans will be sure to keep it well below that..
    it would also be worthwhile to cut slots in the sheet to increase the surface area of it to allow for more heat transfer, and airflow.. and the other thing i have read is to rough-up the surface with some low-grit sand paper because that can also help add surface area. i'm not sure how much a rough surface really helps, but every little bit has got to count for something...
  6. #56
    Jun 2007
    Boston MA
    Thanks for the tips, soundman. I think I'm gonna go with aluminum - I can probably buy a small sheet of it in a hardware store nearby. I was going to go with copper, but that's a bit harder to find. I was also thinking of attaching a small chipset heatsink (from a northbridge, for instance) onto the aluminum sheet if just the sheet itself does not provide adequate cooling.
  7. #57
    Jun 2007
    Boston MA
    Finally testing all the parts at once:
    Hardware overview: http://www.youtube.com/watch?v=2V6GCCh-71w
    Software overview: http://www.youtube.com/watch?v=6dFrt7npltE
    Pretty exciting stuff
    P.S.: I am saying "um" way too much - go on, make fun
  8. #58
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    The Pandora Plugin is not open source...and even if it was, GPL plugins cannot be used with a closed source plugin host (like centrafuse) - thats a violation of the license.
    In the future I would also ask that when something is clearly licensed "License: For openMobile use only" that you respect that.
  9. #59
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Please keep this thread clean of plugin talk, this is a member's worklog. Posts have been clipped and placed here: http://www.mp3car.com/vbulletin/open...lugin-gpl.html
    Tidder
    Try RevFE
  10. #60
    Jun 2007
    Boston MA
    I finally got an IR thermometer so I can measure the chip and heatsink temperature of the amplifier:
    1. I used a sheet of aluminum and folded it several times and attached it to the heatsink. It cooled it somewhat but not enough
    2. I've attached a northbridge heatsink. Performance was better but it still ran pretty hot. I think, in practice, the heatsink itself would do just fine, but I'd like it a bit cooler for those extra hot days in the summer
    3. I've measured the height of the amp+heatsink+fan. It JUST fits, which I'm ok with as long as it actually does fit once i mount it. I'm planning on soldering the fan wires to the back on the power terminals on the amplifier. Fans should be ok with some voltage fluctuation, so I'm not too worried here
    Note: don't try to measure temperatures off shiny surfaces using an IR thermometer. When the heatsink was pretty hot to touch, the thermometer was reading 31C - well below body temperature, even. I finally figured out what I did wrong and smeared some thermal paste on it so I can get a good reading. 65C and climbing - time to go with active cooling!
  1. Integrate Solar Energy in your CarPC Project
    By hexxamillion in forum How to Power a Laptop
    Last Post: 11-26-2009, 09:58 PM
  2. Crowdsourced Map Data Collection, Mapping and Routing: project explained.
    By Heather in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 10-02-2009, 09:26 AM
  3. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 11:11 AM
  4. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 12:06 PM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
Tags for this Thread
