Oh man, I feel like I am getting really close on this. I tied up a bunch of the loose ends I mentioned yesterday. I remounted the HD with the old screws, and just spaced hte MOBO standoffs up a hair. That was all that took and it fit perfect. I did the first test of the whole thing mounted up in the dash piece this afternoon. It all went well.
I have a bit more plastic I still need to remove on the connector side of the MOBO. I still have to work out the M4 mounting. I looked at moving it forward on the bottom of the MOBO mount, but I am not sure that is the way to go with it. It will work there, but it will be terribly tight. I still have not messed with the video card mounting, but I did install it with the flexible extender today just to make sure it worked without a hitch. I have a lot of cable reworking and routing to do, there is simply a crap ton of wiring to fit in here.
Anyhow, I powered it with the 12V supply and the M4 just to make sure it worked. First try nothing, cycled power and it fired right up-- no idea what was up with that, but hopefully it doesn't become an issue.
Next on my list is redoing the lilliput cable, it is like 8' long and I have absolutely no place to put it. I need all of 8 inches, so I will cut it down and solder on new VGA and USB connectors.
I am back to work tomorrow, but start my 7 day off stretch next friday, so I am hoping like heck that I might be able to wrap it up and get it installed. Wish me luck!
Here are the pics:
Later,
Jason
LinkBack URL
About LinkBacks
I burned up the original BT chip trying to desolder it. The blue plastic comes apart into two pieces once out of the silver housing. Getting the new BT chip in was ALOT easier. As per your reply I think I lucked out on putting the connections in the proper sequence. I plan to test everything to morrow when I have some free time. I took pics but i'll save you the trouble of looking at them.
Thanks again for all the help.
