Results 11 to 20 of 26
Thread: 98 Volvo S70 ITX Worklog
  1. #11
    Constant Bitrate tibimakai's Avatar
    Feb 2005
    San Pedro, USA
    right angle adaptors would not help?
  2. #12
    Constant Bitrate knownchild's Avatar
    Dec 2010
    IOWA
    not enough for it to look good.
    Never accept STOCK equipment.
  3. #13
    Feb 2005
    San Pedro, USA
    to look good?! who will see that?
    that heater pipe it's in your way? which connector ha interference issues?
    I have seen somebody who even removed the soldered connectors off of the motherboard and soldered the wires to the motherboard directly.
    I haven't tested it yet if it would fit, but to be sure I will make all of my connections right angled.
    my biggest connector is the serial one for the hd adapter, but they sell right angle adapter for that too.
    I will make my cable for the monitor and I will use a solder on vga connector which is right angle.
    I need to get some right angle usb cables or adapters and then I don't have anything sticking out to much.
  4. #14
    Jan 2011
    Nice! Shame that didn't work out building it into the radio case, that would have made for a nice clean install.
    I have a 98 S70 GLT also that hopefully I'll get to installing a carpc soon in.
    I like the glovebox idea, that's where I was figuring I'd probably mount mine. Psh, it's not like I have any gloves anyway!
  5. #15
    Dec 2010
    IOWA
    Quote Originally Posted by Thorsteenster View Post
    The radio case idea probably would have worked if i went with a Pico-itx mobo or nano-itx but i like having more power and the glove box just holds a bunch of garbage anyways.
  6. #16
    Feb 2005
    San Pedro, USA
    if you would cut out the radio's case back, it wouldn't fit?
  7. #17
    Dec 2010
    IOWA
    no it would not fit, i would have to get a smaller motherboard that's why you cant find a double din case that holds a mini itx mobo.
  8. #18
    Feb 2005
    San Pedro, USA
    I have measured the room in the dash and I have build my own case
  9. #19
    Jan 2011
    I like the glovebox idea anyway, you could put lighting accents in, some plexiglass and makes for easy access and helps you keep a clean glovebox.
  10. #20
    Dec 2010
    IOWA
    LOL that's exactly what i am planning to do.
  1. (56k WARNING)Mini ITX AMD Dual Core Volvo S70 Double Din Project
    By knownchild in forum Show off your project
    Last Post: 01-21-2011, 09:25 AM
  2. 98 Volvo S70 T5 Mac Mini Carputer
    By alexcellent22 in forum Show off your project
    Last Post: 05-16-2010, 04:46 AM
  3. 1997 volvo S70 TDI
    By winnox in forum Show off your project
    Last Post: 05-11-2007, 12:31 AM
