Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 82
Thread: Project "C++"
  1. #21
    Constant Bitrate 4ofakind's Avatar
    Jul 2009
    Next if I find the heart to keep going, I have to mold in the PQi OSD buttons and my slot load DVD drive. I know, "Why didn't I do it at the beginning?". I was not sure I was going to put them there. I'm still not sure. I'm not totally sure I'm going to use the DVD drive at all. Now with my broken LCD, I really am not thinking straight. I'll make up my mind in a week or two I guess.
    Mal
    Vehicle: [100%] 1995 C 1500 ECLB
    Gear: [90%]
    Build: [80%] PC & Chassis, Worklog
  2. #22
    Jul 2009
    Ok, since I broke my 10" LCD I chose to take out my frustration on my in dash ashtray. Plus it is getting a little warm here in vegas so I need to get this done. I did alot of cutting w/ my dremel and 4" cutoff tool. It felt good destroying things on purpose instead of by accident. Pics of what I did coming soon. Got some test fitting to do first. For now I'll leave you with my inspiration, a pic of what my ashtray a/c controls should look like when done.
    Mal
    Gear: [90%]
  3. #23
    Jul 2009
    Been a while since I updated this project because I've been doin stuff.
    First, I could not get my a/c controls in my ashtray due to the large steel bar going across behind my dashboard. I'm not sure how the guy in the above picture did it w/o cutting or severely modifying that bar. I came up w/ an alternate solution I am currently working on.
    In the mean time I have been finishing my dash bezel. I added a display control board, a slot for my optical drive, and I drilled holes and mounted screws to mount my new display when it arrives. I'm nowhere near as good as Nexson, but I like it. I also sound deadened the truck, so all I have left is to run wire and actually install my CarPC components.
    Mal
    P.S. Either I get a better camera or take all my pictures outside. Gees
    Gear: [90%]
  4. #24
    Jan 2008
    slowly but surely!! at first, i thought you didn't use enough sound dampening, but then i see that you hit all the key areas-- saving money and getting most of the benefits!
  5. #25
    Jul 2009
    Yeah, I don't expexct it to be a rolling concert hall. But I'm already way ahead of what I used to do to my previous vehicles: Replace the radio, upgrade the stock speakers, throw in a woofer box that takes up all available space, and power it all with a couple amps on the stock charging system.
    This one's taking a little longer than expected, but I'm having alot of fun.
    Mal
    Gear: [90%]
  6. #26
    Jul 2009
    Always good news and bad news with this truck.
    The good news is I got the amp rack upholstered and the amps and PC mounted.
    The bad news is the Coustic crossover will not fit under the seat AND accept its connections. Im thinking I will mount it to the back cab wall.
    Still to do:
    Buy and install new LCD display. (Man I should not have broke the first one. )
    Move AC controls.
    Mold Mids/Tweets in A-Pillars.
    Make woofer box look like center console.
    Install speakers.
    Wire everything up.
    Three months will be one year working on this; I better get to work.
    Mal
    Gear: [90%]
  7. #27
    Jan 2008
    looks like your doing really good!! my led tails where less then half the work you need to do and those took me nearly 1-1/2yrs...
  8. #28
    Jul 2009
    Ok I got some things done today/night.
    I mounted the main fuse block in the engine compartment on the passenger fender. I cut and installed the 0 guage power wire from the battery, through the antenna (which I removed) grommet on the passenger side firewall, to the fused distribution block on my amp rack. All fuses are currently not installed until I plan out and install the wiring.
    But here is the big/crazy thing I did.
    The Coustic crossover location was giving me fits. It would not fit on my amp rack under the rear seat. I mounted it on the rear cab wall. It was too big to allow the rear seat to fold/operate properly. I was just about to shelve it and go look for a PPI FRX-456, when my neighbor suggested I flush mount it into the back of the rear seat. At first I was hesitant, but then I said "why not?". I mean Im going to reupholster all the seats anyway. So I pulled back the upholstery (its velcroed to the back of the seat), cut out a section of foam with a razor blade, cut a piece of MDF to mount the crossover to, mounted the crossover, dropped it into the section where I cut out the foam, returned the upholstery that now covers the crossover and the wood mount, and finally cut out a window in the upholstery to get to all the adjustment knobs on the crossover. Bottom line: Crossover is mounted/hidden and the rear seat operates just like it did when it left the factory. I plan to run all the wiring hidden in the upholstery. When I get the seats redone, I'll let the upholstery guy clean up my rough cuts and unfinished edges.
    By the time I got done doing all this, it got dark. And you guys know with my crappy phone there are no good pics. I'll see if I can swipe the wife's android phone when it is light outside and get pics for you guys.
    Mal
    Gear: [90%]
  9. #29
    Jul 2009
    Got some better pics:
    Mal
    Gear: [90%]
  10. #30
    Jan 2008
    the x-over looks so lonely in that huge seatback. maybe you should do the same thing with the amps?!?
  1. Integrate Solar Energy in your CarPC Project
    By hexxamillion in forum How to Power a Laptop
    Last Post: 11-26-2009, 09:58 PM
  2. Crowdsourced Map Data Collection, Mapping and Routing: project explained.
    By Heather in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 10-02-2009, 09:26 AM
  3. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 11:11 AM
  4. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 12:06 PM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
