Page 4 of 9 FirstFirst 123456789 LastLast
Results 31 to 40 of 82
Thread: Project "C++"
  1. #31
    Constant Bitrate 4ofakind's Avatar
    Jul 2009
    No, its hard enough getting to the adjustments on the amps as they sit now. Flushing them into the seat wont help. Plus keeping them low and somewhat out in the open helps with cooling in this Vegas heat.
    What is more likely to happen is one day I'll get a Bit One or Mini DSP mounted in the amp rack under the seat and shelve the Coustic altogether.
    Mal
    Vehicle: [100%] 1995 C 1500 ECLB
    Gear: [90%]
    Build: [80%] PC & Chassis, Worklog
  2. #32
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    This is coming along. Awesome!
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  3. #33
    Jul 2009
    Quote Originally Posted by hexxamillion View Post
    Thanks Hex.
    Some stuff came in so I can now work on my A-pillars. Hopefully I will have these done in a week or two.
    "Warning" the fabrication techniques demonstrated below are not to be tried by just anyone. If you choose to try this at home yourself, seek professional help. My wife is constantly trying to schedule me for counseling.
    Here is the start of my pillars. More to come.
    Mal
    Gear: [90%]
  4. #34
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Nice job !
  5. #35
    Jul 2009
    Epoxied these on. Tomorrow will do a little more.
    Mal
    Gear: [90%]
  6. #36
    Jul 2009
    Yesterday I test fitted these in the truck to see how hard it will be to get them in and how well I got the measurements. Was going to use the two part foam I bought but got the wrong type. Ineed a $300 application gun from 3M to use the foam I bought. Not going to happen. So I have to run down to HomeDepot tomorrow and get some $5 foam. Anyone need some $20 3M Foam?
    Mal
    Gear: [90%]
  7. #37
    Jul 2009
    Skipped the fleece and resin. Sprayed the foam, rough cut it with my mini hack saw, then sanded with 60 grit to get prliminary shape. Next will coat with plastic filler, sand, and paint.
    Mal
    Gear: [90%]
  8. #38
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    That really really sucks. I think I have read this same scenario several times on this forum. "I broke the panel while installing". They must be slippery little suckers or people are having too many beverages while working. A 10" Translative, Multi-Touch, DVI, LCD is a nice consellation prize though!!
  9. #39
    Jul 2009
    Quote Originally Posted by PhilG View Post
    Well to be honest I was not being carefull enough. At 6'3", I work better standing up than sitting down. I had just installed the mounting screws, and was flipping the bezel over to check/adjust fitment, when BAM!! it hit the ground. One of my screws was loose and my monitor slipped out.
    My Pixel Qi was a 10" Transflective, Multi-Touch, DVI, LCD. That's why I wanted to cry. But according to my budget, I should have another one by Nov 30 or Christmas. In the meantime I'm getting everything ready for when it arrives.
    I have been looking at this monitor though. 16" isn't too BIG is it? AOC 16" USB Monitor
    Mal
    Gear: [90%]
  10. #40
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Ummm, probably but that's your call! Remember, your eyes are only a foot away from it. If you have to move your head left & right to read text on the screen, it's probably too big!
  1. Integrate Solar Energy in your CarPC Project
    By hexxamillion in forum How to Power a Laptop
    Last Post: 11-26-2009, 09:58 PM
  2. Crowdsourced Map Data Collection, Mapping and Routing: project explained.
    By Heather in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 10-02-2009, 09:26 AM
  3. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 11:11 AM
  4. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 12:06 PM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
