Page 8 of 9 FirstFirst 123456789 LastLast
Results 71 to 80 of 82
Thread: Project "C++"
  1. #71
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by 4ofakind View Post
    Merry Christmas everyone!
    Small update: Yesterday I had some time so I finished up the wiring, installed the fuses, and ops checked everything. It powered up nicely and shut down nicely. Of course with my monitor broken i could see only the various status LEDs and they said all was well. I was happy.
    As for my center console, it has pretty much reached the limits of my abilities. I have it scheduled to go to a professional shop to finish it up. Of course pics will come when i get it back.
    Until then, be safe.
    Mal
    Merry Christmas to you too!
    Congrats on power it up! The other day I finally powered up both units, not at the same time, but individually. Because I didnt have the screen all installed, I didnt see anything either but the mobo LEDs.
    I hear you on the center console. I was going to try the fiberglassing, but in the end I went back to wrapping it. I did so though because my console is too big.
    Now I do have my new dash project though, decided building on top of the old one was to clunky. I want to do your foam idea to get the shape. What exactly is the product you used. Im sure you mentioned it, but I missed it. Also if I use the foam, is it easy to shape? My idea was to get the shape, then use a fabric stretched across that then resin. You think thats the right way to go?
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  2. #72
    Constant Bitrate 4ofakind's Avatar
    Jul 2009
    Quote Originally Posted by HiJackZX1 View Post
    I used Home Depot Gap Foam with the black cap. Resin on top of the foam after you shape it is the exact way to do it. On my larger console, I made the mistake of going straight to filler after shaping the foam. That may work for smaller projects; but not larger ones like your dash. The filler will crack without the support of the fabric and resin. It is not too hard to shape. If I can do it anyone can. For your larger dash just give it a day or two to fully dry before you try to shape. I used a mini hack saw to get the shape I wanted.
    Mal
    Vehicle: [100%] 1995 C 1500 ECLB
    Gear: [90%]
    Build: [80%] PC & Chassis, Worklog
  3. #73
    Jul 2007
    Miami
    Mal
    So let me ask.... If I use the foam, can I simply use fiberglass sheets and do it one piece at a time, or should I use one big piece. Using one big piece to stretch seems to be an issue for me. I have other projects that seem to not work well with the one piece method.
    4x 10inch Tablet
  4. #74
    Jul 2009
    Small update:
    I got a desktop monitor and hooked it up. So I am typing this reply from my truck.
    HiJack, in response to your question I am not sure we are on the same page as how fiberglass works. So forgive me if I offend. But step by step would be:
    1. Spray foam in desired location.
    2. Let dry.
    3. Shape with saw as desired.
    4. Strech or lay various pieces of fiberglass mat over foam shape.
    5. Spread even coat of fiberglass resin over mat pieces. Be careful not to get air bubbles in resin.
    6. Let dry.
    7. Repeat steps 5 & 6 as desired for structural stiffness.
    8. Sand.
    9. Add filler.
    10. Repeat steps 8 & 9 as desired for shape and smoothness.
    11. Paint or upholster.
    Hope that makes sense. I have been told multiple pieces of fiberglass mat helps reduce air bubbles as opposed to one large piece; especially since your final product will not be pool table flat.
    Mal
    Gear: [90%]
  5. #75
    Jul 2009
    Some Pics:
    The first pic is with the truck running. The last pic is with the truck off.
    Mal
    Gear: [90%]
  6. #76
    Jul 2007
    Miami
    You put the Car PC inside of a AMP case? Thats pretty cool!
    YOu think I can use Styrofoam to instead of the gap foam? That would be easier to work with.
    4x 10inch Tablet
  7. #77
    Jul 2009
    The thisg about the Gap foam is that if you drill a few tiny holes or scuff up your area first, it sticks and holds to your original piece really well. Styrofoam may not be resistant to resin and desolve slightly ruining your desired shape.
    Hopefully you are working with your original dash to fabricate. All my suggestions assume you are using your original dash in some way as a base to frabricate on. I have no idea how to fabricate a piece from scratch.
    Mal
    Gear: [90%]
  8. #78
    Jul 2007
    Miami
    No, Im starting from scratch. Actually using the dash was limiting my design ideas big time. Because the Durango has such an easy dash as far as assembly, it will be easy. It isnt like most dashes were the top wraps to the bottom and what not. I also took my Dremel to the top of the dash framing so all the curve areas are just about gone. So I have a very flat surface to work with. I'll keep you updated on it from my worklog.
    4x 10inch Tablet
  9. #79
    Jan 2012
    USA
    Black Truck Rollpan...?
    My project is progressing slowly but surely. I am waiting for some things to modify my dash for my Pixel Qi LCD. In the meantime I sent the truck to have the bumper fixed from the results of an inattentive driver. It should look like the black truck's roll pan by Wednesday.
    Mal
    Where Can you Find that roll-pan...that is the one i want.......What is the website...?
  10. #80
    Jul 2009
    Rollpans are practically everywhere. Google them. I ordered mine online then had it modified to hold my LEDs.
    Mal
    Gear: [90%]
  1. Integrate Solar Energy in your CarPC Project
    By hexxamillion in forum How to Power a Laptop
    Last Post: 11-26-2009, 08:58 PM
  2. Crowdsourced Map Data Collection, Mapping and Routing: project explained.
    By Heather in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 10-02-2009, 08:26 AM
  3. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 10:11 AM
  4. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 11:06 AM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 05:43 AM
