Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 1999 Malibu Wakesetter VLX (boat)
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    I'm about to drop my boat off for a full reupholstering and I got the itch again...
    Immediate system design goal:
    seamless control of non-vital functions
    integrated media
    --mp3, video, xm, ipod control
    ballast control
    -- 6 pumps 3 ballast bags (future plans to add one more bag and two more pumps).
    -- each ballast will be controlled independently by touching the corresponding spot on the boat icon
    -- option to fill all, empty all, and to stop all pumps via independent master controls
    non critical systems
    -- amp turn on
    -- lighting
    -- engine bay vent/blower on a timer
    -- touchscreen engine start
    future additions:
    rear view cam/dvr
    -- helps the driver keep an eye forward while monitoring the wakeboarder
    --dvr will be useful to critique runs
    integrated gps based speed control (perfect pass) to be adjust via ballast 'fill state' presets
    -- would like 3 skill level presets. one button would fill the ballast and adjust the speed accordingly
    code based engine start
    --punch in the code and crank the engine. (with hidden key override)
    System specs:
    mobo - ASRock A330ION
    hd - 60 gb solid state drive
    ram - 512mb
    os - win7
    front end - ride runner
    i/o integration hardware - (4) usb-io-1's
    i/o integration plugin - modified Sonicxtacy02 plugin (see skin design below)
    rearview cam - undecided
    soundcard -- usb dac -> jl audio rlc volume control/line driver
    Install info.
    -- install transreflective 7" xenarc in the insturment cluster. sealing the touchpanel to the newly designed abs facade to protect the xenarc lcd.
    -- aux sony RMX11M control of the pc. installed in the glove box lid or the rear seatback
    -- adding led accent/interior lights to the cabin
    that's the plan. im sure it'll grow as time goes on. but i'm going to try to keep my sights focused this time around.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    to simplify my life and assure getting my boat on the water by the end of may, i've decided to use the elite skin and modify it for my needs. here is a simple skin that i'll modify:
    the boat has a gps guided cruise control called 'perfect pass' the interface for this is a multi-line display with 4 membrane buttons to control it. Luckily for me the buttons are attached to the board using a common 5 pin header... soo usb-io-i will control this and that will allow me to flush mount the display screen from the gauge into my dash:
    That perfect pass system has a numeric tach and speedometer, this will allow me to delete the corresponding factory gauges, leaving me with 5 smaller gauges to graft into the cluster. fuel, engine temp, oil pressure, depth, and voltage.
    here is a mock up of how it'll all look when it's done.
    that's it so far. i have most everything i need now so i can start hacking away
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    started with the gauge cluster mod last night. first thing i had to do is make the gauge 'pods'
    first thing was to separate the abs trim from the gauge:
    I got four 3" abs couplers from the hardware store and cut them at a a 15 degree angle
    im not sure if i want to have them recessed at an angle or extruded like my mock up. here is what it looks like extruded:
    here is another mock up (you can see the new abs panel 'blank' at the top of the pic.. that is what i'll graft the lcd screen and gauge pods into)
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    a little more progress last night. The joycon exr arrived last night.
    after a very simple hook up I started to map the buttons of my transom remote.
    some cool features. besides being able to control the media/music. a long press of the 'source' button will turn on/off the perfect pass. a long press of the 'volume up' and 'volume down' buttons will fill and empty all ballast tanks respectively. a long press of the 'off' button will turn off all ballast pumps
    oh... and all of the commands have an audible confirmation. ("perfect pass enabled", "fill all ballast tanks", "empty all ballast tanks" etc..) im sure it'll get old but it puts a smile on my face whenever i hear it.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    so my time has been split among a bunch of projects so this one is going a bit slower right now. The vride dash wouldn't fit so i had to scrap that idea and go back to my original dash piece
    the boat is ready for a complete rewire of the ballast pumps and future led wiring:
    here is the recessed monitor facade:
    The monitor will now sit about 1" back from the gauge panel
    here is the really rough mock up (not filled/sanded) of how it'll look in the dash
    i hit a wall with gauge placement though. im not sure if recessing the gauges will make it harder to read, yet i'm not really feeling having them surface mounted like they were originally on the boat.
    im also not sure if i want to have 3 small gauges on the left and then the perfect pass 3" gauge on the right or two small gauges on each side of the monitor and seeing if i can sneak the perfect pass multi line display below one of them.
    im leaning toward something like this (but not having the gauges pop out as much)
    if anyone has any design ideas (no matter how off the wall) please chime in. im at a stand still on this
    ---------- Post added at 07:28 PM ---------- Previous post was at 07:27 PM ----------
    got some more geek time in today.
    here is the usb-io-1's hooked up to some heavy duty relays.
    well mostly wired up at least. still need to run power and ground and need a distro block. the yellow and blue wires that are just hanging there are for a future pump if i ever decide to add a bow bag. I will be making a plastic cover for it to protect and hide all the wiring as well
    the big white wire looms on the left go to the ballast pumps. each set has four wires. the blue wires will be connected to a fused constant 12'v. the yellows are connected to the + leads that attach to the pump. the white wires go to the usb-io and will switch the relays, the black is ground
    here is another gauge cluster pic. this one shows the ultimate layout and some more of the filling/sanding of the screen:
    i decided to go with a recessed gauge, in the end i think it looks the cleanest
    still need a few more rounds with the sanders but it's getting closer.
    you're looking at the raw abs right now, the monitor's housing is made from a light gray abs and i've been sanding the crap out of the whole piece so that's why it has that dirty matte look and the different colors
    here are the stock gauges just placed in there. im contemplating installing them behind the holes instead of on top, but the way they are now allows them to be easily replaced:
    i still need to add the perfect pass multi line display and a depth finder display
    it's hard to photograph it and make it look good in this state, but up im pretty happy with the progress so far
    ---------- Post added at 07:29 PM ---------- Previous post was at 07:28 PM ----------
    haven't updated this in a little while but have made a lot of ground on the project.
    ok, so onto the good stuff
    Here is more work on the gauge cluster; im still not happy with it, the recessed screen is a !@#$! to sand in the corners.
    i also received this today:
    short youtube video of what it does
    and now the homebrew mtc will get a Power Wedge controller
    This was actually a the hardest part of the build so far. i dont want to, nor have the time to make my own ic board; yet, i need to flip the polarity in order to move the wedge up and down. Ii figured out how to do it with the usb-io and 4 additional 40amp fuses. the nice part about this; i can run low voltage wire (cat 6 or even telephone cord) from the usb-io under the dash, and have it control the relays placed close to the wedge and batteries.
    not sure if anyone will be able to make sense of my chicken scratch but here is the "schematic":
    i also have gotten into seriously modding the "elite lite" skin for our purposes:
    I'm trying to create the skin so that it'll be as painless as possible for you guys to quickly incorporate it into your own system too. should be only a few files and one folder to place in the correct spots.
    (ignore the stretching, the screen is an old 4:3 monitor, the touchscreen that will be installed in the boat is a 16:9 aspect ration and everything will resolve itself
    Main menu-
    ballast button: will bring you to the main ballast screen
    wedge button: will bring you to the power wedge control screen
    perfect pass button: will bring you to the perfect pass control screen
    lights button: will bring you to the light control screen
    power button: short press will toggle the perfect pass on/off, long press will start/stop the engine
    audio: brings you to the elite skin's audio screen. long press will bring you to the video screen
    wake preset: brings you to the wake preset screen
    Ballast-
    short press will toggle pump on/off
    long press on any of the 'FILL' buttons will turn off all empty pumps (if any are on) and turn on all fill pumps for 8 mins (or any predetermined amount of time)
    long press on any of the 'EMPTY' buttons will turn off all fill pumps (if any are on) and turn on all empty pumps for 8 mins (or any predetermined amount of time)
    Power Wedge-
    retract button: will raise the power wedge to it's stowed position
    up arrow: will manually raise the wedge (momentary switch, it will only move the wedge as long as you're pressing the button)
    down arrow: will manually lower the wedge (momentary switch, it will only move the wedge as long as you're pressing the button)
    "large" button: will reset the wedge to the lowest position, then raise it to the highest position of it's functional range (based on time)
    "medium" button: will reset the wedge to the lowest position, then raise it to the middle position of it's functional range (based on time)
    "small" button: will lower the wedge to it's lowest position
    Another forum member and I are brainstorming ways to have a position sensor so that we can turn this into a 'smart' system instead of a blind one. more to come on that in future posts.
    Perfect Pass-
    up arrow/down arrow will adjust speed setting or scroll through menu options (same as stock multi line display)
    stargazer logo will access the menu
    power button will toggle the power on and off (also accessable from the menu screen)
    gps speed will be displayed but derived from the computer's gps dongle, not the perfect pass
    Wake Preset-
    one touch control to set ballast, wedge and perfect pass speed automatically
    Audio screen-
    This is the skin's default audio browser.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Nov 2008
    I'm a boarder myself, and this is sik. I especially like the Wake Presets, awesome idea.
    Is it going to be finished in time for the summer season?
    I've always considered a split wedge, so the 2 sides can automatically work independently, to keep the boat level on the straights, I see you just bought a wedge, but something to consider anyway.
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by badmonkey23 View Post
    thanks. didn't even think anyone was looking at this thread.
    I plan on having it up and running by the end of the month. at least v1.0. im sure i'll have to make some changes after real world interaction with it. the biggest hold up is the upholstery shop. they f-d up big time on my cushions and im having them redo everything. :\ they had to call in a specialist so im crossing my fingers that it'll get done sooner then later
    I decided to go with the power wedge because the foil was designed and tested by engineers; clearly, that isnt me.
    does your boat not stay level on the straights? the wedge is made to shape the wake and give it a little more size. i dont think it has any thing to do with aiding plaining of the boat. i believe what you're thinking of are trim tabs
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jan 2008
    i have been watching as well-- my families got a 1980-something ski boat(i think it's 16ft), and while we really only ski or tube behind it, i'm always interested in different applications for pc's..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Nov 2008
    It would mainly be for when people move around in the boat. Trim tabs are similar, but I'm guessing they'd disturb the wake, and lift the boat slightly out of the water, a submerged split wedge would do the trick.
    I'm in Oz, so we're about to go into our winter season, with all the floods we had we only got about 3 weeks on the water all summer.
    Dec 2004
    Los Angeles Ca
    interesting idea
    here are some videos of it in action:
    interface:
    http://www.youtube.com/watch?v=74w99EZpVxA
    power wedge:
    http://www.youtube.com/watch?v=4avDfYhNS18
    http://www.youtube.com/watch?v=6iBffNrzTnM
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. AUX location in my 1999 Malibu
    By superjavs1 in forum General MP3Car Discussion
    Last Post: 07-03-2008, 11:36 PM
  2. 02 Malibu Stealth
    By bandican in forum Worklogs
    Last Post: 04-03-2008, 08:09 PM
  3. Malibu ECM/ECU Questions
    By LuangTom in forum Off Topic
    Last Post: 07-31-2006, 07:51 PM
  4. My 1998 Malibu
    By SuperMatty in forum Show off your project
    Last Post: 10-03-2002, 01:42 PM
  5. LCD for Malibu dash
    By Zip-Lock in forum LCD/Display
    Last Post: 10-29-2001, 10:24 PM
