Page 10 of 25 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 250
Thread: Samsung Galaxy 10.1 custom Civic install, Actual Build Started on Page 18
  1. #91
    Aug 2011
    By the way guys, do you all know how I can tell if I have touchwiz or not?
  2. #92
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    yes.. I'm sure there's a setting in there that allows it to mirror its output via hdmi. On my Gingerbread its in settings / display / tvout. I'm sure its something similar on yours.. let me know :-)
    Steve
  3. #93
    Feb 2004
    Manchester
    From what I remember when I had my 10.1, before touchwiz4 was released it was missing alot of the widgets.. I would also expect to see it in the settings /about tablet or something like that.. will say 3.1 touchwiz maybe.
    Steve
  4. #94
    Aug 2011
    Shoot, I knew I should've brought it' to work with me. WHy do I have to work today! I wanna go home and work on this! Grrr!
  5. #95
    Feb 2004
    Manchester
    To enable TV-Out, go to Applications > Settings > Sound and display > TV out. By the way, the TV system in Malaysia is PAL.
    When TV-Out is enabled, the sound will come out from the TV speaker making watching movie using Samsung Galaxy S a different experience.
    I know this is for the phone.. but this would also explain why you didn't get any sound when you tried it. :-) You just need to click an option on your pad...
    Steve
  6. #96
    Aug 2011
    Thanks for the find. I was looking for stuff like that last night, but was not seeing it. Again I was tired, and maybe i just didn't pay attention very well. SO I'll try and find everything tonight and see where I'm at then. Wow man, thanks for all the help. It's easing me a little bit. I'll feel better when I get home, find this stuff, and plug it back in and it works. Wish I was home now!
  7. #97
    Feb 2004
    Manchester
    you will be up and running within a few mins.. :-) good luck
  8. #98
    Aug 2011
    I just got on "The Galaxy Tab Forum" and searched display settings and found a few different threads on what you said for the Galaxy 7 tablet, but none for the 10.1. So I'll check it out when I get home, like I said, and hopefully it's there. If it is, then that should, SHOULD, solve the problems and I should be up and running and doing back flips in my hallway, much to my daughters's enjoyment! I can just see it now, "again, again daddy, again again!" My biggest fans! :0)
  9. #99
    Oct 2004
    NY
    have you tried the hdmi directly into an hdmi tv? I'd try to confirm the hdmi output alone straight to an hdmi device before bringing the converter & all else into the mix...
  10. #100
    Jan 2008
    the galaxy s phones go into "fast charge" more when connected to the original charger. Iirc the way it does that is by shorting the data pins and the phone recognizes that
    Quote Originally Posted by Scott Carver View Post
    Ya I did that. I actually disconnected it when I found out it wasn't charging and just plugged in the regular wall charger. Then I got a charge on it, but still no output. Maybe I'm not doing this right. I'm trying things like Pandora, and Netflix, cause to me an audio and video signal is an audio and video signal. So maybe I have to go through a different application in order to play these, but that would then make the reason for getting a tablet null and void cause that's part of the whole purpose I got one was for streaming video and radio.
    At least I thought I did the wall charger. I'll have to go try it again tonight. I was so brain fried last night between being nervous about setting it all up, and then it not working I was frustrated. I'll post up pictures of what I did, and maybe someone has an idea of what to do next.
  1. Samsung Galaxy Tab 7" Commodore Install
    By alexb2710 in forum Android Tablet
    Last Post: 10-25-2011, 12:53 AM
  2. Galaxy Tab in 06 Civic Si
    By mich1248 in forum Android Tablet
    Last Post: 08-10-2011, 01:52 PM
  3. Samsung Galaxy tab 7 in 06 Audi A4
    By crs9 in forum Android Tablet
    Last Post: 06-30-2011, 04:05 AM
  4. A New Direction (Samsung Galaxy Tab)
    By PrayingWithFire in forum Newbie
    Last Post: 01-19-2011, 02:26 AM
  5. Samsung Galaxy Tab 7.4 x 4.7in tablet
    By RipplingHurst in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-26-2010, 10:54 PM
