Page 19 of 25 FirstFirst ... 910111213141516171819202122232425 LastLast
Results 181 to 190 of 244
Thread: Samsung Galaxy 10.1 custom Civic install, Actual Build Started on Page 18
  1. #181
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Quote Originally Posted by Scott Carver View Post
    Hey everyone, I'm back at this power thing. Can I run the charger for the tablet, and the power for the converter of the same Point Of Load module?
    I gotta keep it real here. I know with the normal drama of handling power with typical CarPC's can vary quite a bit and makes for much chatter. I have had my Samsung tablet since the end of the summer and leave mine on all of the time. I don't have it connected to any power or ignition wiring. My battery charge lasts from 3 to even 5 days without needing to charge it. That's with internet music streaming and all the other data stuff like twitter, facebook, market updates, etc. All I do is have the brightness auto adjust plus I timeout the display and enable power saving mode. I turn off bluetooth, wifi, gps and only enable when needed. (Tasker app is your most bestest friend in the whole wide world
    The simplicity of powering is one of the many reasons why I went to the tablet and ditched my carpc build. So my answer to your question from my own personal experience (can't speak for others) I say simplify your design on power...and maybe even not worry too much about it.
    "Live Free!!!...It's all about Open Source"
    Current Proj:'09 Altima In-Dash Android Tablet and System Upgrade
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #182
    Aug 2011
    Ok, that's a good point. It does seem to go for days without needing a charge. I still need to power the converter though. So I guess I'll stick with the P O L i have and use it for that. Thanks man. I'm planning on getting that thing done and ready for install next week while I'm off. Maybe I can get it installed, even thought he rest of the system won't be anywhere near done. Lots to come that's for sure.
  3. #183
    Aug 2011
    I was thinking about it last night and I have to have a power source to the tablet. I have to have it for the HDMI to work! So I need a charger up front. So I guess I'm back to my original question. Can I run them both off the same POL or do I need one for both, or should I go with a bigger device?
  4. #184
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    What type of adapters do these thing use? Can you simply use a USB car adapter? I have a Mi-Fi in the car with mini-usb connector. The Mi-Fi has its own battery, but i wanted to keep it on 24/7. It only lasts 4 hours on battery, So I bought a 5V 1amp USB car charger. So far the Mi-Fi has been on for almost 1 month.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  5. #185
    Aug 2011
    The tablet has a usb to 30pin connector, and the converter has a barrel connector to it an goes to a wall plug. Both are 5v after testing, and I'm not sure of the watts on it.
  6. #186
    Jul 2007
    Miami
    I dont think its the watts you want to look for. Its the Amps. Say for example my Mi-Fi requires 500 mAmps at least to charge. So I paried it with a 1 amp charger. I took my numbers from the device of the wall plug itself, it should list it there.
    4x 10inch Tablet
  7. #187
    Maximum Bitrate PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Just for reference, watts is a measure of power which is amps x volts so it is related and although more commonly rated in AC circuits, does apply to DC as well. If the voltage is a fixed number which in this case is 5v, and the current requirement is 500mA, then finding a supply that outputs 2.5w is the same thing as a device that is rated at 500mA. Just thought I would clarify this.
  8. #188
    Aug 2011
    Thanks for the info.
  9. #189
    Aug 2011
    Dang it, I forgot to update this forum. I've been on my other forums updating and not doing all the audio over here, so I forget to post the tablet portion. I'll catch everyone up right now!
  10. #190
    Aug 2011
    Ok another day in the books. Not nearly as much done as I thought I'd get, but I'm pretty pleased with the progress. I can see things coming together.
    First up I started Version 2 of the tablet pan. The more and more I look at this and think about it, the more and more complex it seems. But I'm gonna keep working at it. Here we go.
    If you will recall, I was going to use the docking station for this. After taping it up, and looking at it I decided not to do it that way. I decided I would just use the base part of it, and cut it in later. Thankfully I decided this after tape and not after glass or there'd be a version 3.
    Time for glass! ALl my materials, including my coffee! Let's go for it.
    Got some wax on it this time to help with the separation after drying.
    Then I started the glassing process!
    2 layers!
  1. Samsung Galaxy Tab 7" Commodore Install
    By alexb2710 in forum Android Tablet
    Last Post: 10-24-2011, 11:53 PM
  2. Galaxy Tab in 06 Civic Si
    By mich1248 in forum Android Tablet
    Last Post: 08-10-2011, 12:52 PM
  3. Samsung Galaxy tab 7 in 06 Audi A4
    By crs9 in forum Android Tablet
    Last Post: 06-30-2011, 03:05 AM
  4. A New Direction (Samsung Galaxy Tab)
    By PrayingWithFire in forum Newbie
    Last Post: 01-19-2011, 01:26 AM
  5. Samsung Galaxy Tab 7.4 x 4.7in tablet
    By RipplingHurst in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-26-2010, 09:54 PM
