Page 24 of 25 FirstFirst ... 141516171819202122232425 LastLast
Results 231 to 240 of 244
Thread: Samsung Galaxy 10.1 custom Civic install, Actual Build Started on Page 18
  1. #231
    Aug 2011
    Ok little update. We've decided to keep the civic, according to my wife, and pay it off. That's 3 more years. So, now the build is back on, only I'm using different stuff now. The tablet remains the same, and the head unit may change. I'm looking into a new pioneer DEH-P9400 and if I can get my hands on that, I may actually do a faceplate extension with it as well. Not sure. We'll see. But the build will be back on soon. Sorry for the delay!
  2. #232
    Low Bitrate TxAxZxZ's Avatar
    Dec 2005
    FWB, FL (but currently in Belgium until 2016)
    Quote Originally Posted by Scott Carver View Post
    And there it is! IN! With hot glue for now, but it's in!
    Hello Scott. I've been reading your worklog the past couple days. Nice work! I have a question regarding the dock. You mentioned that you temporarily mounted the dock to the bezel with hot glue. How do you plan on making it permanent? I am wanting to make my bezel (cradle) this weekend for my SG Tab 2 7.0. I dismantled the cradle from the dock because the cradle has too much of a gap to have a nice clean line (see pictures below). I'm thinking I might glass the cradle while the tablet is docked so I can make it one piece. I figure I'll have to get some putty or something to surround where the connection is so I don't get any resin into the connector. What do you think?
    Dock with cradle attached. Notice the big gap?
    Dock without cradle.
    JeepTablet Project
    - Design <<<100%>>>
    - Construction <<<70%>>>
    View My Worklog
  3. #233
    Jun 2012
    Scott, if you're still around on these boards.
    In post #193 on page 20 you show your before and after shots of your dashboard bezel. It appears that on the original bezel you had an AC vent on the left side of the double din stereo section? Is that correct?
    If so you cut way into that portion of the bezel to make room for the length of the GT. If it is an AC vent how do you plan on fixing that section to still pump out air to the car?
    It's a problem that I will most likely run into with my GT install on my 05 Xterra.
  4. #234
    Aug 2011
    So last month we were keeping the car, the beginning of this month we were selling it yet again. Now we're keeping it for real I guess. At least till it's paid off, as I said before. So the build is back on, but it's only come about in the last couple days that we've decided this. So nothing has happened. Matter of fact I'm kind of back to scratch with it a little bit. By that I mean I threw away all the extension pieces, LIKE AN IDIOT, for the face plate extension etc. So I'll have to get back to that starting over. I'm still undecided on if I'm going to get a new head unit. I'm ok with tearing into the Alpine unit cause it's old and I got it for a steal when I bought it. But if I go out and spend a couple hundred dollars, which I don't have, on the new pioneer unit, then I'm not sure I wanna go tearing into it. I'm just not sure yet. If I get a new Pioneer Unit it will be the DEH-P9400BH. The link will show you what all it has. It would give me everything I need.
    But to everything else, it's all back on. I still have the dash bezel that I started making and everything else. I'm going to probably do some alterations to the bezel, cause after thinking about it, and looking at other sites etc, I think I can do it better this time. I'm also going to be incorporating a pocket in there to slide in my phone, Samsung Galaxy Nexus, as well since I'll be using it as my wifi hot spot etc. I still have to figure out where I'm going to relocate my HVAC controls too, and as well, where I'm going to put the face plate.
    My thoughts before, and I'm going off memory and what the bezel was turning out to be, was that the HVAC controls were going to go in the head liner, and the face plate was going to go under the tablet. I think this will remain the same. I'm also thinking the HVAC controls may do good in the pocket in the center console as well though. So I'll explore and see where I go.
    Sorry guys for not responding sooner. I didn't get any alerts. I'll have to check that out.
    Quote Originally Posted by TxAxZxZ View Post
    I'm not 100% sure what you're asking me, but what I'm seeing is that you don't want to use the cradle you want to do a fiberglass pan or surround and you're worried about the contacts getting resin in it? The way I did it was did the fiberglassing first, then I cut in the cradle dock. This way you don't have any resin around it. Once I put it in there, I hot glued it, and that's the way it sits now. It needs to be moved a little more now though, cause the contacts barely touch. So once I get all that finalized, I'll either use resin or CA Glue or epoxy to get it in place. Not sure if that helps. Hopefully it does, but if not, let me know and we'll figure it out together.
    Got a build log? I'd like to follow along with you if it's ok with you.
    Quote Originally Posted by larue05 View Post
    I have a total of 4 vents on my dash. One on either side of the steering wheel, which includes the one I cut into, and then two on the other side of the dash, next to the bezel on the right, and another one on the far right of the dash. To me, and this is just my opinion, 4 are too many for this small car. So I'm going to cover up the duct, and then it should push more air out of the other three. My A/C cools off the car pretty damn quickly too. So I'm not worried about it. That vent that's getting closed off, is where the phone is now going to. It's in pretty direct sight of me, and it's damn near the perfect spot for it too!
    Again guys, sorry it took so long to get back to you, I'll go check my settings now. I should have some progress soon on this stuff. I'll update when I do. Thanks guys!
  5. #235
    Dec 2005
    Thanks Scott. I was referring to fiberglassing the bezel and dock at the same time. I got past that checkpoint using a little bit of your ideas. I added my worklog to my signature. Good luck and hopefully you don't have to redo too much
    JeepTablet Project
    - Design <<<100%>>>
    View My Worklog
  6. #236
    Aug 2011
    Thanks, me too. We'll see how it goes.
  7. #237
    Aug 2011
    Ok so to kick this bish off, I got some new parts today. Nothing big, but lets see what the mailman delivered to me today!
    Not a very big package.
    What is this some kind of joke!?!
    Well I have to say they were wrapped up really well!
    Mmmmmm volt meter candy!
    Front and Back
    So I got two cause I wasn't sure if I would get a difference in hooking them up one to the alternator, and one to the sub amp. I thought maybe I'd see different settings. Besides that, they were cheap enough, that if I can't run them that way, or won't see a difference, then I can use one for the truck!
    But this will help me in continuing the tablet install.
    That's all for now!
  8. #238
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    So what are those parts for?
    "Live Free!!!...It's all about Open Source"
    Current Proj:'09 Altima In-Dash Android Tablet and System Upgrade
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  9. #239
    Aug 2011
    Well, I"m going to have 4 amps, a few batteries, and lots of power, so I want to be able to watch my battery voltage. I got one for the power system, and I got one to put at the sub amp to see the draw on it. Make sure it doesn't drop below 12v.
    Here it is in action:
    Obviously I need to dial it in, but you can see how it looks. I think it's very subtle. Not too bight and yet still very clear! I like it alot, and it was cheap which is even better!!
  10. #240
    Aug 2011
    So I have some news guys. The install is stopping at this point. My wife and I have decided to sell the car and try to get a new one. However, that being said, I'm going to do the tablet install in the truck I'm currently starting a build on. When that starts, I'll go ahead and link it over here, and start a new thread. Thanks for your patience guys! Hopefully it won't be long till that starts!
  1. Samsung Galaxy Tab 7" Commodore Install
    By alexb2710 in forum Android Tablet
    Last Post: 10-24-2011, 11:53 PM
  2. Galaxy Tab in 06 Civic Si
    By mich1248 in forum Android Tablet
    Last Post: 08-10-2011, 12:52 PM
  3. Samsung Galaxy tab 7 in 06 Audi A4
    By crs9 in forum Android Tablet
    Last Post: 06-30-2011, 03:05 AM
  4. A New Direction (Samsung Galaxy Tab)
    By PrayingWithFire in forum Newbie
    Last Post: 01-19-2011, 01:26 AM
  5. Samsung Galaxy Tab 7.4 x 4.7in tablet
    By RipplingHurst in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-26-2010, 09:54 PM
