Page 4 of 25 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 250
Thread: Samsung Galaxy 10.1 custom Civic install, Actual Build Started on Page 18
  1. #31
    Jan 2002
    Philadelphia
    So to be clear if I went with the DCDC I would need 2 of them. 1 for the tablet and 1 forthe converter right?
  2. #32
    Oct 2004
    Israel
    Which converter? does it need 12V?
    If you need both 5v and 12v I think you should go for something like the m4-atx ( or whatever car-pc psu you want )
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
  3. #33
    Aug 2011
    Ok so back on subject with my build and research. I've been looking at the M2-ATX like you suggested a couple pages ago. I'm trying to figure out hook up on it and I have a theory but Im not sure if I'm correct. Can you look it over and confirm for me please?
    Here's my little diagram. My confusion comes in a where do I install the converter power at?
    J1 - Battery Positive
    J2 - Now if I wanted to power a 12v something off this, the J2 is where I'd do it from correct?
    J3 - Ignition or Switched Power
    J4 - Ground
    J5 - "Goes to Led". I could put an LED up front to tell me power is going out. Correct?
    J6 - This has two pins "Remote and Ground" so the remote would go to my bit one remote in and the ground to ground
    J8 or J9 - Which of these, or do both of these go to the power. I'm guessing cause it says on the J9 of the manual says "optional, J8 is in parallel with J9". So does that mean if I wanted to I could run the power for the Galaxy from the front to here and it would power the converter and the charger for the Galaxy? Also I'm thinking I can use this or something like it to plug directly into the converter, and wire it to J9 or J8.
    Also for this, what pin should I use for Offdelay/Hardoff? I'm guessing A which is 5sec/45sec. Does this basically mean that when I turn off the car it will take 45 seconds to turn off the converter or charger? If I use no pins, it will turn on when I turn on the car, then turn off when I turn it off?
    Here's my little diagram. Can someone confirm this please?
    I just sold the stuff today to give me the money for this project. As soon as I can pay off the credit card with it, I'll be buying it all.
  4. #34
    Oct 2004
    Israel
    Quote Originally Posted by Scott Carver View Post
    Correct.
    Possible , You can also get it from the J7 cable - I don't think it really matters for your use
    Correct.
    J4 - Ground
    Correct.
    Seems right.
    You don't need to connect the gnd , only remote
    NO. it's just a momentary switch it doesn't supply voltage... To get 5V you would have to find the 5V pins on the J7 cable - You can use J8/J9 if you want to wire the tab's power hardware button for example
    If you don't connect the power button then the only way the tab will be aware of the ign switch is by charging/discharging.. From the manual it seems that the m2 cannot be connected via usb to change the settings ( unlike the m4 ) so you would have to go for P1 and wait a full minute before the tablet will not be supplied with power and go to sleep , Or use P0 and figure out how to start the m2 with the ignition ( the m4 in this state waits for a button push on motherboard pins as far as I recall but its seems that the m2 acts a little different so you will have to figure this out )
  5. #35
    Aug 2011
    Ok so using a DMM I could just ground one and then go along the tabs till I find the 5v one right? Or is that too simple?
    Lost me on the "tabs hardware button" part. Sorry
  6. #36
    Aug 2011
    Would it be easier for me to just get a small power inverter instead of using this?
  7. #37
    Oct 2004
    Israel
    Yeah
    you can also find the pinout and make your search a little easier
    I don't know how to explain the tab's hardware power button thing better
    What I'm going to do is to open my nook and extend the hardware buttons , the power button will be connected to the motherboard switch and will control the sleep/wakeup of the tablet
    Some things on my install require me to be able to charge the tablet when the car is not in use ( when I use USB-HOST I'm draining the battery even when its charging ) and I'm planning to continue charging about 5 hours after I shut the car down ( In a later part I'll be using the DCDC-USB usb connection to send a hard-off command to the power supply when the nook's battery is full )
  8. #38
    Aug 2011
    WOW! That's awesome man, I was just looking around for that. Thanks! So there's basically several 5v power sources in there. Just pick any one correct?
    So with the hardware tab button you're basically saying, crack open the tablet, and extend the wires out? I don't think I wanna go to that extent.
  9. #39
    Oct 2004
    Israel
    It will defiantly be easier , but the audio part might be messed up - power inverters are a big cause of trouble and can cause ground-loops and alternator noise( just search the forum )
    You can use a cheap 12V and 5V converters with the current rate you need
    But I don't know how reliable it will be ,
    And if it will be eventually cheaper because you need both 12V and 5V stable from what you told me..
    Look at the power-supply section , maybe the folks there can recommend you a more suitable and "tailored" solution
  10. #40
    Oct 2004
    Israel
    yeah , use one of the +5VDC ( +5VSB is the standby voltage - if you plan to connect something to it make sure it doesn't need more than 1.5A )
    and one of the COM ( black ) which is GND
    About the hardware button , Exactly
    And I didn't think you would that's why I haven't really suggested it
  1. Samsung Galaxy Tab 7" Commodore Install
    By alexb2710 in forum Android Tablet
    Last Post: 10-25-2011, 12:53 AM
  2. Galaxy Tab in 06 Civic Si
    By mich1248 in forum Android Tablet
    Last Post: 08-10-2011, 01:52 PM
  3. Samsung Galaxy tab 7 in 06 Audi A4
    By crs9 in forum Android Tablet
    Last Post: 06-30-2011, 04:05 AM
  4. A New Direction (Samsung Galaxy Tab)
    By PrayingWithFire in forum Newbie
    Last Post: 01-19-2011, 02:26 AM
  5. Samsung Galaxy Tab 7.4 x 4.7in tablet
    By RipplingHurst in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-26-2010, 10:54 PM
