Originally Posted by
papinist
Thanks for the tip.
I am not yet sure how I want to set up the power source: at the moment the tab is connected to switched +12v, so it is powered when car is running, and uses its battery when car is off. In this case it's ok to let the tab check and connect a2dp device when engine starts.
But I'm evaluating the possibility to hardwire the tab to permanent +12v so it could be up and running all the time, letting me do remote control even when car is off, at parking etc. For this to work, I have to 'detect' the car state to connect a2dp device and start/stop music. My idea was "when the tab finds Belkin BT device - or when that device asks to connect - the car is ON so: connect BT device (a2dp and obd2), start music, airplane mode off etc"
I understand that standard a2dp devices did not connect itself to the tab - except the TuneLink? Perhaps I should try to let tasker check every 5 seconds if a2dp device is found, and if yes.. start the "car on" task.
