Results 1 to 3 of 3
Thread: '05 Rav4 - Project nagao
    Jul 2010
    Fore-Warning
    I am NOT mechanically inclined nor am I good at woodworking or anything of the such.
    Project Nagao - Not As Good As Others
    * Wish I had some of the skills for fab/etc *
    Hardware
    Mobo: AMD dual core fusion w/ integrated gpu (it's been so long since I ordered it I can't remember exact specs, but it resembles/rivals dual core atoms)
    HDD: 2.5" 80gb sata
    Power: M4
    Ram: 8gb's (only using 4 though for os)
    OS: Win7 32 bit ultimate/pro edition (forgot edition, but it's not home)
    Wifi: Usb N-adapter
    GPS: I-blue gm-2
    F/R amps: 2 cheap 500 watt amps from China
    F/R speakers: Stock
    Sub amp: Can't remember, it's an old spare from a long time ago (no more than 500-700 watts max though)
    Subs: 2 shallow mount Power Acoustik 13" 700 watt subs. They have a mounting depth of only 2".
    I wanted to create something that allows me to keep the maximum amount of trunk room. I never enjoyed the big boxes and subs once I grew out of those first couple years of driving. I enjoyed the trunk space once I finally got this vehicle about a year ago. So I started planning a box to house anything in and it only had 1 restriction: NO more than 4" high total.
    Then came box building. Pointing to the warning again, I am absolutely horrible with doing this stuff myself, but I can always think of the good ways of doing things. But alas, I tried my hand at it. Built the box with the middle space for pc, power supply, fan, 2 f/r amps, wifi, cable runs, and other wires. The 2 outside areas are for subs, mounting at 2" and 13" wide they just barely fit. The area underneath the subs/pc is a little compartment I used for housing the dist. blocks and some other wires. It's used to store some parts/tools right now.
    The plan at some point is to carpet it as I think it looks pretty rough with just the wood look. I also need to find something to do with the sub amp, as it just sits out for now to the side.
    The wires - I ran 0 gauge to the battery for 12v+ and 0 gauge to ground at a bolt in the trunk area. I had a local shop drill/grommet through my unused clutch plates to get the 0 gauge to the engine compartment as I would never trust myself doing that.
    Concerns/Things to fix:
    1. Alternator whine (it sounds like it comes outta my front driver speaker only though) - Local shop talked me out of running the ground 0 gauge to the battery and it sits at a bolt in the trunk. Not sure if this caused an issue or not yet.
    2. F/R speakers (It sounds like only the front passenger speaker plays music) - I'll run through my f/r amps + wires soon. It worked on a previous temp install, so I know it should work if it's hooked up right.
    3. Subs gone crazy. This is a wierd one to explain, but every so often, the subs just start pounding really really fast, on their own, without being in tune with music anymore. Turning music/sound down does not stop them either. They only stop when turning the amp dials down. It's not specifically the gain or frequency that does it, it's a combination. I'm wondering if it's cause I had to wire them in mono? I don't know much about wiring subs, but if I had the screws for the amps, I would have wired them normally, 2 channel...
    Things planned:
    1. Hidden valet switch for the remote wire on the aftermarket wire harness (disables everything in the trunk - comp, amps, subs/amp)
    2. Usb ports in front panel (already have extensions, just need spare plastic covers)
    3. Carpet box in trunk to match grayish carpet already in there.
    4. Misc. fun+extras (led lights for the box, sub grills/covers to protect them, inverter in case of ac circuit ever needed, etc...)
    This has been a build long in the planning stages and at this stage, about 85% done. With my fun budget well beyond blown, this is where it sits for a while.
    ** Pics ***
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
    Jul 2010
    Got some pics uploaded finally.
    Also, did the connect/disconnect of the f/r left/right rca's at the amp and found that both the front speakers were playing while the rear ones weren't. Maybe I got something mixed up on the rear amp, but it's disconnected for now and not a big deal. More to come soon I hope!
    Dec 2005
    Raleigh, NC
    That looks like a rat's nest and it's only inviting something to bounce around and short out. You should mount your computer hardware and clean up your wiring a bit.
    "You're just about as useless as JPEGs to Helen Keller" - Wierd Al
  1. First Project - Rav4
    By Ghostgum in forum Newbie - Proposed setup
    Last Post: 12-07-2010, 04:41 AM
  2. Turbo my RAV4, need help
    By almc2242 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-18-2007, 02:40 AM
  3. Does an '06 Toyota Rav4 have an accessible CAN-bus?
    By Bigestlee in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-14-2007, 02:04 AM
  4. Wants to Put a Computer in My Rav4
    By wengkun in forum Newbie
    Last Post: 10-16-2006, 07:58 AM
  5. Anybody ever try a carputer in a newer model Rav4?
    By SmartBeaner in forum General MP3Car Discussion
    Last Post: 09-22-2005, 12:53 PM
