Page 10 of 14 FirstFirst 1234567891011121314 LastLast
Results 91 to 100 of 136
Thread: 2004 VW Jetta GLI CarPC and more
  1. #91
    Constant Bitrate cazzz's Avatar
    May 2012
    Florida
    Here are some pics of my radio cage and disassembly of my Xenarc 8" LCD.
    Monitor came apart easily by removing the four corner screws and prying the back off.
    Disconnect the speaker wires from the motherboard and move the back out of the way.
    Disconnect the button board, I left it mounted in the case for now. I will attempt to remount in the car. According to Xenarc the LCD panel will work without the board attached.
    Remove the six screws holding the LCD to the front of the case and it is now apart.
    I need to modify my radio cage by removing a portion of the top shelf.
    I still think I am on the right track using the 8" LCD panel. Looks like it will fit perfectly.
  2. #92
    May 2012
    Florida
    Originally Posted by AZN dubs
    this is amazing. i want to add sound deadening material throughout the entire car because i took my rear seats out and they did block some of the sound.
    you're like mad mike from pimp my ride with all of that electronic stuff in the trunk
    Read all the info on this site:
    sounddeadnershowdown.com
    His prices are not the cheapest but the information is great. You will understand soundproofing after reading.
    Most think dynamat is soundproofing and it is not. It is sound deadening, just stops the vibrations of the metal. It does not absorb sound.
    That is why I used Mass Loaded Vinyl (MLV) throughout the car. In fact, I used dynamat then MLV. On the floor I used MLV with a foam backing.
    After reinstalling the dash there is a significant reduction in noise from the front of the car.
    When I open the sunroof with the cover still closed I cannot even hear the sunroof raise.
    It is very nice to have a quite clean '04.
    I still have to do the door panels. They will be next right after I install the 8" LCD monitor in the dash.
    I bought the MLV from TM sound proofing, they had the best price.
    dynamat.com
    fatmat.com
    secondskinaudio.com
    hushmat.com
    desgnengineering.com
    tmsoundproofing.com
  3. #93
    May 2012
    Florida
    No turning back now. Just modified my GLI radio cage and modified the backside of the motherboard mount on the Xenarc LCD.
    Trial fit
    Now I modified the back plate so I can reinstall the motherboard securely.
    Take deep breath and relax........
  4. #94
    May 2012
    Florida
    I actually created a channel the the LCD panel slides into.
    The only problem is the the LCD panel will be recessed into the dash and not mount flush. I need some room for a bezel.
    I am attempting to use the radio cage for support.
    If this does not work or look right then I will trim the side tabs off of the radio cage which will allow me to mount the LCD panel flush to the dash.
    This requires fabricating some type of mount. I am not sure how I would make the mount or what materials I would use. More than likely some type of sheet metal or bracket.
    Might be making a trip to Lowe's and Ace Hardware for some ideas.
    The bezel will be made out of fiberglass or carbon fiber and will not provide and structural support. So, I can do that last.
  5. #95
    May 2012
    Florida
    I've decided to build a sheet metal faceplate. The will make for a solid install and give me a surface to mount the bezel.
    Here is my template:
  6. #96
    May 2012
    Florida
    I tried to build a mount out of aluminum. FAIL!
    So, I searched the MP3car.com forums to get some ideas and presto.
    It was so easy. I velcroed the LCD to the motherboard mounting plate. Then I used L brackets to mount the mounting plate to the radio cage.
    The L brackets are velcroed for now so that I can adjust the screen for a final fit. The I plan to screw the L brackets to the radio cage.
  7. #97
    May 2012
    Florida
    With the trim installed.
  8. #98
    Constant Bitrate firstorbit84's Avatar
    Mar 2009
    FL
    Looking good. Keep it up!
  9. #99
    May 2012
    Florida
    After sleeping on it I came up with a plan for the bezel.
    The GLI trim is brushed aluminum.
    So, what about a CNC'd aluminum bezel brushed to match the existing trim?
    Dimensions are 6.5" x 7.5" and maybe 1/4" thick.
    It would be awesome, but at what cost.
    I will get a few quotes next week.
  10. #100
    May 2012
    Florida
    Went to a machine shop today to discuss an aluminum bezel.
    Problem 1. The machined aluminum is much brighter than the stock trim. And there will be machine marks throughout.
    They quoted $65 cash for the machine work with any material I want to try. I am considering Lexan. It will machine well and I can finish sand it.
    So, I purchased a .093 x 8" x 12" piece of Lexan at Lowe's. Using a table mounted zigsaw I created a flat bezel.
    I need to finish sanding it tomorrow then paint it black.
    Depending on how this looks I may source a thicker sheet and try it again. Then decide if it is worth having a piece machined. I am thinking I can shape it myself with hand tools.
    Pictures tomorrow.
  1. 2004 VW Jetta GLI - CarPC install
    By dustin in forum Worklogs
    Last Post: 07-25-2008, 01:55 PM
  2. Jetta TDI R Carpc W.I.P
    By Jetta_4_TDI_R in forum Show off your project
    Last Post: 02-29-2008, 10:08 AM
  3. MP3Car Infill G4 install in a 2004 Volkswagen Jetta
    By Zip-Lock in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-17-2007, 08:51 AM
  4. 2004 Jetta Factory steering wheel controls
    By Zip-Lock in forum Input Devices
    Last Post: 06-28-2006, 03:10 AM
  5. Jetta 2004... Wire code... Need help.
    By rexthegreat in forum Car Audio
    Last Post: 05-24-2005, 05:39 PM
