Page 11 of 14 FirstFirst ... 234567891011121314 LastLast
Results 101 to 110 of 136
Thread: 2004 VW Jetta GLI CarPC and more
  1. #101
    Constant Bitrate cazzz's Avatar
    May 2012
    Florida
    Installation begins:
    Cleaned up the wiring in the radio cage.
    Installed the USB hub in the glovebox.
  2. #102
    May 2012
    Florida
    LCD trial fit:
    Another trip to the store, long tie wraps to hold the circuit board protective cover and heat shrink.
    I lengthened the motherboard cable to the bezel mounted control buttons so I could reposition it. I guess I didn't measure and it is still too short so I get to add more wire to the 12 strand cable.
  3. #103
    May 2012
    Florida
    Originally Posted by dubluv2003
    I know you want to most likely go with the real deal, but could you not pick up some 3m brushed aluminum vinyl wrap for the bezel once complete? Something to think about.
    Funny thing is I have two 4' x 10' sheets.
    I picked one up because it was mis-priced then got a second because the first had a crease down the middle.
    I think I will run into the same problem as the machined aluminum, it will be close but stick out like a sore thumb.
  4. #104
    May 2012
    Florida
  5. #105
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Very nice and clean install. Your bezel came out fine. Keep up the great work! SNO
  6. #106
    May 2012
    Florida
    Quote Originally Posted by SNOtwistR View Post
    Thanks, it is a little rough but it is a good start.
    Here is the bezel covered in 3M brushed aluminum.
  7. #107
    May 2012
    Florida
    Originally Posted by AZN dubs
    looks good. but i have to say, the momentary switch and the toggle switch look a little out of place. if you could find some cleaner buttons, i think your dash/center console would look insanely awesome..
    but still, you're doing amazing work
    I agree with you about the buttons.
    I have new blanks when I find a permanent solution.
    I tried to let the power supply control the computer but I just wasn't comfortable so I added the buttons so I could take care of the computer.
    Now that is up and running I may revert back to the power supply controlling the computer and remove the buttons altogether.
  8. #108
    May 2012
    Florida
    I have installed the 805TSV in my car.
    The next step is to install an IR sensor and wire it to the monitor.
    I would like to avoid installing the entire bezel. I can just use the monitors remote control.
    Any ideas on the wiring diagram for the button board on the bezel.
    I need to know which wires need to connect to the IR sensor.
  9. #109
    May 2012
    Florida
    I was able to determine that the IR sensor is wired as follows:
    Terminal A - wire 11 should be the output
    Terminal B- wire 1 (red) should be ground
    Terminal C - wire 10 should be 3-5v
    However, i found a couple different terminal configurations.
    I do not know what frequency IR sensor to use. There seems to be 2 common freqs, 38.5Khz and 56.8Khz.
  10. #110
    May 2012
    Florida
    I plan on testing the LCD remote as follows. I have a 38.5Khz IR sensor, hopefully this will work.
    Then I have to figure out which wire goes where.
    Here we will connect the detector as such:
    Pin 1 is the output so we wire this to a visible LED and resistor
    Pin 2 is ground
    Pin 3 is VCC, connect to 5V
    When the detector sees IR signal, it will pull the output low, turning on the LED - since the LED is red its much easier for us to see than IR!
  1. 2004 VW Jetta GLI - CarPC install
    By dustin in forum Worklogs
    Last Post: 07-25-2008, 01:55 PM
  2. Jetta TDI R Carpc W.I.P
    By Jetta_4_TDI_R in forum Show off your project
    Last Post: 02-29-2008, 10:08 AM
  3. MP3Car Infill G4 install in a 2004 Volkswagen Jetta
    By Zip-Lock in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-17-2007, 08:51 AM
  4. 2004 Jetta Factory steering wheel controls
    By Zip-Lock in forum Input Devices
    Last Post: 06-28-2006, 03:10 AM
  5. Jetta 2004... Wire code... Need help.
    By rexthegreat in forum Car Audio
    Last Post: 05-24-2005, 05:39 PM
