Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 121 to 130 of 136
Thread: 2004 VW Jetta GLI CarPC and more
  1. #121
    Constant Bitrate cazzz's Avatar
    May 2012
    Florida
    The Mac Mini install is now complete.
    I added a Pac Audio LD-10 to boost the audio signal as a result of the signal loss through the ground loop isolator.
    The stock monsoon rocks, never sounded so good.
    When the Mac Mini starts the following desktops are loaded:
    Sirius
    iTunes
    My favorite FM station through tunein.com
    Google earth.
    The local FM station is on when it boots.
    Google earth tracks my position using the on board GPS.
    With the Mac Mini I see no reason to have front end software.
    I just setup desktops and can simply swipe from one window to the next.
  2. #122
    Low Bitrate julaikos's Avatar
    Nov 2007
    Very nice install!
    Just one question : you still need the lcd's speakers?
    Oltcit turbo power!
  3. #123
    May 2012
    Florida
    Quote Originally Posted by julaikos View Post
    Very nice install!
    I don't think so, but I had them and just installed them.
    Who know what I might use them for, possibly trouble shooting?
    Maybe a microphone under the hood so I can here the turbo spool up, LOL!
  4. #124
    Jan 2007
    Where did you get the holder for the touchpad and how is it mounted to the center console? Install looks great.
  5. #125
    May 2012
    Florida
    Quote Originally Posted by NCHEVYHEVN View Post
    It is a bracketron universal cup holder mount. Found it for $25 on amazon.
    http://www.bracketron.com/m/tablets-...t#.UUXdY_q9LCQ
    I mounted the apple magic trackpad.
  6. #126
    May 2012
    Florida
    Here is the final layout, components, and wiring information: GLI_Layout.pdf
  7. #127
    May 2012
    Florida
    Here is a video of the setup. It shows the boot times and basic operation.
    http://www.youtube.com/watch?v=zZE7kz1BUAI
    The boot times will improve when I replace the harddrive with a Solid State Drive.
  8. #128
    May 2012
    Florida
    Had the windows re-tinted today. The tint that was on the car was cheep. Needless to say I lost the rear window defroster when the old tint was removed. Good thing I live in Florida.
    Too bad the original owner was cheap!
    Looks much better. Now you can't see me and my toys.
  9. #129
    May 2012
    Florida
    I added an AT&T USB connect modem to the Mac Mini today.
    Now I do not have to hassle with connecting my iPhone each and every time.
    Just keeps getting better.
    I also order an adapter cable that will connect the USB modem to my external antenna.
    This should add about 5db signal gain and allow me to keep the modem hidden in the trunk.
  10. #130
    May 2012
    Florida
    OBDII for MAC
    I found a program from Yhasi called Movi and Movi Pro.
    This program should provide all of the OBDII basics but like all other will not supply boost.
    I am having trouble connecting the software to my PLX WiFi.
    Yhasi's tech support has been fantastic.
    Emails are going back and forth, I supplied screen shots of the setup today.
  1. 2004 VW Jetta GLI - CarPC install
    By dustin in forum Worklogs
    Last Post: 07-25-2008, 01:55 PM
  2. Jetta TDI R Carpc W.I.P
    By Jetta_4_TDI_R in forum Show off your project
    Last Post: 02-29-2008, 10:08 AM
  3. MP3Car Infill G4 install in a 2004 Volkswagen Jetta
    By Zip-Lock in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-17-2007, 08:51 AM
  4. 2004 Jetta Factory steering wheel controls
    By Zip-Lock in forum Input Devices
    Last Post: 06-28-2006, 03:10 AM
  5. Jetta 2004... Wire code... Need help.
    By rexthegreat in forum Car Audio
    Last Post: 05-24-2005, 05:39 PM
