Page 1 of 14 1234567891011 ... LastLast
Results 1 to 10 of 136
Thread: 2004 VW Jetta GLI CarPC and more
    Constant Bitrate cazzz's Avatar
    May 2012
    Florida
    I bought my charcoal grey 2004 VW Jetta GLI last year. It was completely stock with minor dings and dents. The interior however had a few panels recovered and it looks like crap. So, I decided to take out the interior, sound proof the car, and run cables for my new carpc.
    Before I get into the tear down here is some back ground pics.
    Step 1. New Paint Job.
    Paint Prep
    http://share.shutterfly.com/action/w...AcOHLRw2bOWj2Y
    Painted
    http://share.shutterfly.com/action/w...AcOHLRw2bOWj4g
    May 2012
    Florida
    Keeping with the exterior appearance I replaced the headlights and tails. Dectane.de all around.
    http://share.shutterfly.com/action/w...AcOHLRw2bOWj6o
    Changed the front and rear chrome VW emblems with black emblems.
    Added smoke running and turn signal lights all around. Led bulbs throughout.
    Step 3. Added a little performance with APR Stage 1.
    May 2012
    Florida
    This is where I am at now. I have removed the interior from my car. I will be adding sound proofing materials, covering the upper pillars, headliner, sunroof cover, and door inserts.
    I plan on using foamed back material for the headliner and sunroof cover and will experiment with 3M vinyl for all the other surfaces.
    Interior pulled:
    http://share.shutterfly.com/action/w...AcOHLRw2bOWj8w
    Sound proofing was an important part of this project. I researched most if not all of the products available and did an analysis to determine cost per sq ft. Here is a run down of the materials.
    CLD, contrained layer dampner, commonly called sound proofing. Usually butyl rubber covered in a foil. This deadens the sound of the panels and only needs to cover 25% of the surface to be affective.
    MLV, mass loaded vinyl. I used the 1 lb per sq foot density and this material is for sound proofing as it blocks noise. Ideally you install this over full panels with no seams. I did find this difficult in some places so I used overlapping pieces. I did not glue the seams and taping the seams is nearly impossible as the tape does not stick very well.
    Under carpet cover, I used 1/4" high density foam covered in MLV.
    Closed cell foam, used to eliminate vibration and rattles from loose panels.
    Extruded Butyl Rope, used around the doors and speakers to eliminate air movement.
    If anyone is interested I can provide a cost comparison between these suppliers.
    sounddeadnershowdown.com
    dynamat.com
    fatmat.com
    secondskinaudio.com
    hushmat.com
    desgnengineering.com
    tmsoundproofing.com
    May 2012
    Florida
    http://share.shutterfly.com/action/w...AcOHLRw2bOWj-4
    I have to repair a few wires that I accidently cut when removing the stock undercarpet material.
    I am also going to repair a tear in the drivers seat bolster. I will probably remove the material completely from the seat and take it to get it sewn.
    Next I need to run wires for my carpc install.
    May 2012
    Florida
    The Plan:
    Stock monsoon head will be replaced with a 7" or 8" LCD touchscreen. The 7" fits the double din slot, the 8" however will take some fabrication and the fit will be tight.
    Mac Mini installed in the trunk.
    DC-DC power supply installed in the trunk.
    USB hub installed on or near the dash.
    Remote power switch for the Mac Mini installed in the center console
    Sewell Digital to Analog 5.1 DTS/AC-3 Decoder installed in the trunk for computer sound integration into the stock monsoon amp and stock speakers. I know they will be upgraded in do time. I am adding a small sub with this install however.
    The following wires will need to be run before reinstalling the interior.
    Power to the trunk. I am installing a marine grade fuse bus under the hood and in the trunk. These will provide grounded power distribution for all future wiring projects.
    #8 black ground hood to trunk
    #8 red power hood to trunk
    Power and ground for LCD panel trunk to dash
    HDMI, DVI and VGA cables trunk to dash. Covers all the bases for future upgrades.
    USB cable to USB hub trunk to dash
    The remaining cables are in the trunk area.
    Once these are run I can get my car back on the road and start bench testing the carpc.
    May 2012
    Florida
    Components:
    Basic Mac Mini
    Carnetix P-2140 power supply
    Carnetix P5USB hub
    Griffen remote usb controller for volume control
    Sewell Digital to Analog 5.1 DTS/AC-3 Decoder for audio integration
    Lilliput 7" or Xenarc 8" touchscreen.
    Replacement antenna, includes wifi, gps, and cellular. (No FM)
    Next I will cover modifications to the Mac mini and list all of the connections.
    May 2012
    Florida
    5 modiificatons to the Mac Mini
    1. Replace the 500GB HD with a 450GB SSD
    2. Replace the 4 GB of ram with 16 GB ram
    3. Remove the internal power supply and replace with a cable and connector mounted on the side of the case. The external power supply will be used in the house with a patch cable to the case connector. In the car, the DC power supply will plug into the dc connector on the side of the case.
    4. Disconnect the internal wifi antenna and replace with a pigtail cable to a connector on the side of the case. A small external antenna will be used in the house. In the car, the roof mounted antenna includes wifi.
    5. Modify the on/off button wiring. The power supply will control the on/off function of the mac mini based on ignition power. When the car is turned off the power supply will turn off the mac mini. I may use a remote on/off switch mounted in the center console. I plan to use a 2.5mm plug in the side of the case for the on/off switch connection(s)
    The following items will be connected to the mac mini USB ports.
    1. USB cable to the USB hub in the dash
    2. GPS dongle with external antenna connection
    3. AT&T 4G dongle
    4. Power supply
    USB hub
    1. LCD monitor for touch screen function
    2. Super Drive
    3. Volume Knob
    4. OBD II
    Other connections:
    Wifi Antenna
    Power
    On/off function
    TSOLink out to Sewell audio converter
    - This unit provides RCA out for 5.1 surround or 2.1 stereo
    May 2012
    Florida
    LCD panel planning.
    I am attempting to fit an 8" Xenarc LCD panel in the dash.
    There is enough room by removing the double din radio and a dead panel above the radio.
    The radio cage will be modified to fit the panel.
    The challenge is to make a bezel that fits the opening and accepts the LCD panel.
    I have a buddy who works with carbon fiber and fiberglass. He will make an attempt.
    I also contacted Joe Shock to see what he can do. There are 4 local sheet metal fab shops that I will discuss this with as well.
    The LCD panel will be the last purchase.
    May 2012
    Florida
    I will be on vacation for 1 week.
    Task list for my return.
    Repair wiring bundle under passenger seat.
    Purchase wire, cables, connectors, fuse blocks and fuses.
    Disassemble the dash.
    Run cables and wires.
    Install new antenna and maybe a hidden FM antenna just in case.
    Take drivers seat for repair.
    Reassemble the interior.
    Hopefully the car runs and everything works.
    Disassemble the trunk.
    Wire all power connections and fuses.
    Purchase Mac Mini
    order connectors for the antenna and on/off switch.
    Install software and verify the mac mini is up and running.
    Setup an ATX power supply to bench test the entire setup in the house where its nice and cool.
    Modify Mac Mini as outlined above verifying operation after each mod.
    Attach the PSU to Mac Mini and verify operation.
    Purchase GPS and AT&T dongles verify operation.
    Purchase audio interface verify operation.
    Check the USB hub and volume control
    Ready for installation.
    By now I should have a bezel and decide on the easy route using a 7" Lilliput or the bezel works and I purchase the 8" Xenarc.
    Back in a week.
    May 2012
    Florida
    Just returned from a cruise to the Bahamas. Much needed rest. It's time to get working on my car.
    Play by play starts tomorrow.
  1. 2004 VW Jetta GLI - CarPC install
    By dustin in forum Worklogs
    Last Post: 07-25-2008, 01:55 PM
  2. Jetta TDI R Carpc W.I.P
    By Jetta_4_TDI_R in forum Show off your project
    Last Post: 02-29-2008, 10:08 AM
  3. MP3Car Infill G4 install in a 2004 Volkswagen Jetta
    By Zip-Lock in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-17-2007, 08:51 AM
  4. 2004 Jetta Factory steering wheel controls
    By Zip-Lock in forum Input Devices
    Last Post: 06-28-2006, 03:10 AM
  5. Jetta 2004... Wire code... Need help.
    By rexthegreat in forum Car Audio
    Last Post: 05-24-2005, 05:39 PM
