Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
Thread: Samsung Galaxy Tab 2 7inch tablet in 2006 G35 double din
  1. #11
    Sep 2008
    Quote Originally Posted by viceversa View Post
    ^thanks! I'm using an app called Llama ( Google play store link ) which allows your android to perform specified actions when certain conditions are met. A similar app is called "Tasker" which isnt free but Llama is free and I find it to be much easier to use.
    Yep, heard about this app. Haven't used it yet though, but seems like I will.
    So basically I have a condition setup that when the tablet is charging to change the screen timeout to never then a separate condition setup that when the tablet looses power to change the screen timeout to 5 seconds. I have tapped into the cigerette lighter for power which is ignition switched so it only charges when the key is in. This will simply turn the screen off but the tablet is still on... Android was designed to never really be turned all the way off anyways so there really is no need to fully turn the thing off unless some apps start acting up and you want a fresh boot. The tablet will last days on battery power just sitting there not being used
    but that is just the start of this app...under the same condition of when the tablet looses power I have set actions to: disable bluetooth, disable wifi, and Pause the current playing track. When the tablet regains power I have set conditions to enable bluetooth, enable wifi, and open up the music app...
    I see. Yes, it makes sense. If you turn everything off (might probably as well kill all the running apps except the launcher), the system itself won't be eating much battery. But I guess I will still need some emergency power button access. Now I understand why you drilled that little hole.
    Well, I guess this approach could be used until I'll figure out some way to "press" that power button automatically.
    The possibilites are endless here. LMK if you have any more questions I'm more than happy to help out
    Thanks for a very detailed answer!
    Now you've got me thinking - maybe I shouldn't have wasted my time this week inventing a cooling solution for my car PC, which keeps rebooting because of overheating, but instead replaced that cumbersome many-piece machinery with a nice small tablet?
    D945GCLF2, Atom 330, M2-ATX, EBY-701, Pharos GPS-500... - Assembled & Installed!
  2. #12
    Sep 2008
    Is it a forum standard that every single post be approved first or is that just b/c my post count is so low? I understand the purpose but wow it's very annoying lol
    Probably 5 first posts? I guess recent spam attacks on the forum might also cause enforcing some stricter rules.
    That's funny - I couldn't find your reply at the end of the thread, and only when re-read all the posts from the beginning found that message, which was added earlier today, but posted only now. Took me some time to undertsand why it was this way.
  3. #13
    Dec 2008
    Quote Originally Posted by bambam View Post
    Yes, I agree. Your install looks awesome but how are you getting sound from the tablet to your speakers? I didn't see a headunit anywhere.
    I'm using a PAC ROEM-NIS2 which is used to hook up aftermarket stereos to the stock Bose amp which is located in the trunk. So the only sound control I have is on the tablet but the pre-amp voltage out of the headphone jack just isnt enough to really power the system....sooo thats why I'm installing that EQ
  4. #14
    Dec 2008
    Quote Originally Posted by alpax View Post
    Well that past couple days it has been extremely hot in my area and I'm beginning to get worried about the temp of the tablet especially the battery temp...it rose to about 130 degrees F yesterday from my car just sitting in the sun all day. Android is supposed to have a fail safe that turns everything off once a certain temp is met but I didnt see that happen lol currently I'm trying to figure out a way to have the system completely shut off once it reaches a certain temp using Llama. What kind of cooling solution did you come up with for your setup?
  5. #15
    Dec 2008
    haha yeah I was starting to get frustrated b/c I want to answer questions but have to wait over a day for a mod to approve whatever I post lol yeah my post count is low but hey ive been a member here for 4 years! well I'm over 5 post so maybe its 10? iuno but i wish a mod would chime in.
  6. #16
    Low Bitrate aziodale's Avatar
    Jun 2009
    Italy Sicily Palermo
    Congratulations to one of the few really well-made customizations
    Huawei Mediapad 7" (1280x800 IPS) | Carnetix P2140
    My last update http://www.mp3car.com/show-off-your-...t-version.html
  7. #17
    Sep 2008
    Exactly! The dash is getting really hot on a sunny day. I don't know how it may affect the "sleeping" tablet.
    Can Llama check the temperature as well?
    Heh... Nothing special really. First I put a bigger radiator on that Atom (cut an old one from P-II in half ). That didn't really help much without fans, so now I put two fans there, and also replaced the regular HDD with an SSD, which should run cooler. The problem is - I used a very compact case (M350) because it fits perfectly in the niche in my console behind the screen, and I didn't want to construct a custom case. But with M2-ATX PSU squeezed inside there is no room in that enclosure, so I had to be inventive.
    But it's so retro now... I will definitely replace that with Android soon.
  8. #18
    Dec 2008
    Quote Originally Posted by aziodale View Post
    why thank you kind sir!
  9. #19
    Dec 2008
    Little update: received the Clarion EQ, Alpine MRX-M50, bluetooth headset. will install tonight!
  10. #20
    Jun 2012
    OC So. Cal
    very, very clean. Sounds Like you really did some homework. I'm a newb here but it seems like a dual core is overkill sort of. The android, maybe running linux would do just fine (I think). a few questions if you don't mind.
    -Is there any carPC front ends for the android? or are you just sticking with the regular android interface?
    -In you hunting, did you find any 7 " tablet with BT phone synchronization?
    -Did you base your decision at all on the processor? If so, what good & best bang for the buck? *(I'm on a budget)
    - Can you ad USB ports and get all the functionality of a windows /Cetrafuse setup? (I.E. sound cards, Fusion brain, whatever...)
    Thanks much, D-
  1. Replies: 91
    Last Post: 07-21-2013, 05:48 AM
  2. galaxy tablet in a lexus
    By mast240 in forum Android Tablet
    Last Post: 07-18-2011, 11:26 PM
  3. Samsung Galaxy tab 7 in 06 Audi A4
    By crs9 in forum Android Tablet
    Last Post: 06-30-2011, 03:05 AM
  4. A New Direction (Samsung Galaxy Tab)
    By PrayingWithFire in forum Newbie
    Last Post: 01-19-2011, 01:26 AM
  5. Samsung Galaxy Tab 7.4 x 4.7in tablet
    By RipplingHurst in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-26-2010, 09:54 PM
Tags for this Thread
