Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
Thread: Samsung Galaxy Tab 2 7inch tablet in 2006 G35 double din
  1. #31
    Dec 2008
    haha I like the icons and yup all of those icons shown are widgets made my desktop visualizer. Hope you can get your project underway soon!
  2. #32
    Variable Bitrate daclothe's Avatar
    Dec 2004
    Quote Originally Posted by alpax View Post
    Are you still using Desktop Visualizer? Seems like nothing else is really needed for the UI.
    and what icon pack is that?
  3. #33
    Dec 2008
  4. #34
    Dec 2004
    Quote Originally Posted by viceversa View Post
    oh that's a cool site. thanks for the heads up!
  5. #35
    Aug 2011
    Colorado
    What are the reasons for using a tablet instead of a car PC and a typical 7" or 8" touchscreen built for double DIN vehicle installation?
  6. #36
    Sep 2008
    Quote Originally Posted by Carson Dyle View Post
    I have a typical CarPC with an Atom CPU, and 7" Lilliput touchscreen, but I'm looking at replacing it with a tablet. The main reason is that I'm tired of fighting with different issues:
    - My PC was overheating, so I had to construct a better heatsink and find how to put a couple of fans into a small case.
    - The available Front Ends are basically hacks to make a regular desktop system usable with a small screen and fingers instead of mouse&keyboard. Even if you finally made it work, you should not touch it - the system is very fragile, as there are many dependencies between the components, both hardware and software.
    - It takes about half a minute for a PC to boot.
    - The whole system is pretty bulky, cumbersome and expensive.
    - Very limited selection of navigation software, which can be comfortably used with a small touchscreen.
    Advantages of a tablet:
    - Costs almost the same as only a good car PC touchscreen - not even counting the PC itself.
    - It is smaller than a typical touchscreen - again, not even counting the PC.
    - Uses less power.
    - Doesn't need a special smart power supply.
    - Turns on instantly.
    - The system's UI is designed from scratch to be finger-friendly. The same deal with all applications.
    - Good navigation software. Even just the standard Google Maps/Navigation could be used. Nothing on PC compares to usability of Google Maps on a tablet.
    Of course there are some disadvantages:
    - Cannot be used as a Bluetooth audio/interface to the phone (some might have a solution).
    - Cannot connect a backup camera (there could be options).
    - Cannot install an FM/AM radio (some tablets may have FM radio).
    - If the car is used rarely and for short periods, the tablet's battery may discharge and it will be booting the same half a minute like a PC. Also the tablet needs to be switched on manually in such case.
    - Limited storage for media. If 32/64GB SD card is not enough, have to come up with some external solution.
    If these items are not critical, the tablet seems to be a much better choice.
    D945GCLF2, Atom 330, M2-ATX, EBY-701, Pharos GPS-500... - Assembled & Installed!
  7. #37
    Dec 2008
    ^exactly, hit the nail on the head bro.
  8. #38
    Jun 2012
    viceversa, is this how you did your audio setup, aside from the dock? This is the biggest portion of my project that is setting me back atm.
    Name:  Tablet Audio setup.jpg
  9. #39
    Jun 2012
    Regarding the bluetooth, it is a android limitation...a android device cannot act as a bluetooth headset plain and simple. I have a work around for this and it works great, I bought a external bluetooth headset with 3.5mm output and plugged that up to my EQ aux input. My phone is paired with the bluetooth headset NOT the tablet so when a phone call comes in I just press the aux button on my EQ and there ya go. Look into an app called "Tablet Talk" to get a better idea of it all.
    Hey vice, can you also speak more about this or take some photos of it too? Do you have a link to the actual BT headset you got? I'm really interested in the implementation of this as well, since it's the only portion keeping me from being 100% hands free in the car.
  10. #40
    Dec 2008
    Yes that is the same configuration of my setup except I moved to a Hifonics HFEQ which in comparison to the clarion it has more flexibility with LPF / HPF, better knobs and IMO sounds better.
    This is the bludetooth reciever I am using: Samsung HS3000. This plugs into the aux input on the EQ which is then switched by the button on the front. I still havent mounted my bluetooth yet and it's sitting on top of my EQ for now until I finish up with mounting the EQ.
  1. Replies: 91
    Last Post: 07-21-2013, 06:48 AM
  2. galaxy tablet in a lexus
    By mast240 in forum Android Tablet
    Last Post: 07-19-2011, 12:26 AM
  3. Samsung Galaxy tab 7 in 06 Audi A4
    By crs9 in forum Android Tablet
    Last Post: 06-30-2011, 04:05 AM
  4. A New Direction (Samsung Galaxy Tab)
    By PrayingWithFire in forum Newbie
    Last Post: 01-19-2011, 02:26 AM
  5. Samsung Galaxy Tab 7.4 x 4.7in tablet
    By RipplingHurst in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-26-2010, 10:54 PM
Tags for this Thread
