Results 1 to 10 of 17
Thread: Volvo s80 2000 Car pc
    Jul 2012
    Sweden
    Smile Volvo s80 2000 Car pc
    Hello everybody. I'm new to this forum and also to the car pc thing. The elementary for this build is my fathers. For over a year (can't remmember) we've used a Asus Eee pc with 11 inch screen. Now we've grown out from that and are going to build a real car pc. The car is a Volvo s80 year 2000. The main purpose will be to use it as a Gps and also monitor by ODB. I'd like to use it to play music too but the built in stereo doesn't feature an aux-connection.
    We don't like the regular Gps's where you got a like four inch screen or so. As we got this seven inch screen for the right price in surplus we will go with that. I guess you guys out there know that the resistive touch panels are dustmagnets, so apologise for that.
    The monitor got vga, two composite in for rear or nightcamera use, audio in and USB for the touchpanel. We assumed that the audio in the monitor should suck, but we where wrong. It is ok for Gps use and better than a modern cellphone.
    The motherboard an Intel DN2800MT with atom N2800 cpu. It's a bit overkill but the eee pc did just make it running Windows xp but now we got enough horsepower for HD video too.
    The heatsink look small but it will handle the heat from the cpu fine. It has also clearance for the dvd and hdd cradle wich leaves out one ghetto-solution.
    The wireless card comes from the original chassi we're using. The card is an Atheros something, it'll work for us. Sad there's no bluetooth on it so we're going to use a dongle. The Ram is 2x2gb Kingston 1066MHZ DDR3 SODIMM, as ram is so cheap these days. There are also tons of other connections on the board that I don't even know what they are used for. But I can tell there's integrated 8-19v dc-dc powerinput.
    May I introduce the chassi. An old Asrock ion 330 or something with broken graphics. So the motherboard was recycled and the chassi and other useful parts where saved. And now the come to good use.
    The front plasticcover. Behind the ventilation holes there has been an IR-reciver but that doesn't connect to our new motherboard so we'll skip that.
    Took the freedom and flipped the image, sry it looks weird. The Harddis a Samsung, 160Gb, and spins at 5200rpm. It's from an old laptop with a broken power-connector not worth fixing. Works for this even if and SSD had been the optimal choise, but not for our wallet. The DVD is original from the chassi better use oit here than use shelfspace.
    The power to the drives comes from the motherboards s-ata powerconnector. But originaly (asrock-style) it used a 4-pin atx (cpu) powerconnector. An easy fix with the soldering iron.
    The other end of the drve-cables. Perfect length.
    The other cables used for the "pc-part" of the project. Powerbutton, pwr-led and internal USB for the bluetooth dongle. The wires for the wireless where former mounted at the front of the case. Now the new motherboard got another layot that don't match that cable-lengt so we need to move them. I will hope that it makes the least impact on performance compared to extend them.
    The with of the chassi is a bit bigger than normal mini-itx, but the depth is to short. So we needed to extend it.
    We drilled the rivets away and cleaned it up in the milling machine and mounted it back on with soldering, my fathers idea. I didn't know that it worked but it did.
    The distances for the motherboard where also on non-standard places. So we made new ones.
    The backplate also got milled. It's not that pretty with the old holes left but it will be ues as ventilation holes. Intel is also niceand includes the regular full height backplates but also the half height that we used.
    The lid of the chassi. Very clean looking design.
    That's it for today
    /Joakim and Krister
    Last edited by jocke92; 07-14-2012 at 04:50 PM. Reason: My bad the car is a model year 2000
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Welcome to the forum! Nice start to your project, just a heads up on the obd stuff for your car might not happen if 1. it is not obd compliant 2. it outputs any info as it might not have any data to send since its age is before the mandated obd specs. good luck SNO
    Jul 2012
    Sweden
    Quote Originally Posted by SNOtwistR View Post
    Thanks for your reply. The car is year 2000, my bad. According to the information we can find on it should work, but thanks for your attention.
    As I'm new here. How do I change the heading/topic of the thread?
    Jul 2012
    Sweden
    The weekends progress
    Our first plan was to put the bluetooth receiver inside the chassi. But the chassi would lower the performance of it. So we decided to mount it behind the plastic front cover. Instead.
    But as it's not much space there we needed to do some modifications. If we've mounted it on the back it wouldn't be fully integrated. I'd got some left-over (from another project) internal USB-connector pieces that I demolished and soldered together. Then we mounted it with cable ties which gives us one or two millimetres space between the bluetooth-board and the metal.
    We found an power-button on an old circuit board that fitted ok for our use. So daddy milled a plastic piece to mount it with.
    The button and the leds are soldered.
    The original mount fot the leds were in and beside the power-button but we changed that and I don't think it looks bad. As there where hollow feed holes for the plastic cover (look at the prev. pic.). We just drilled through them and pushed the leds through. The orange is for power and the green for harddisk activity.
    The CPU is steady at 60 degrees Celsius and the powerdrain from my wall outlet is 8w idle and 11-12w load. It sounds a bit high to me so we decided to mount a fan inside. It's a noticeable difference in both noice and temperature. But when we mount it in the car the noise won't bother and the fan will do the job. We just need to drill som more holes, cause now the fan is covered to 2/3.
    The inside. The fan should be mounted as we drill the holes. We will also make a cover for the depth-extend-modification. We need to choose where we are going to mount the pc. Maybe in or under the glove compartment.
    To the former eee pc daddy had made a nice mount. It mounts where the mesh for the center speaker in the deluxe edition 5.1 system mounts. We got with the cheap alternative. It's a breadboard that is cut and polished.
    Jul 2012
    Sweden
    Monitor mount, cooling fan and possibilitys
    Fan is mounted with an old fan grill we've had lying around. The temps are good now.
    A close up picture on the wooden tray.
    The long side
    The short side. The monitor has got a plastic bar that will be used when we mount it in the car.
    It's mounted in the car.
    From behind. We've not tested the angle out. The viewing-angles of the monitor isn't all that great.
    The holes for the cables
    A possible mount
    The glove compartment is cast in one piece. So we don't want to break it. Maybe we can get a spare one at second-hand.
    Mar 2012
    New Jersey
    Will the computer just fit in the glove box? That will allow you tuck it away, hide the wires, and have easy access when needed. I was able to fit mine perfectly that way and due to the tight fit, a mount wasn't even required.
    "It's not worth having if you can't customize it"
    Jul 2012
    Sweden
    Quote Originally Posted by duncanator24 View Post
    It will not fit there without modification. And even then it'll be hanging on by a hair. But the will be able to hide the cable with the other option too. Time for an update on our progress.
    We started the day out put the power-cables from the battery in the trunk to the front of the car. We used 2,5mm2 cable.
    We found a four amp automatic fuse that will be enough for our project. Don't know where we got it cause we don't have automatic in our house.
    We are going to mount the switch and fuse back here. Actually where the other fuses mounts. The switch is rated for 10 ampere 220 volt.
    The fuse where mounted using cable ties and the hole for the switch where cut out. We didn't got enough cable so the colour coding get disrupted.
    This is what it looks like from the outside. If I disregard from the cable ties it looks like it's part of the original interior design. The left is for the gps-module and the other one for computer and monitor.
    let's make a U-turn and take a look at gps. They connects through bluetooth. The fourth one is mounted in the car already. But if I'm not completely lost it's a Nokia.
    We also put the display cables in place. To do that we needed to dismount the monitor and the lid. So three pictures of the hole.
    The famous mess of cables. After that we tested out the computer in the car and it worked with the touch-screen. But we didn't get any sound. That derives in that it only works when using something connected to the av-connections not the vga-port. When I tried the audio quality I tried both sound and composite. So time for plan B. Another set of speakers maybe, cause the CD-changer adapter is to expensive.
    Jul 2012
    Sweden
    We put apart a crappy budget keyboard. The controller board may be used to send keyboard-commands to the computer and then be translated to scripts by ahk (autohotkey)
    We milled out the panel that will mount below the monitor. I darkened the monitor in gimp so nothing is wrong with it.
    It's a bit wider to keep the led thats indicating if the main powerbraker is on. It's a bit bright so it needs more dimming. The buttons that we will be using is unavailable. They comes from a broken key set belonging to a cnc-machine, now used for spare keys.
    There will be six buttons connected to keyboard keys, pwr-button, pwr-led, main-powerled and a USB-port. The picture is not the final design.
    Mar 2012
    New Jersey
    I see you are using Mapfactor Navigator on the screen. Have you tested it out extensively or is the first time installing/using the software? I have experience with it and found it to be absolutely terrible lol..
    Jul 2012
    Sweden
    We don't think it's bad, but it's failing at some points. So we might try out some more, I heard someone talk about Odyssey but it didn't manage to finnish the installation. It said that it miss a component but it did not tell what to install (like .net or something I guess).
    We mounted and soldered the connector for the panel. I know that we're able to let it start by the ignition and so on but we don't like that. We prefer separate supervision of the computer.
    Theres no pictures during the work. But we used an IDE connector from an old motherboard to replicate the powerswitch, hdd- and powerled connectors inside. So we've got the one mounted on the chassi plugged in too.
    We also got the antennas for our wifi in the mail. But the signal did actually suck even more and no connection at all. I will guess that it broke during the lightning as other parts of the computer (that we got the card from) did. I was not able to try it in my laptop as HP won't let the laptop to boot with not certified cards.
  1. 2000 Volvo S40 Liquid Cooled Car-pc
    By Angel_OD in forum Worklogs
    Last Post: 09-03-2012, 03:33 PM
  2. Volvo V 70 Sw
    By ramaloji in forum Show off your project
    Last Post: 01-16-2007, 03:22 PM
  3. for owners of radios volvo until the 2000
    By ramaloji in forum Car Audio
    Last Post: 12-17-2005, 05:28 PM
  4. volvo?
    By volvoman in forum General Hardware Discussion
    Last Post: 09-06-2004, 10:46 AM
Tags for this Thread
