Results 1 to 8 of 8
Thread: The Nexus 8 (Mazda RX8 Nexus 7 / Focal install)
    Nov 2007
    Name:  header scaled.jpg
    I have wanted a carpc setup for quite a while (years actually, massive lurker here), and had recently decided that a tablet was perfect for the application. I had been thinking about using an HTC Flyer, but then I heard the rumors of a Google Tablet and just had to wait for it. Despite its apparent drawbacks (storage mainly) I think the Nexus 7 is the ideal candidate for carpc applications.
    The car is a Whitewater pearl 2005 RX8 GT that has been really good to me so far (besides the no bass Bose system).
    The main piece of my install is a modified Metra double-din install kit. My initial idea was to cut out the Metra frame and mount the tablet flush to the center console, but when I received the Metra kit I realized that there was just not enough space for this to work. The tablet is actually perfectly flush to the top of the Metra kit, meaning the Hazard switch needed to be moved along with the removal of a small amount of material from the car itself. I cut and shaped a piece of sheet metal to the curve of the tablet to hold it in place behind plastic face and mounted it using epoxy. I used a heavy amount of dremel work to notch out the HVAC to allow for the tablet to sit down far enough in the opening in the metra kit.
    Name:  Sheetmetal curve.JPG
    Name:  Sheet metal adhered sc.JPG
    When the tablet was seated, I reworked a few cables so that they would fit in the close tolerances I had to work with. Initially I had been planned to use a custom OTG y-cable I made to allow for simultaneous charging and access to usb storage (and a usb DAC), but evidently this is disabled in the kernel currently. The tablet will not charge and mount external storage at the same time. I have heard of some people getting this to work, but I was in a rush to finish the install and have not fixed this yet.
    One issue I had was that as this is a permanent install, I needed a way to use the volume keys and power button (for flashing roms and such). This was an interesting problem to solve; I ended up making a pulley system that mounted fishing lines to the faceplate and wrapped them around the Nexus, with the lines coming out a small hole I made in the ash tray. This way when I pull the string the button is pressed
    Name:  Pulleys scaled.JPG
    The finished product turned out very well I think. It is rock solid, and when the screen is off it almost completely disappears into the dash, a really cool look. The tablet is very fast and buttery smooth, perfect for in car! Also, since the light sensor is not covered the tablet auto-adjusts its brightness as it should, a useful feature when using google maps at night.
    As for software, I am running a custom rom (JR6) because of the side mounted navbar. I am also forcing the tablet into landscape mode. I have the tablet set to "stay awake" when connected to power, so it automatically turns on and goes into deep sleep when the car is off. I so far have mainly used Spotify for my music, getting wifi on the go tethered from my phone. Works great.
    All this would be worthless without a good sound system, right?
    For sound, I installed a Focal 3-way polykevlar component set run of a JBL amp at 100W per channel. I am using a Clarion Eq746 equalizer in my glovebox to give me the controls I was missing from using the tablet (fader, subwoofer control, real eq), also it acts as a much needed line driver for the Nexus. I made some speaker adapter plates for the fronts that where quite off center to allow for the deep Focals to clear the window glass in the door. I did not Dynomat the doors, but I really wish I had. These speakers really have some kick to them and shake the doors to pieces. If you are replacing the speakers in your car I recommend that you do the sound dampening at the same time. I installed the tweeters in the sail panels and quickly made some temporary pods for the mids to go on the dash. I will fiberglass these to the A-pillars at some point when time allows.
    Name:  Dash Speakers sc.JPG
    What is left:
    1. I do not like having to use the tablet for volume control, so I am going to take the potentiometer out of the clarion unit and remote mount it for ease of access.
    2. Solve the external storage otg cable problem.
    3. OBDII engine info
    4. Install Focal Polyglass 13
    5. Fiberglass the dash speakers
    6. Dynomat the doors
    7. Whatever else my poor college budget will allow!
    Thanks for reading! Comments welcome.
    Sep 2012
    Do you have any pictures of the back with everything wired up?
    I like the NEXUS 7, and have contemplated doing the same thing. Did you consider relocating the head unit and just connecting via HDMI cable? If you have steering wheel controls, it could work.
    Newbie focused313's Avatar
    Jul 2012
    Michigan
    that looks amazing.
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Cool!
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
    Nov 2007
    Thanks guys!
    Quote Originally Posted by Hayesxb View Post
    I don't have any really nice pics of everything wired up. It is very straight-forward to do though (power, audio, and Metra adapter that's it). It would be next to impossible to remote-mount this headunit, as it incorporates the entire black face. It is MUCH simpler to buy a Metra kit and use that to retain control of the HVAC and screen above. Also, I am not using any of the stock speakers, so the steering wheel controls would not work anyway.
    Feb 2006
    how did you change your display to nexus 8?
    Dec 2010
    Twilight Zone
    Quote Originally Posted by rico_3000 View Post
    Last post in this thread:
    09-25-2012, 02:22 PM
    Late login by OP:
    Last Activity 06-30-2013 05:11 PM
    As of 4-10-14
    CarPC Progress: 60%+ Starting from scratch with old laptop. Trying to figure out how to get all the programs I want/need for RideRunner!
    My Build/Install Thread
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    great work. like your components too
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. VW Golf "Nexus 7 HU" Install
    By DatTugrut in forum Fabrication
    Last Post: 10-03-2012, 07:52 PM
  2. Nexus 7 install
    By FSUnoles in forum Android Tablet
    Last Post: 09-21-2012, 09:49 PM
  3. Replies: 23
    Last Post: 12-26-2007, 06:54 AM
  4. RELEASE: iG-Nexus (for iG3 UMPC, CF, Nexus)
    By RPM_VR4 in forum SB Skins
    Last Post: 10-25-2006, 11:53 PM
  5. Nexus for RR?
    By RPM_VR4 in forum RR Skins
    Last Post: 10-24-2006, 08:38 AM
