Page 13 of 13 FirstFirst ... 345678910111213
Results 121 to 129 of 129
Like Tree2Likes
Thread: HiJackZX1 UAMCB (Urban Assult Mobile Command Base) ft. The Tobiathin Core.
  1. #121
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    [QUOTE=redheadedrod;1492068]
    Quote Originally Posted by HiJackZX1 View Post
    Well they are not external screens, but at the same time they are, lol. Only when being used in sharing mode do they act as external screens. What web server do you recommend? I am a huge IIS fan, but lots more use Apache.
    I would strongly suggest Apache as it is the most supported web server and is free..
    I would suggest using a LAMP package that is ready to install. I have never had much luck trying to add other packages to IIS where as I can load something like WAMP, XAMPP or Universal Server and you have a full blown web server, ftp server, mail server with PHP and some other options out of the box and takes only a few seconds to install.
    I use XAMPP for my web site development stuff.
    I will look into that. I tend to become very biased on products. So since I am use to IIS, I will not touch the others unless the first one does something I do not like. Look how long I held onto the Car PC being the better choice. Then Centrafuse ****ed me off, and the creators closed their doors. I tried Android and now it powers my install along with Windows 7. Cant use Win 8, because god knows Win 8 is equivalent to Vista, which was equivalent to Millenium. Why MS does that one good, one bad OS stuff is beyond me.
    Quote Originally Posted by daclothe View Post
    what about teamviewer? i know they recently updated where the android clients can act as native touchscreens on the other end...not sure how the whole multiple clients thing would work, but it might be a rabbit hole worth going down.
    The issue that is killing me, is that I need something that will play video in fluid, fast, exact real-time. Every viewer suffers from major lag issues. The only one, and I do mean only one that plays in real-time with 98% lag free video, is Splashtop. Issue is that Splashtop only works with one client at a time. They claim to be working on a new business version that will allow several clients to connect and view a desktop, but there is no ETA on that.
    Did all my measurements. The rear bench is 43.5 inches long across. My second row is much longer, but is a 40/20/40 set up. The middle portion (20) was removed a long time ago to make a center console. I measured the seats and they are 21.5 across each. That's 43 inches, so should fit. Going to start taking things out the truck and do better measurements.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  2. #122
    Sep 2009
    in what way do you need the tablets to interact with the PC desktop? if it's just video & audio, then why not just run a DLNA server on the PC and a capable player on the tablets...
  3. #123
    Jul 2007
    Miami
    The tablets can already access the server. I want a kind of shared mode. So everyone sees the same thing, at the same time, and control it all together. A shared mode. When they want to do their own thing, they simply close the browser or app and use the tablet as normal.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  4. #124
    Jul 2012
    Just read through this ENTIRE thread!!! Good work and great info so far!
    With your new build plans, what are you doing with the MK808, and have you figured out the touchscreen option yet? I am fully convinced that I want to run an Android car solution myself. I would really like to use the MK808 or similar if we could just get a USB touchscreen to work with it! Otherwise, I need to find a tablet that supports USB Host, so that I can still run a bunch of USB peripherals. Following up on a link posted by someone earlier, I came across this capacitive touchscreen that's currently only available on pre-order. http://www.chalk-elec.com/?p=1712
  5. #125
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    I have also been trying to find a tablet solution. Most tablets are now supporting USB Host Mode. But at the same time, many have dropped using a separate charging port. Which means, in the car, when you are trying to use USB host mode, you cannot also charge through the USB port. This can be an issue. At least the MK808s can have a charge AND use host mode at the same time. But still waiting for touchscreen.
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
  6. #126
    Sep 2009
    i used a motorola Xoom even though it's an older tablet just for that reason (has separate usb and charging connectors).
  7. #127
    May 2012
    Grandville, MI
    There are some products out there that will do this but realize they are generally used for businesses and will cost some money.
    The VNC route is likely the best route but will be dependent on your network speed. Just have to find a server that will allow more than one connection to it.
    Another option you might be able to take advantage of is Intel's WiDi or similar technology that will allow you to broadcast a screen to multiple devices.
  8. #128
    Feb 2009
    Hey HiJackZ, did you give up? Thread seems pretty quiet.
    03 Cadillac CTS
  9. #129
    Aug 2003
    Plymouth , MN
    LOL.
    He moved on to Android OS.
    Check out
    Nirwana-Project worklog. The multizone Android SUV.
    http://www.mp3car.com/worklogs/15595...droid-suv.html
    2002 Chevrolet Avalanche
    Gigabyte Z97 mITX Intel Mobo, 8GB RAM, Intel Core i5-4590S 3.0GHz Proc, 320 GB Hard Drive, Dual 12' VGA HDMI DVI touchscreen monitors,....
    http://www.mp3car.com/show-off-your-...avalanche.html
  1. FS: MSI GME965 Core 2 Duo Mobile Mini-ITX Motherboard
    By WiCKeD 5.9L in forum Classifieds
    Last Post: 06-11-2011, 03:24 PM
  2. FS: AMD Turion™ 64 X2 Dual-Core Mobile 31W TMDTL50HAX4CT
    By lxt_123 in forum Classified Archive
    Last Post: 03-06-2007, 04:36 PM
  3. Replies: 10
    Last Post: 01-24-2007, 01:02 PM
  4. Dual core mobile CPU, under 1w!
    By damarble in forum General Hardware Discussion
    Last Post: 06-06-2006, 11:18 PM
  5. Biostar + Mobile Athlon XP (Thoroughbred core)
    By traycerb in forum General Hardware Discussion
    Last Post: 06-25-2005, 11:05 PM
