Results 11 to 20 of 24
Thread: Removable Nexus 7 install in a 2006 F150
  1. #11
    Variable Bitrate Deric's Avatar
    Sep 2006
    Quote Originally Posted by badmonkey23 View Post
    Looks great. I'm working on my nexus7 install - how did you get the tablet to automatically switch from bluetooth when you take it in and out of the dock? It doesn't look like there's any wires plugged in? What wizardry is this?
    It's not using Bluetooth. It's using the Asus dock so its a hardware connection on the 3.5 jack.
    You could use tasker or BT auto connect to connect to a Bluetooth reciever when it is plugged in (docked). If the tablet was plugged in away from the vehicle it simply wouldn't connect to it since it would be off or out of range.
  2. #12
    Nov 2008
    I couldn't see a 3.5 pin in your install, was confused, but now I've watched a vid on that dock I get it now, it uses contact pins (never even noticed them before). Awesome. My build wasn't working out real well anyway, might scrap it and start with this dock. Thanks.
  3. #13
    Sep 2006
    The primer is starting to peel a bit on this so I am going to sand it all back down and apply some adhesion promoter this time around. I was out so I used primer that I used in my Mustang CarPC build but it is not sticking for some reason. More updates after the weekend.
  4. #14
    Newbie jprix82's Avatar
    Aug 2007
    Excellent install,subscribed.
    What case did you use to hold it to the dash?
  5. #15
    Sep 2006
    It was a clear lexan back plate. One of the cheap no name ones on eBay.
    Quote Originally Posted by jprix82 View Post
  6. #16
    Aug 2007
  7. #17
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Nice job :-)
  8. #18
    Sep 2006
    I ordered this exact one
    http://item.mobileweb.ebay.com/viewi...d=290898939721
    However it was a pain to fill in the gaps.
    Also it has been too cold to repaint it. Hopefully I can tackle that this weekend.
  9. #19
    Oct 2004
    NY
    really nice install, only thing that really takes away from it a bit to me is the very big notch for you to pull it out. without that it looks 100%. there's got to be a way to improve that at least a bit before paint, maybe reduce it at least? don't get me wrong, it's really nice as is and if you're happy with it that's what really matters but I think improving that would take this from just being really nice, to being really awesome...
  10. #20
    Sep 2006
    Quote Originally Posted by turbocad6 View Post
    I plan on filling that in a bit once it warms up here. The notch should be about half the height it is now once I'm finished.
  1. The Nexus 8 (Mazda RX8 Nexus 7 / Focal install)
    By Framinator in forum Worklogs
    Last Post: 04-04-2014, 12:49 PM
  2. **2008 VW GTI Nexus 7 Tablet install**
    By maresgti12 in forum Show off your project
    Last Post: 10-05-2012, 12:01 AM
  3. Nexus 7 install
    By FSUnoles in forum Android Tablet
    Last Post: 09-21-2012, 09:49 PM
  4. starting ipad install in f150
    By thenewbreed in forum Car Audio
    Last Post: 05-29-2012, 06:29 PM
  5. 2006 Ford F150 Screw 4x4 Truck - JAPEELER
    By japeeler in forum Worklogs
    Last Post: 12-02-2008, 03:45 PM
