Page 1 of 11 12345678910 ... LastLast
Results 1 to 10 of 104
Like Tree2Likes
Thread: 2012 Camaro In Dash PC Project
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I have been watching peoples builds here for months, and am ready to build my own car PC. I currently have an Android head unit but want to replace it due to it's terrible sound and 80 second boot and long front end initialization time.
    So after searching dozens of topics here, and reading hundreds of posts, I have ordered the following items to start with, all from ebay sellers because of the shopping convenience and selection of items.
    Derrick's DDIN HDMI Case kit w/buttons (arrived yesterday, but still need drivers and diagrams) ebay item 110966372323
    Intel DN2800MTE Atom mobo because it's "Fast Boot" and low profile even after being populated with RAM, SSD, and WIFI. ebay item 400282149972
    Intel 6235 dual band ABGN and Bluetooth 4 mini PCI-E card ebay item 280986615036
    Mini PCI Antenna's ebay item 200823987601
    Toshiba mini SATA II 64GB SSD fast and cheap, ebay item 110965824315
    Hynix HMT125S6TFR8C-G7 2x2GB DDR3-1066 SO-DIMM's (tested mobo compatible list) ebay item 170920996466
    Here is the project car, a 2012 Camaro 1LT:
    Here is the old Android unit to be replaced:
    Test fit the new display in the Metra Dash kit opening ok. Will have to fabricate a new bezel.
    Here is the Amps, Cap, and Sound Processor behind the seat:
    Here are the shallow depth subs in the trunk:
    I still need to order a bunch of hardware like standoffs, cables, connectors for the headers, etc. Will update as I go.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Very nice, you are well underway getting that hardware together. Good luck SNO
    Aug 2003
    Plymouth , MN
    Watching this thread.
    You seem to be off to a great start.
    Keep the updates coming.
    2002 Chevrolet Avalanche
    Gigabyte Z97 mITX Intel Mobo, 8GB RAM, Intel Core i5-4590S 3.0GHz Proc, 320 GB Hard Drive, Dual 12' VGA HDMI DVI touchscreen monitors,....
    http://www.mp3car.com/show-off-your-...avalanche.html
    May 2009
    Ladispoli, ROMA
    I want to know how the Intel DN2800MTE works and if you use a external power supply or use the car battery.
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I had originally thought I was going to power the Intel DN2800MTE off the battery, and power the screen off the provided SATA Drive Power cable (I don't need SATA power since I'm using the mini SATA II 64GB SSD plugged into a mini PCI-E slot), but was not totaly sure, so I read more about power supplies on the forum.
    I decided I wanted the smart function options, so selected a DC to DC converter that I should be able to mount inside the DDIN case.
    So with that research done, I ordered some other items:
    Joycon EXR USB Programable Steering Wheel Interface ebay item 200570124954 (mainly for volume up and down, and song advance)
    Dual USB 2.0 Ports Full-Height Header Bracket Cable ebay item 190508062612 (need the cables and header sockets for the touchscreen)
    18" HDMI Flat Cable ebay item 110957976136
    HDMI 270 Degree Right Angle Adapter ebay item 370653011781 (the location of the mobo's HDMI port makes this an ugly neccessity)
    NoiseBlocker Fan XM2 40x10mm Silent Fan ebay item 130542698378 (case fan )
    DCDC-USB intelligent DC-DC converter to split between the screen and the motherboard. (I added up 90W total if everything, mobo, screen, wifi, bluetooth, SSD, RAM, and 8 USB's are on) Product Code: PWR-034 from mp3car.com
    BU-353-S4 USB GPS receiver Product Code: GPS-004 from mp3car.com
    I still need to decide if I want to go Windows 7 or dare Windows 8, and decide on a front end. Lots more research to do.
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    I decided on Windows 7 home premium 64 bit, so ordered a copy from Amazon.
    The motherboard and Joycon came yesterday. Waiting on all the rest of the stuff that fits on the motherboard before starting assembly.
    May 2009
    Ladispoli, ROMA
    Good, I will wait....
    keep the updates coming
    I want to buy this mobo to remove switching power supply because it has many spurious
    and disturbs a little bit the gps receiver and fm radio ...
    I'm using a Zotac mobo with dualprocessor and 2Gb ram.
    I would like to try this mobo
    Mar 2011
    Interesting. I like where this is headed.
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Well.. any progress is some progress.
    Yesterday I received the RAM, and the power brick for testing, and today I received the WIFI/Bluetooth module, and the Windows 7 DVD. I will try to convert the DVD to a USB bootable image tonight.
    I mounted the WIFI module, and made up a single female to dual male barrel connector for powering up the screen and motherboard, connected an HDMI cable, and a keyboard, and entered BIOS. Not much else I can do without the SSD.
    The motherboard rear blanking panel cannot be installed without cutting the left side inner flange off because the opening on the left side of the case is flush with the left side panel itself. I'll take some tin snips to it when I get my permanent HDMI cable and 90 degree adapter in, because I will also have to cut a slot out to the top of the blanking panel for the HDMI cable to get back in the case.
    Results so far:
    Jun 2007
    Boston MA
    Have you tried test-fitting it into your car? I remember that a lot of users had trouble with BlackBox-ITX because it was too long (depth-wise). This case looks to be a little more shallow since the screen enclosure is considerably smaller.
    My Project: All-in-one Double Din Unit
  1. 2012 Honda Civic Dash Kit
    By ShadowGrim in forum Product Suggestions for the Mp3Car Store
    Last Post: 09-24-2011, 04:12 PM
  2. 1967 camaro Project
    By sikryd in forum Worklogs
    Last Post: 08-16-2010, 12:38 AM
  3. Project Media-Z - 99 Camaro Z28
    By kiztope in forum Show off your project
    Last Post: 08-18-2006, 11:20 AM
  4. Project 'Uber-Hack Camaro' first boot in car!!
    By stealthy-one in forum Show off your project
    Last Post: 05-21-2006, 02:01 AM
  5. Project 'Uber-Hack Camaro' first boot in car.
    By stealthy-one in forum Worklogs
    Last Post: 05-18-2006, 07:41 AM
